Removing power steering pulley (pics)
Old Jun 1, 2010 | 05:27 PM
camaronut396's Avatar
Car: 1989 Iroc-z Camaro
Engine: Procharged 383 Holley Stealth Ram
Transmission: Soon to be ATI TH400/Borg Warner t5
Axle/Gears: Moser M9 4.86
Hey everyone, i am trying to get all the parts and stuff figured out so i can throw the 383 in. My problem is that my power steering pulley is aluminum, and i have previously tried removing it, and broke a little piece off.. so i stopped..
How can i get the pulley off with out having a custom one made?? I called procharger today and they said they have never heard of this pulley... WTF???!?!?! ummm. ok...
so if anyone has advise so that i can figure a way to get it off and back on a new pump with out breaking the pulley into pieces would be great..
Here is a pic of the pulley setup..
Old Jun 1, 2010 | 05:30 PM
Twin_Turbo's Avatar
Re: Removing power steering pulley (pics)
You need a puller, it clamps around the ridge on the front of the pulley and uses a large bolt to draw it out:
works like this:
Old Jun 1, 2010 | 07:59 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
yup that's about the only way w/o damaging it i've never seen the alum. one before def. aftermarket nice piece actually
Old Jun 1, 2010 | 08:09 PM
I tried with a puller like below, and the other picture is what happened... (sorry pics are so big....)
Old Jun 2, 2010 | 03:53 AM
Twin_Turbo's Avatar
Pull the pump, heat up the pulley and try again. Looks like crap quality if it breaks like that.
Old Jun 2, 2010 | 11:06 AM
83 Crossfire TA's Avatar
Heat is going to be your friend with that one... the aluminum will expand much faster than the steel, and if you get lucky you might be able to heat it fast enough that you can just pry it off.
I also have never seen an aluminum PS pulley...
Old Jun 2, 2010 | 07:12 PM
ya it is the pulley that came with the procharger... its a POS... i barely put pressure on a rib, and it broke a tiny piece off.. well when i need to swap pumps, ill try heating it up a lil bit...
Old Jun 3, 2010 | 06:37 AM
Damon's Avatar
When you use the tool I've found it VERY helpful to put a hose clamp around the jaws to make sure they can't slip off the pulley collar. And I mean VERY helpful.
The way the puller holds the arms in place isn't the greatest design and will deflect under heavy load. The hose clamp method positively prevents any slippage.
Also- did Procharger tell you to put that bolt in the end of the PS input shaft to retain the pulley? Stock setups don't use a bolt. As you can attest from your experience trying to get the pulley off, they won't fall off on their own!
Old Jun 3, 2010 | 07:30 AM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Did you have the pulley puller seated correctly? Because I can't see that breaking under even pressure while trying to pull it off? I'd just remove the entire bracket so you have even floor to work on; otherwise you may just damage it too much that you can't run it anymore. Hell I wouldn't even run it with a broken rib.
But I say remove it. I know removing a stock alternator bracket isn't tough to get the power steering pump removed, but I don't know about your set up with the s/c.
Old Jun 3, 2010 | 06:18 PM
it was seated correctly, and then all of a sudden it wasnt coming off, just started breaking that edge off.. and it isnt the actual rib that has a small (.5 in) broke off.. it is the very outer piece of the pulley. so im not to worried about it.
I didnt ask procharger how to remove it, i just asked them if they have this pos pulley and they said no...
and like i say, its aluminum, its soft. breaks apart very easy.... >: (
Old Jun 3, 2010 | 10:09 PM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
The puller i've used in the past had 2 sleeves that completely encased that notch on the pulley. I borrowed it from either O'Reilly's or AutoZone.
Old Jun 4, 2010 | 01:26 PM
Drac0nic's Avatar
83 is probably right on this one, I would at least use a propane torch on it. Aluminum to steel by and large is NOT a pretty proposition when talking about things such as galling. If it's not a wierd offset or something consider a steel pulley they run about $10.
Old Jun 4, 2010 | 10:53 PM
where could i get a steel 8 rib pulley? or would it need to be custom made?
Old Jun 4, 2010 | 11:24 PM
Stangski09's Avatar
I hear AutoZone in the states has inexpensive power steering pulleys. I'm from Canada but I hear these guys have them cheap. Hell I have an extra PS Pulley if you want, it has a piece of the rib broke too, but if you cant find one you can have this one for $5usd and you pay shipping.
BUT you'll most likely find one, and if you don't; that's effed.
Old Jun 5, 2010 | 12:08 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
They will lend it to ya to use also, just don't fubar it up or you gotta buy it.
Or have your Mom return it as women somehow disarm them and they dind't notice I totally F'ed it up hehehehe
I do that all the time, just had her go exchange some spark plugs for me that had ben sitting around for 6+ months, knowing they would probably blow me off but she had no trouble, suckers
Old Jun 5, 2010 | 02:11 AM
Stangski09's Avatar
Yo, I said they have pulleys, not pulley removers.
Old Jun 5, 2010 | 02:32 PM
Drac0nic's Avatar
whoops didn't realize it had some extra ribs. Sorry.
Old Jun 8, 2010 | 05:02 PM
I believe the t-bird super coupes and maybe some of the 3.8 SC GM's used 8 rib pulleys.
Old Jun 8, 2010 | 05:19 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I have a KD puller that wraps the hub much more solidly. Snap on makes an even better one. But sorry bro, it looks like that pulley is toast. Even with heat and a good puller I dont know if youre gonna get it off. Looks like half the hub is gone. Sucks that Procharger doesnt back their products better. I just did have a Pontiac GTP in the other day. Didnt notice if the pulleys have more ribs but its worth checking.
Old Jun 8, 2010 | 06:39 PM
ya idk what to do. once i get the motor out then ill start messing with it. Cant wait to get the rest of my parts for the 383! : )
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
Bull86
Aug 10, 2015 05:43 PM
3rdgenparts
Aug 8, 2015 07:09 PM
