setting blow-off valve?
Old Mar 27, 2012 | 06:57 PM
BANDITSBC's Avatar
Car: 90 gta
Engine: 5.slow turbo
Transmission: tremec tko
Well I thought I was hearing my blowofff valve, but I think its coming out my airfilter.
Anyone have a good way to test/set a blow off valve?
Thanks in advance
Old Mar 27, 2012 | 08:08 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: setting blow-off valve?
the spring in the BOV should be just enough to keep it closed at idle (vacuum is trying to open it), then when you open the throttle blades and get out of max vacuum it will stay closed, but when you let off and the throttle blades snap shut the vacumm is back trying to open the BOV and the boost pressure in the charge pipe is just enough to help it open
Old Mar 27, 2012 | 08:36 PM
BANDITSBC's Avatar
Car: 90 gta
sounds good.. can I use a hand vac pump to test/set it?
Old Mar 27, 2012 | 10:26 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
hook a vacuum gauge up to where you plumb in your BOV reference (plenum...) and let the car idle, whatever it reads put the spring rated at that value in the BOV and your done. I suppose you can use the hand pump to test the BOV to make sure you have the correct spring but it's just as easy to check while the motor is idling
Old Mar 28, 2012 | 11:41 AM
Ronny's Avatar
POI.... you can borrow a VAC tester hand pump at Auto Zone no charge
Old Mar 28, 2012 | 12:08 PM
BANDITSBC's Avatar
Car: 90 gta
thanks,,, I work @ Autozone :-)
Old Mar 28, 2012 | 12:47 PM
Ronny's Avatar
Employees are not eligible for free stuff !
Old Mar 29, 2012 | 01:23 AM
BANDITSBC's Avatar
Car: 90 gta
Loaner tool!
Gonna set that tomorrow. Thanks for the help!
lakeffect2
Aug 23, 2015 08:44 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
89mulletbird
Aug 12, 2015 07:08 PM
