Chronicles of a 9 Second 305 Trans Am, Can It Be Done....
Old Jun 13, 2011 | 09:36 AM
  #451
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Chronicles of a 9 Second 305 Trans Am, Can It Be Done....
Old Jun 13, 2011 | 09:58 AM
  #452
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I think the 76mm will get you closer to the 9's than a 70mm but depending on the car weight, I guess some mustang boys have pushed T70's into the high 9's before so it may be possible. Figuring you need upwards of 600whp, thats asking for a good bit out of a T70. I've seen a DSM make 710whp on racegas with a single T70 but he's operating in a different area of the map compared to a 305 would be, so he can get more lbs/min out of it.
Old Jun 13, 2011 | 01:44 PM
  #453
83 Crossfire TA's Avatar
The typical f-body will need more like 725-750hp to get into the 9's, unless the car is _really_ light. OTOH, a mismatched combination with a turbo that can push _something_ into the 9's won't be as fast as a well matched combination that may be borderline for getting there if you know what I mean.
My choice on those would depend on pricing and what hot sides are available.
Old Jun 13, 2011 | 02:24 PM
  #454
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
If you feel the rear will hold up to a transbrake launch you can touch 9's with less power...else if you come off the line slowly, you will need a crapton of power up top to make up the lost time. ask me how i know
Most of your ET is in the first 330 feet
Old Jun 13, 2011 | 02:44 PM
  #455
Old Jun 13, 2011 | 02:48 PM
  #456
Old Jun 13, 2011 | 02:52 PM
  #457
what cam is that? That's way too much gear...
huh... OK, for a 305 my instinct is something in the .85-.95A/R range, so it looks like you're a little small or a little big with either of your choices. I'd shoot a little small if you're looking for better street manners, and little big if you're looking for best performance at the track, of course, I'm cheap, if I'm debating between $275 and $875 for the same use it's goig to be the $275 and it would be the 1.05A/R setup.
Old Jun 13, 2011 | 02:55 PM
  #458
Old Jun 13, 2011 | 03:02 PM
  #459
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I'm wondering if you need a q-trim... a T4 .96 P trim may work but start to become a restriction above 600whp I'm thinking. P trim T70 is like 600 bucks, so I'd think the T76 should be around the same price. Look up Modular Turbo, a vendor on LS1tech. He got me decent deals on my masterpowers.
Old Jun 13, 2011 | 03:05 PM
  #460
Old Jun 13, 2011 | 06:08 PM
  #461
project89's Avatar
the gt45 will be spooled up by 3k on a 305,but regardless if ur using a megasquirt u can spool that turbo at dead idle if u wanted to
http://www.youtube.com/watch?v=YpZFg_2_5xo
if u want twins i can build u a set of log headers i already have the weld els
and a pair of ebay t3/t4s will support just a tad over 900 hp
Old Jun 13, 2011 | 06:25 PM
  #462
metalhead212121's Avatar
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
project89- really stupid question... whats up with the popping sound in the video??
Old Jun 13, 2011 | 06:29 PM
  #463
project89's Avatar
the popping u hear is the antilag/lauch control system active
when activated it adds between 5-30% extra fuel depending on how u configure it
at the same time it retards timming i use a setting of 0* btdc ,and it also starts droping spark to one cyl at a time
this allows the raw fuel to get into the turbo headers were it is ignited by the retared timming and spins the turbo up really fast
fuel amount
ignition retard
rpm
and spark cut (number of sparks droped per amount of ignition events and even the park drop pattern )
is all adjustable
Old Jun 13, 2011 | 06:37 PM
  #464
pretty cool... do you have a catalytic converter on the car?? I'm wondering if you have to worry about raw gas clogging the cat or if the raw gas is "recycled" back into the engine...
Yeah.. as you can see my knowledge of turbos only goes so far..
Dan
Old Jun 13, 2011 | 06:42 PM
  #465
project89's Avatar
that was pilsburys car, i helped him build it and did all the base tunning on it.
i dont rember if he had a cat on the car
i dont recomend using one though unless u have an open cutout before the cat,also this system has to be used with a stright threw muffler
or u risk loading the muffler up with raw fuel and exploding the muffler
for cars with cats and chambered stle mufflers id setup the launch control as a 2 step
no extra fuel added with ignition retard with spark cut only at the very upper limit of launch rpm
Old Jun 13, 2011 | 06:43 PM
  #466
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Thats interesting, i dont know if they raised prices or not, but 650 for T70 seems high let alone 775 for T76. I got my pair for 550 each from him
Old Jun 13, 2011 | 09:11 PM
  #467
Drac0nic's Avatar
I thought you had a pair of TE44s? That should easily be enough to push a third gen into the 9s. Why not use those especially if you're doing custom uh oh
headers. Otherwise single wise I'd be thinking T76. I like the idea of the HX52 as well, I'm going with a TMF5502 on mine (I think, unless I figure out where to cram two GN turbos in my engine bay)
Old Jun 14, 2011 | 12:22 AM
  #468
The HX52 would be my no brainer answer if it wasn't for the fact that there is no real upgrade path from it. That is the largest compressor connected to that exhaust flange, everything else is different. TMF5502... never seen one in person but they were used on some of the same DD's as the GTA4202 that I have... a bit largish for a single on a 305 and may be a pain to package.
The problem i have with twins is that there is no way to run more than a 2.5" down pipe on the driver's side unless you rearrange the brake setup (manual or maybe hydroboost). If you want to go twins there are tons of choices that will get you close or into the 9's that should be fun...
Old Jun 14, 2011 | 07:22 AM
  #469
Drac0nic's Avatar
I'd just get a hydroboost. I'm going to probably hit one up in the future no matter what I do.
Yeah it's a similar package to a GTA4202, and it's being a bastard to cram in. Some mods to the floor pan and it will be servicable. I'm thinking of getting a scavenge pump and mid mounting atm. Since I have a van under the passenger side seat would be nice and easy, improve weight distribution, remove engine compartment heat and probably some other stuff I have forgotten. Maybe I should get an engine out and start mocking a bracket up for this beast.
It's a "bit" large but based on my calculations assuming I'm putting down 250-275hp N/A it will actually fit on the map of a similar sized turbo (GT4202/4294) fairly well. The turbine/spooling is my big concern, but I figure I will use electronics for that if worse comes to worse.
Old Jun 14, 2011 | 07:23 AM
  #470
Old Jun 14, 2011 | 08:37 AM
  #471
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
3" on mine. Plenty of room there, just gotta heat sheild the booster/master since everything does sit close.
Old Jun 14, 2011 | 08:54 AM
  #472
Old Jun 14, 2011 | 03:37 PM
  #473
Heh, that would be right in my sweet spot for sizing... enough so that I'm tempted to buy one, though I have no idea WRT to that specific model/seller. Looks very compact for what it is, I'd be a little worried WRT to real world airflow.
Old Jun 14, 2011 | 05:01 PM
  #474
project89's Avatar
theres 2 guys i know using them on the turboforums, and i know of a few mustang guys using these too they make pretty much what a mp turbo would make powerwise
btw rom here t76 new shipped to ur door for 330 bucks
http://cgi.ebay.com/ebaymotors/3-Per...item1e645eefec
Old Jun 14, 2011 | 05:31 PM
  #475
Old Jun 14, 2011 | 06:10 PM
  #476
Drac0nic's Avatar
Originally Posted by Street Lethal
I still have those turbo's, but they have a different style flange. I would either have to make some type of adapter, or ask Ed to scrap the T4 flange and make the headers with that style flange. That Master Power T76 is really grabbing my eye though, so I may just have him make me an earlier type of his header setup. I know he is working on his website right now, but I'm hoping he gets started on them as soon as possible cuz I'm really getting itchy lol....
Just FYI they are standard 2.5" 3 bolt header flanges. I got 2 off ebay for $5 each. I'm thinking of a scavenge pump now to fit mine in.
Old Jun 14, 2011 | 06:28 PM
  #477
project89's Avatar
.81 will be fine,u will be rpm limited anyways because of the tpi , 6k tops and relistically more like 5,400
u want the turbo to spool up fast and be all done by 5,500 ish rpms to match the power curve of the tpi
the ebay t76's do measure an actual 76mm compressor and p-trim turbine wheels
which btw that 200 bucks u save could buy u an assortment of used ptrim turbine housings but for a tpi 305 u wont need more then the .81
Old Jun 15, 2011 | 04:44 PM
  #478
Old Jun 15, 2011 | 06:46 PM
  #479
project89's Avatar
even still the 81 will be fine
Old Jun 15, 2011 | 08:55 PM
  #480
The .81 will probably be OK, but it would definitely be more on the "street" side of sizing rather than a race setup...
Old Jun 15, 2011 | 10:59 PM
  #481
project89's Avatar
psst rob this is right up ur alley
https://www.thirdgen.org/forums/engi...ml#post4953136
Old Jun 26, 2011 | 08:36 PM
  #482
any updates??
Old Jun 27, 2011 | 01:58 PM
  #483
Old Jun 27, 2011 | 02:25 PM
  #484
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
man this makes me want to set aside the 401 and try to build a 305 and see what happens. Seems like a nice challenge to try
Old Jun 27, 2011 | 02:53 PM
  #485
ARRGGG, mine just started making a weird ticking noise last night... I'm hoping it's valvetrain... the only other engine I have sitting around is a 350... don't wanna do that...
Old Jun 27, 2011 | 05:31 PM
  #486
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
you criticized me on the fact that i built mine up in my thread about building a 307
Old Jun 27, 2011 | 06:02 PM
  #487
Wait, did you actually build a 307 or did you build a .010" over 305?
Old Jun 27, 2011 | 06:33 PM
  #488
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
my dad built the 305 in the car presently, and my moms ex bf gave me the old 307 out of his chevelle that had 14xxx on it in favor for a 396. i havent built it yet, but when i get my priorities stragihtened out it will be in the works. i had a wierd idea for it but im not sure it would work without extensive machining
Old Jun 27, 2011 | 07:38 PM
  #489
not entirely odd if you have the parts... there have been a few engine masters entries that started with 307 blocks, one that won...
Old Jun 27, 2011 | 08:12 PM
  #490
Drac0nic's Avatar
The only thing about a 307 is they are a bit harder to get pistons for. Expect that to come up. If you're doing a stock bottom end shove a cam in it and have fun. I would do a cam pretty much no matter what 307s were known for eating them.
Old Jun 27, 2011 | 08:54 PM
  #491
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
so maybe i was wrong, im sure you will easily be able to fit a pt88 on the bbs design single headers, my headers arent too different from the bbs just my turbo is alot further forward, when i built them i just had the mpt70 and i thought it was a nice tight fit, but this pt88 fits just fine and doesnt hit anything at all. my only concern right now is hood clearance but i had like 1.5" all around on the mpt70.
i say go with the 88mm
Attached Thumbnails Chronicles of a 9 Second 305 Trans Am, Can It Be Done....-pt88.jpg   Chronicles of a 9 Second 305 Trans Am, Can It Be Done....-pt88-1.jpg
Old Jun 27, 2011 | 10:24 PM
  #492
Still waiting on BBS, haven't heard anything from them yet....
I thought you said you were gonna run your car naturally aspirated down the track first and then opt for the turbo(s)... Did I miss something??
Dan
Old Jun 27, 2011 | 10:41 PM
  #493
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
i kinda wanted to see if a 350 crank and a.30 overbore would work, just for ***** and giggles, otherwise i think a cam and a little work with a turbo would make a decent driver engine
Old Jun 28, 2011 | 06:11 AM
  #494
Old Jun 28, 2011 | 08:59 AM
  #495
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I dont believe this is correct....i cant find one post that I've criticized you on your build...in fact I dont see any build threads that you started???
Old Jun 28, 2011 | 09:18 AM
  #496
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
eh i thought you commented against the idea on my 307 thread, sorry i got a little defensive, i meant it in a sorta joking way but it was still uncalled for. oh well not a big deal, i shouldnt have said anything, my sincere apologies, but now back to the thread
Old Jul 2, 2011 | 10:58 AM
  #497
Drac0nic's Avatar
Def an oddball combo but I bet you could do it with some stock 400 rods and stock 307 slugs. Piston selection is sorta limited though.
The other thing is that 283 slugs are the same bore I believe, but you'd have to run the 307 crank and 400 rods or you'd have to run a 3.0 stroke crank and 5.7 rods.
Another cool combo for this could be a 283 crank and then using 307 slugs with 5.94 rods out of a 4.3L V8. It would be a 283 but give better pin height than a regular 283 would.
With some custom slugs there are a TON of combos out there for a 307 with rod and stroke, I'd almost be inclined to do a 400 crank in the block if I was going to that expense (which I wouldn't really, I'd be inclined to do the 350 crank/5.565 rods and 307 slugs if anything.)
As a last alternative something that is a little on the exotic order that could be doable is LS1 pistons. You'd have to match the right set of rods up to the right slugs to make it work but they have the same pin diameter and a set of
Some thing like ross 99837 would let you use a 400 crank, 6" rods and leave 5 thousandths for the deck to be cut. Could be a wicked combo overall and would probably be about 360 CID in a 307 block.
Old Jul 2, 2011 | 01:28 PM
  #498
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
what are you reffering to as slugs?
Old Jul 2, 2011 | 01:55 PM
  #499
Drac0nic's Avatar
Pistons. I'm not sure on the model though they may be pushing the rings WAY up to get that C/H. Not too sure it'd do well with forced induction. On the plus side if you kept the stock chamber volume and increased the stroke to 3.75 you would gain a lot of compression. For nitrous or a N/A engine the easiest thing to do to a 307 would be 305 heads that are ported some or L98 aluminum heads and a cam. That would make it make a lot more power than it did initially. For boost some 350 Vortecs and a cam would make it run very well I imagine.
Old Jul 2, 2011 | 02:14 PM
  #500
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
does the 350 cranks stroke have enough clearance for the pistons walls though? and with 6 in rods youd be using around 1.6 rocker arms i think
