paxton supercharged l98 build worth it??
Car: 88 camaro, 87 TA
Engine: 454 stock, built 468 400hp+150 shot
Transmission: WC t5, m29 t56 spec stg3 clutch
Axle/Gears: 9 bolt 2.77, 9 bolt 3.70
ok so a little more info here. i have a 1987 trans am gta l98 motor with a paxton sn93 supercharger on it. what i need to know is it going to be worth putting heads intake cam injectors ect.. plus a tune with that blower?? it runs fine right now makes about 5 lbs of boost but the blower could use a rebuild.(500) so what are you guys thinking?? just go turbo or stay with the blower??
im looking to make in the 550 range if possible with that blower but i just dont know lol...
just another thought i met a guy at summit the other who had a very similar setup in his irok. stock l98 bottom end with the trick flow aluminum heads slp blower cam and holley stealth ram, he said that the sn93 would on make 2 lbs of boost because the motor flowed so well, that was even with the underdrive pulleys and the modded impeller?? is that true??
let me know what ya think!!!!!
Re: paxton supercharged l98 build worth it??
Car: 1991 RS
Engine: 5.0
A few points:
1. Of course heads/cam/ injectors/tune is going to help. There will almost never be a situation where it doesn't. You asked one of the most basic questions of hotrodding and making horsepower. Your question would be like asking do slicks make a car hook better.
2. Your not going to get much help with that attitude. You have to allow some time for people to respond. Some times its almost instant, other times you have to wait.
3. If you think your blower needs a rebuild, go for it. No sense in upgrading everything else only to be handicapped by a less than optimal part.
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
It's a ok blower I have one but you will not make 550 HP with it does not flow high cfm but if you had a vr-4 it possible
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Fortunately, Thirdgen.Org offers a 150% full money back guarantee if you are not completely satisfied with the response and service of our automotive experts. That's right! Simply stop using our services and we'll send you back not only your original membership fee but an additional 50% of your paid fee just for your trouble!
well see the question was to put the money into the motor with that blower or just go turbo?? i understand all that i typed above would help but with that supercharger or just go to a turbo?
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Edit: Technically, you can in fact install a wastegate on the cold side (which of course is the only side a supercharger has), then run the highest rated pulley available, while adjusting the wastegate to keep desired boost pressure in check. It has been done before, but kind of noisy going that route, and I wouldn't recommend it. Good luck....
1991, blower, build, corvette, engine, l98, paxton, stock, supercharge, supercharged, supercharger, thirdgen, tune, tuning, turbo
