Twin turbo 383 build - I'm pretty new to this forum
#101
Re: Twin turbo 383 build - I'm pretty new to this forum
I think im going to run the LT1 ecm and then use the megasquirt III system on top of that. Then Im going to get rid of the old wiring harness and get this simple fuel injection wiring harness.
http://cgi.ebay.com/ebaymotors/1994-...#ht_1199wt_939
But im still a little confused on how to delete the opti spark system. Do you have any experience with that?
id idnt read the entire thread just yet but u can delete the opti by using a ford edis ignition setup. this is a wasted spark system and is very easy to install.
another option would be to use ls1 coil packs and do a cop setup.
u do not need to run the ms3+3x system to do this. u just need a crtank triger wheel and convert the opti distributor to put out a cam signal which is very easy to do .
i plan on switching to ls1 cop on my gen1 355 with twin turbos this comming summer for now im just using the hei dizzy
check out my build thread for some ideas on how to do the plumbing and assorted stuff
#102
Car: 1987 Chevy Camaro
Engine: 383 twin 60mm turbo
thats a decent size. Sounds like a stage 2 or maybe stage 3 turbo, like a T04E 50 trim wheel which I believe is 54mm/76mm. Should be ok for 350-400 hp per side if pushed. 700-800 hp total but thats stretching it abit. Will be spinning it hard.
Does the compressor housing have atleast a 3" compressor inlet? I would assume so.
#103
you can get away with 2.5" from turbos to intercooler and 3" to throttle body if you like. I have that combo now and its working but I may go to a 3.5-4" pipe from intercooler to TB if I upgrade to a 85-90mm TB
#104
Okay. So im running the lt1 style throttle body and its the upgraded bbk twin 58mm throttle body. So you think I should run a 4inch to the throttle body?
#105
#106
Okay cool thanks for all the input
#109
Originally Posted by junkcltr
a 3.2" round pipe has the same area as a twin 58mm TB....
#110
smaller pipe will accelrate it not slow it down
theres actually a page on ttf.com that shows u how many fps the air will travel and with size pipe .
#111
Originally Posted by project89
smaller pipe will accelrate it...
#112
theres actually a page on ttf.com that shows u how many fps the air will travel and with size pipe....
#113
okay. I have a question because everyone seems to have a different answer, say you have a twin turbo setup and you are running 10psi on each turbo does that mean you are running 20psi of boost or is it still just 10psi? Another question do you need 2 boost gauges ? Im running mega squirt, bank to bank injection not sequential so should I still run 2 widebands or only one?
#114
No, 10 psi from each is 10 psi total. It does not add. Only the amount of air adds together.
No, you can run 1 boost gauge as its just taking signal from the plenum. If you wanted to get 2 and read the compressor outlet pressures, then you can do that but I rather see the pressure the motor sees as there is a drop thru the piping and thru the intercooler.
I run 1 wideband on my car but have ports on both banks to see whats happening on the other side if I need to. Just move the o2 sensor around alittle.
Not mentioned, but you can run 1 boost controller with 2 wastegates as well. Just plumb the signals into a T fitting to the controller. Works fine so far for me
#115
#117
okay. so you dont worry about one bank going lean or something happening and not knowing about it? I already have 2 widebands but the mega squirt can only read one bank at a time and I have to flip a switch to start reading the other side. I have someone that wants to buy one of my widebands and i just want to know if its really worth the extra 200 dollars to be able to read the other bank at the flip of a switch because i could really use that 200 for my waste gates.
#118
I check both banks every now and then, but theoretically, if one side is good in a batch system, the other side is good I also test header surface temps with laser temp gun but that doesnt always tell you much...does give an idea which cylinders are colder...I use it to detect idle misfires and such... I also check plugs when I can but its a PITA on my car so i rarely get to that.
#119
okay thanks that helps me out a lot.
#120
hey do you think 2 feet of 3/8 fuel line from the tank is big enough and then possibly go bigger after that hard line from the tank? What size line do you use? Because my plan is to use the stock sending unit, take the in tank fuel pump out and just use the feed, return and vent lines and use 1 in line fuel pump and filter. Then i have all auto meter gauges so I will try to use the stock fuel level sensor with the autometer gauge but im not sure if it will work
#121
I just got this 4 inch intercooler piping and it is hugeeee. I will fit no problem but it just seems like im going to lag. Should i still go with the 4 inch or just exchange it for 3 inch. I was planning on doing 3 inch from the turbos and then 4 inch to the intake. Now idk what i want to do because it doesnt seem like i should run 3 inch from the turbos and then have all that air squeeze into the same 3inch size pipe. Please someone help everything else is done this thing is ready to start im just stuck.
#122
these are some older pics but here are some.
#123
Well idk why but it wont let me post anymore pictures
#124
Car: 1991 Camaro Z28
I am getting another thirdgen this week of a buddy after not having one for the last 5 years. I have had a 3000gt vr4 and fell in love with turbo charged cars. He is offering me this car at a deal that i cant pass up and i will want to boost the car. seeing all your guys builds is ****ing inspiring. subcribing.
#125
Tell me about it I joust found a full hotside for twins for 100 bucks, another boosted third gen is in the works!!!
#126
Car: subaru wagon, two formula's
Engine: tpi 350's
Transmission: 700 r4
Axle/Gears: 3.27 posi
I know this is an older post, but I am doing a twin turbo setup on my formula 350 currently a solid 275hp TPI305 temporary motor till my 357 forged motor is done. I was going to buy this set that dumps the turbos towards the front right next to the serpentine belts, may have to remove the passenger side bracket for the serpentine setup in my 89, but I'll just run a shorter belt and barely get it on, by using a socket and ratcheting the alternator to get the belt on. What kind of manifolds are on this motor? Did they go far to the side of the head, then dumped towards the top? I was going to buy a similar kit for mine. Have you run the car at the track since this setup was finished? I'm very interested, thanks
Terrell351
06-13-2021 01:13 PM
