Procharger with EFI to carb
Old 04-24-2011, 01:05 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Hi,
After changing my mind yet again?! Im gonna run the D1SC procharger set-up. The only thing is that it came off a Camaro with EFI. I want to run it with a blowthrough carb set-up. Apart from the carb hat, does anyone know the difference in the kits? Can I just get the right stuff from Procharger easy enough?
Old 04-24-2011, 02:21 PM
daverr's Avatar
Re: Procharger with EFI to carb
EFI is the only way go with forced induction. You will have nothing but problems with a carb like flooding, bogging ,and simple weather change will throw it off. looking at your parts list why do you want to skimp on fuel delivery???
Old 04-25-2011, 09:02 AM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
this is not entirely true, a well tuned and prepped blow thru carb is as reliable as efi in nice weather.
Im sure the only difference between the two kits is the piping routing, as far at the actual supercharger it doesnt care if its efi or carb'd.
Old 04-25-2011, 09:49 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Ive been wondering the same. I have a P1SC that I bought for my LT1 and was wondering about using a carb wth the setup.
F.I. 57 Belair
08-23-2021 01:09 AM
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
customblackbird
10-01-2015 04:30 PM
skinny z
Carburetors
09-29-2015 11:25 PM
-=Z28=-
09-24-2015 10:21 AM
Quick Reply: Procharger with EFI to carb
