Setting base timing
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Setting base timing
How do you know what base timing, total timing to run on a boosted motor? I have a 390 SBC running an F1 Procharger and plan on running about 14-15 PSI of boost. I have a BTM box. How do I start to sort out timing?
I have not fired the motor yet. Once I get it to at least idle and run, I plan to drive it straight to the dyno and have them help me fine tune it. I just gotta get it out of my garage. The motor has an ATI fluid damper and a pro billet MSD dizzy.
Any help would be great. Thanks.
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Re: Setting base timing
Since no one with more experience has chimed in..... I would say if your just driving it to the dyno and taking it easy, I would just run some conservative timing and just try not to make much, if any boost on the way there. Something like 8-14 initial, and max of 25 should be fine for a trip across town. I would be more concerned with your A/F ratio not being to lean since it will bring on detonation real quick if it leans out.
1988, 88, base, camaro, charger, f1, procharged, procharger, recommendation, sbc, setting, settings, timing, z28
