What plugs to use with this setup?
Old Aug 1, 2010 | 09:36 PM
ian1320's Avatar
Car: 88 IROC-Z and 86 IROC-Z
Engine: TPI 305 and E85/Nitrous 383
Transmission: 700R4 and T56
Axle/Gears: 3:27 and TBA
I just finished my 383 build and im looking for some advise on the right plug to use for my 150 shot.
The engine is a vortec 5.7 (bored and stroked to 383) with an LT4 Hotcam, 062 heads, 10.5:1 compression, full MSD ignition system w/ 6AL box. It currently runs on premium but im going to be switching to an quickfuel e85 system soon.
Does the difference in fuel require a different plug as well? If so what do you suggest for both setups?
Thanks in advance for the help.
Old Aug 4, 2010 | 05:09 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: What plugs to use with this setup?
i run 2 steps lower in my car with the supercharger i run a 3924 autolite
Old Aug 4, 2010 | 07:39 AM
ian1320's Avatar
what fuel do you run? There is a ton of info out there for gasoline + nitrous but info on e85 is slim.
Old Aug 5, 2010 | 04:48 PM
ian1320's Avatar
NGK TR6 N/A and NGK B8EFS on the spray..... that a good starting point?
Old Aug 5, 2010 | 06:57 PM
tom86iroc's Avatar
Car: 1986 iroc
i run a mix of 94 and cam2 112 i believe yeah i'm not fimiliar with e85
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Feb 28, 2016 03:33 PM
stalkier
Dec 6, 2015 11:25 PM
Bryan F
Aug 27, 2015 07:28 AM
Street Lethal
Aug 13, 2015 08:28 PM
