Turbo 1991 z28 with A/C - Turbonetics tc76
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Re: ** Engine bay paint pics 1/1/12** Turbo 1991 z28 with A/C - Turbonetics tc76
I like it
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
well I was going to coat everything, but i could buy a new hotside for the price of coating so I VHT rattle canned (and baked) the headers, and wrapping the rest. When/if the hotside fails I'll redo it in stainless
all i have left to do is clean/paint the engine and put it all back together
headers coated, ready for the oven:
hotside cleaned ready for wrap and painted the water pump:
all i have left to do is clean/paint the engine and put it all back togetherheaders coated, ready for the oven:
Re: Turbo 1991 z28 with A/C - Turbonetics tc76
ok i was real sick the other day so i didnt come by. but i need to get by there sail one day and check it all out in person. that looks really good man. what color on the engine.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
That or just do simple logs in sch. 40 mild steel pipe and weld els. Thats what I may do if it ever gets that far. I dont see the wrapped mild steel failing anytime soon with turbo braced up and a good tune. Cracks? just keep rewelding/patching as needed til it all crumbles. Logs may not be as efficient as a header but oh well, just run more boost as needed to make up for it.
I may try to cast my own custom manifolds if the header deal doesn't play out well. Casting stuff is pretty easy as long as you can melt some iron to pour
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
VHT'd the welds, the rest is aluminized so I didn't paint it and just wrapped it. Need more wrap to finish the waste gate tube and the down pipe, hopefully I can find some tomorrow. Pressure washing and degreasing the motor tomorrow, a little paint, then stabbing it all back in!
I'm at bit of a crossroad on what to do with my clutch/trans... Since it's an LT1 the only clutch options are up to about 500hp for $400ish, then its $1200 for the next step (twin disc good to 1200hp). I think I'm gonna stay with what I have until it gives up the ghost or I have the cash for the big boy clutch... sucks.
On top of that I have a vibration I can't figure out, its not the wheels/rear/DS all of that is new or balanced since I noticed the vibration. past about 65/70 MPH I get a relatively high frequency and powerful vibration that is speed related since it's the same in an gear, neutral, clutch in or out. I think it's my tail bushing and or yoke but I'm not sure there is 1/32" or a bit more side to side (or up and down) playwhen the driveshaft yoke is inserted into the tail housing and the seal has a small leak (the yoke does not seem worn but I have not mic'd it yet), could be internal trans... A total rebuild is only $680 with billet forks/pads and carbon syncros but again thats money/time I dont have right now and I just want to get the car on the road even if its with 1 psi, but that means I'll have to pull the trans AGAIN to fix it. /rant LOL
If anyone local knows there way around a t56 or has experience with play/tolerances for a yoke and tail housing in general and could take a 5 minute look at it it would be great, My option is that its just the bushing but this is my first time with such a little transmission, I'm used to BIG slow diesel transmissions where an 1/8" of play is ok, and this high rpm gasser trans seems like it should have super tight tolerances to me but what do I know... (very little!)
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
If it does it whether it's in gear, nuetral, clutch in or clutch out, I would be VERY surprised if it actually was the tranny. 99% of all tranny problems I've ever seen will stop or go away whether it's in or out of gear (ussually out of gear). I would look at the driveshaft or if you have an adjustable torque arm, make sure the angle is right. My brothers car has a pretty tight U-joint on the driveshaft (axle end) that he has to have fixed. Thought it was bad so we installed a new one but it was still tight. I think the drivesahft may be slightly bent, and right around 70 mph and up it has a very noticeable vibration that just gets more and more violent the faster you go. It's not just the steering wheel or shifter either, it's like the whole car is vibrating. I would def check out your drivesahft before anything. If in doubt, new U-joints are like 13$ a piece.
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
that is exactly how it feels, it's scary almost
I've done u joints twice, DS balanced, new rims/tires, new rear end, and it's still there but since its independent of gear/clutch manipulation I assume its the yoke/bushing/output shaft since that is the same regardless of gear/clutch. I guess I'll throw it all back together, new front u-joint since the new one does have a spot where it sticks, and double triple quadruple check the driveline angle, if that fails to fix it I'll borrow a known to be good DS and see. You have no idea how badly I want you to be right that it's the DS
even though that means my 3.5" custom CM bad *** shaft is trash
even though that means my 3.5" custom CM bad *** shaft is trash Supreme Member
Car: 1986 Trans am
Engine: 5.3 LM7
even though that means my 3.5" custom CM bad *** shaft is trashBTW, progress is looking great. Love the way turbo pipe looks all wrapped up! Can't wait to see some more done.
Car: 89 Iroc-z
Transmission: TH400
His setup could use a twin disk or slipper clutch to be optimal but its doing a great job holding that power.
Some other guys I've talked to say they liked their Spec 3 clutches as well
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
hmm the spec clutches do look like they'll work, dont know how i missed them. thanks Orr!
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
dont know much about the t56 but maybe the tailshaft bushing is toast? also, maybe check for grooves one the yoke too
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
hard to do that with the motor/trans out, I have a spohn adjsutable TQ arm and I set the pinion angle to what I though was correct last time I tried to sort this issue out. the thing I run into is the trans and rear result in
[trans] \ ___[DS]___ / [pinion]
if that makes sense, they both point down which I beleive is wrong and I cant remeber if I was able to fix that last time I adjusted it. The correct way is like this right?
[trans] \ ___[DS]___ \[pinion]
I used a how to and set is to like -2 last time (if I did it correctly)
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
everything is ready to go back together tomorrow! I cleaned the motor today, new pilot bushing, finished wrapping the hotside, gonna clean the shop and start assembly tomorrow
clean motor:
new pilot bushing:
wrapped hotside:
clean motor:
new pilot bushing:
wrapped hotside:
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
got the motor in last night and fixed the brakes (have not tested if they leak though, got the last few pieces painted up, going to do the final install and hopefully start her up tonight
hotside silicone sealed
motor and transmission reunited
up on the hoist, the bag is to catch the little bit of fluid still left in the trans
to everyone who says you can't pull/insert the motor with the dizzy on... I did it WITH a long t56 trans attached with ZERO issues.
in and looking good
different angle
now the fun part, installing all new and clean parts for a few hours, that I know fit and work!
in and looking good
different angle
Car: 1986 Trans am
Engine: 5.3 LM7
Damn you move fast! Wish I could say the same on my build lol. Things looking great man! Can't wait to see that nice engine bay filled up a little more.
as a quick roundabouts check, toss the angle finder on the ds and then the pinion yoke on the rearend. the difference between the 2 angles should be 2-3 degrees or so. a friend of mine was having trouble like you are describing on his car, and i measured something crazy like 15 degrees of pinion angle. vibrated like crazy.
how is the plug access with those headers on the LT1 heads?
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
whitedevil - yeah I've bee busting my butt because I want to drive it a few times before I go back up to school. I have about 1/3 of the stuff back in now, its looking nice
ok when I get the DS back in I'll check it out and post up my findings
they are "113" aluminum corvette L98 heads I believe, unless you see something that indicates they are lt1 heads? But to answer your question the plug access is great since I'm running the headers upside down, look at post 76 and you can see the passenger side plugs from below, the drivers side looks the same without the down pipe. From the top plug access is still very good
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
aw man, I was hoping you were right, then I may have non-hyper pistons too! oh well
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
BIG update!
ok well it's pretty much done! (aside from forging the motor and putting in a nice clutch but that's down the road
I did find an elbow that would work for my intake, spectre PN:9781
I have been having issues with my brakes, and I had a crappy brake line for the front pass side so I redid that and put a new master in, all should be well now I hope.
I did the line repair first, here is my arsenal of tools, one of these doesn't belong..... yeah thats how well my line repair went
but i got it done:
and bench bleeding the new master:
I used copper RTV on all of my flanges like most turbo guys do, i put it one kinda thick and am concerned it will break off and go through the turbo but oh well I'm risking it LOL
headers on:
)I did find an elbow that would work for my intake, spectre PN:9781
but i got it done:
headers on:
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
BIG update! cont.
down pipe and some accessories:
turbo all bolted up:
how I did the cold side piping:
pretty much done except some plugging the harness back in and some clamps/hoses for the small things!
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
so this is probably a stupid question, but am I going to have to relocate all of my vacuum lines?
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
there's shouldn't be a vacuum big enough on the intake side of the turbo lol
put a vacuum manifold off the brake booster line and run everything off of that.
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
why would there not be a vacuum on the intake side of the turbo? there HAS to be. I'm talking pre-compressor wheel, between the filter and turbo
what is a vacuum manifold? like a vacuum canister?
Car: 1989 firebird formula, 1991 z/28
Engine: none LSX! one day, 350tpi
Transmission: none t56 one day, t5
Axle/Gears: 9-bolt 3.45, 10 bolt 3.73
i would run everything off a vac. canister with a check valve between the canister and manifold
Engine: LZ9????
Transmission: 2004R
all the smog accessories run during part throttle driving, should be vacuum there just put a check valve to keep positive pressure from reaching them under boost.
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
well all that I have running on vacuum is a/c, cruise, and brakes so a check valve would work for cruise and a/c, not like those are gonna be on under boost. The brakes though... Hmm I'd rather go with a constant positive vacuum than a canister for simplicity's sake, along with the fact I'm nearly out of room under the hood
Car: 89 Iroc-z
Transmission: TH400
so this is probably a stupid question, but am I going to have to relocate all of my vacuum lines to the intake side of the turbo? I know I will only be seeing boost at WOT so i guess as long as the vacuum lines are clamped on i'll be ok and just wont have power breaks or cruise under boost LOL. so how does one brake boost then???? I feel dumb
I've seen 18psi here and never blown off a hose or hurt my booster that I know of.Under WOT with boost, soon as you let off the gas, the pressure is released by the BOV and engine now is making vacuum so the brakes come back. The booster stores vacuum from the last highest vacuum reading it received until you press the pedal.
To brake boost at a stand still, just hold brake down and hit the gas. Once the brakes are pressed, boost will not change anything. Brakes are already clamped and holding.
All my other vacuum lines are to the intake as well. If you ran a PCV system like factory, then you need a strong check valve or run the vacuum to the compressor side of the turbo but becareful of sucking oil into the compressor!! Need a oil-air separator installed between intake and manifold.
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Factory brake booster has a check valve in it. Run the brake vacuum line to the intake and dont worry about it.
for the PVC system, I'm currently at stock configuration I think, 1 PVC valve on each valve cover, both going to the intake, one at the back, one just behind the throttle body. To run a catch can I need to run both of those lines to the catch can (air/fluid separator) and then to the intake plenum? I have read there needs to be a fresh air makeup but I'm not really understanding the system, but I though it was better to have a vacuum in the crank case
Car: 1986 Trans am
Engine: 5.3 LM7
ok awesome, I knew it wasn't as complicated as I was trying to make it
Car is coming together nice by the way. Lets hear some dyno numbers soon!
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
I'm not sure the exhaust will pull enough vacuum, and your gonna have to have a well designed setup to get that to work. You need high velocity exhaust gas that's not under much pressure AND a good fitting to tie into the exhaust to produce a decent vacuum
haha dyno numbers... Probably not until summer sadly, school starts in a week plus I'm still rocking hyper pistons so it wont see too much boost for a while
Car: 89 Iroc-z
Transmission: TH400
I just vent both valvecovers to a big moroso catch can and its working fine. I actually get very little oil coming out of the covers. NO idea what my crank case pressure is if any pressure exists, but I dont have oil coming out of anything in or on the motor so I think all is good.
If you wanted to run a PCV to the intake to use vacuum to suck vapors out of the crank case like the factory, you need some checkvalves.
If you ran to the turbo air intake side, there will be alittle bit of vacuum there but depending on the system there may not be alot at cruise speeds like the intake plenum would see. But assume there is vacuum, you'd need a separator like this:
Another option is this: basically check valve system for boost
http://www.et-performance.com/turbo.html
i may be looking into trying that system
Car: 1986 Trans am
Engine: 5.3 LM7
Believe it or not, the exhaust mounted evac setup works great as long as it's set up correctly. V8 drag racers have been using this setup for a LONG time. Only thing is that the exhaust has to be free flowing past the fitting, so if you have a muffler, it may not work great. I'll have a straight through exhaust and "bullet" style muffler so it'll be fine. It also will make more vacuum the closer it is to where the downpipe comes out of the turbo. I'm sure 3-4 feet back will still make plenty of vacuum though. There are special weld fittings that are curved that go into the exhaust and use the flow to create vacuum. Then you add a metal one way chack valve to prevent the chance of exhaust gasses getting to the motor and your good to go. Heres a pic I found on a turbo setup after a quick search.
People say that the optimum setup would be to use a catch can connected to both valve covers, and then run a line from the top of the can to this exhaust vacuum source, but thats really to prevent any smoking out of the exhaust from possible oil burning up in it. Just seems like a cool method to me, and I like the fact that theres no need to add an expensive vac pump when you can let the engines exhaust flow do it for ya!
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
orr -
oh ok so you just let the pressure in the crank case push hte vapor into the catch can which is vented to air, gotcha. thats simple enough.
white devil -
that would be nice to save some cash, it would be interesting to see a reading on how much vacuum those setups actually pull. I know it can be done it but if the flow over the fitting isn't just right I could see it being unable to develop much of a low pressure but maybe thats all it needs since the crank case is at a somewhat positive pressure? hmm I'll have to look into this more
white devil -
Car: 1986 Trans am
Engine: 5.3 LM7
Some guy said he played around with it a bit with a vacuum gauge since he was curious, and he was getting about 10 inches of vacuum through one of those exhaust setups. I don't know how it works to be completely honest with you, but it does I guess haha.
orr -
white devil -
white devil -
Car: 89 Iroc-z
Transmission: TH400
I'd be alittle nervous on a turbo setup tho.. the downpipe is receiving high pressure exhaust from the waste gate. I hope it gets reduced enough by the time you get to the evap system on the exhaust. Else it would seem you'd have some backpressure in the exhaust...especially if you run FULL exhaust with mufflers all teh way back out the rear of the car. Thats alot of pipe and theres alot of flow losses with all the straight runs and bends. Need a larger system to reduce some of the pressure and really high flowing muffler, which by that point really doesnt muffle anymore
Exhaust evap works great on headers with good collectors because theres a high velocity point there that creates a vacuum to "suck" on the exhaust ports. This is how you make power and that suction can be used to evacuate the crank case...but you dont have that on a turbo system..its just one open pipe of constant cross sectional area.
I never tried it so I dont know. I just know when you have a pin hole in the exhaust, you have black soot around that hole. Air is coming OUT not sucking inward.
they just work off the same principles as some of the blow off guns.... they put holes in the end of the nozzle so the air flowing through the end will pull in additional air and increase volume. as long as you have good velocity running through the exhaust, the system should work fine. thats what i think, anyway.
Car: 89 Iroc-z
Transmission: TH400
I guess that makes sense...its been along time since i had fluid flow dynamics classes...and I dont remember alot of the subject
Engine: LZ9????
Transmission: 2004R
ive never seen a PCV exhaust EVAC on a turbocharged engine. if it were me id just make a oil separator or buy one and hook it to manifold vacuum or turbo inlet, or vacuum pump
Car: 1986 Trans am
Engine: 5.3 LM7
The vacuum pump operated systems are great as well, and really don't have many downfalls except cost...which is the main reason I'm straying away from that idea.
The exhaust set up seems, IMO, to be the most reliable and best for a street car. I really don't see how running the fitting into a turbo downpipe will be any different than running it into a header collector. After all, turbo's create much more heat and velocity than an N/A motor would. Chances are if you are running a turbo setup, you are not going to have a restrictive muffler in line since thats a big power robber. The turbo basically acts like a muffler, so in reality, you really don't have to run a muffler at all. I have heard plenty of freinds cars that are very quiet with a dumped downpipe. The biggest tip I have heard when using this system is to try to locate the fitting on an area of the exhaust that is straight, and not on or right after a bend, and it should be golden.
Again, just my .02 cents. I know that the majorty of people run a setup like orr's with the valve covers just vented to a catch can, and you rarely hear of problems coming up. Having some kind of vacuum source is just a bit of a plus I guess.
i think the diesel tractor pull guys pretty much run a pipe out of the crankcase directed to the ground under the tractor. with 100+ psi of boost, it spews out like its an air compressor. lol
Car: 1986 Trans am
Engine: 5.3 LM7
http://www.coloradospeed.com/index.p...ducts_id=17761
^^ Figured you may want to check this out. It's a bit pricey at $160 but after doing about 4 hours of research on LS1tech, it seems like one of the best options out there, and has a pretty clean install as well. I def think this is what I'll be going with on my setup. Claims it's for LSx motors, but will work on anything. It's a catch can system that has built in one-way check valves on the ports. You plumb one line to your valve cover, one line to your intake manifold vacuum source, and one line to the area between the air filter and turbo inlet. It uses the engines vacuum under normal cruising and idle to get gasses out of the crankcase, and then as soon as it senses boost, it closes the intake port and opens the turbo port, using the turbos "suction" to create a vacuum under boost. This way you ALWAYS have a suction source whether under boost or not. Looks pretty awesome!
Car: 89 Iroc-z
Transmission: TH400
Looks interesting but on my setup I will not have air intakes on the turbos, just open screens
No place for inlet vacuum source
Car: 1991 RS Camaro
Engine: 400 Smallblock
So reading this thread has convinced me of a few things...
First of all I will be doing this to my car as soon as I have the money and facilities.
Second, as soon as I get out of college im taking a job in Texas. This was my poor baby last November...just a day after I finished digging it out from the last snow storm
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
what is that white stuff????
it's nice only having two seasons down here, but the summer heat is hard on stuff, 130+ degree heat cycles 90 times a year in the garage does bad stuff to cars/boats/anything
Well for an update I put in 13 hours today, 10 or so yesterday, and all thats left is to hook up the boost/vacuum reference lines to the WG and BOV, plug wires, and fashion a radiator overflow tank then I can start it up. Over the last couple days I re-loomed and rewired most of the harness, finished the intake, put the clamps on, did the exhaust, relocated the battery, new starter, buttoned up some loose ends etc. No new pics since it looks the same pretty much, I'll get a vid of it running in a day or two
So since I'm not going to tune this SOB for a month or two, how can I trick the waste-gate into staying open so I can take the dam thing for a drive on just a couple PSI? I assume I could just put a ball valve on the WG and hit it with compressed air at like 20psi (or just slightly higher than the WG spring rating) and close the valve when it's under pressure to keep the WG open? I cant imagine spooling the turbo with the WG open especially if I baby it, i don't want to blow the motor up on a test drive LOL
