low cost and low boost turbo kit???
Old Sep 18, 2010 | 11:48 AM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
would a t-70 turbo rear mount would run fine without methanol injection and intercooler du to rear mount turbo(cooler)
with the stock 1989 prom with a maf, ecm reprogrammed by sinister can it handle 5 psi or max out the maf?
26pound injector enough
stock fuel pump enough
will probabely go with FMU
sacvenge pump
i expect 450whp.
Old Sep 19, 2010 | 10:23 AM
Speedfreak391's Avatar
Car: 87 iroc Arctic White w/gold ss stri
Engine: Turbo'd 5.3 in process
Transmission: T-56 w/SPEC stage 3+ clutch
Axle/Gears: 9" Moser w/3.25's
Re: low cost and low boost turbo kit???
Not sure but it sounds like you will need bigger injectors, and better fuel pump. and I think you should be ok. But before you think your going to double the hp of your motor on 5psi of boost you better think again. 5psi on the stock 350 in an iroc will get you around 50-60hp across the board. you will not double the output of the the engine until around 15psi. Just a little heads up.
Terrell351
Jun 13, 2021 01:13 PM
toronto formula
Nov 10, 2015 06:17 AM
fasteddi
Sep 2, 2015 10:29 AM
E Rod
Aug 28, 2015 05:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
