Supercharger CAM
Old Jun 18, 2012 | 06:06 PM
iroc90dfi's Avatar
Car: 1990 IROC-Z
Engine: 355 TPIS Mini Ram, Vortech R-Trim
Axle/Gears: 3.73 Strange S60
Supercharger CAM
Looking to get a new CAM for my project. I currently have a TPIS ZZ-9 cam with a Mini-Ram and Vortech R-Trim. I just got a new motor 355 whcih will have Brodix street heads and 700r4 with 3K stall. I need to add some gears, thinking 3.55 or 3.73. What cam are you guys running for your supercharged car?
Old Jun 18, 2012 | 06:56 PM
Twin_Turbo's Avatar
Re: Supercharger CAM
Latest build will have a TPIS ZZ-9x custom ground w/ wider LSA (114) setup very similar to yours (355, 195TFS, Mini Ram, D1SC)
Old Jun 18, 2012 | 10:57 PM
iroc90dfi's Avatar
Car: 1990 IROC-Z
Yeah I am thinking of just keeping it in the new setup, Just wanted to know if anyone had any other recommendation on what they are using. What convertor will you use or is it stick?
Old Jun 19, 2012 | 04:53 AM
Twin_Turbo's Avatar
9x!! not a 9, it's a cross breed between a zz409 and a zzx
2400 converter
Old Jul 28, 2012 | 07:46 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
the more compressor you have, the higher you plan on revving the engine, the tighter your LSA can be. Throw away that inlet charge, waste more fuel, but make more power and rev higher. The restriction to that statement is concerning a smaller exhaust housing. Too much overlap with a very small turbine is a bad idea just like too much overlap with too small of a compressor is a bad idea. Match everything. Big turbo? big exhaust housing? big exhaust plumbing? large intake manifold? big valves? low compression? big ports? Large turbocharger? Engine is good for 8,000rpm? Give me a large duration, with alot of overlap.
example would be a 355cid engine, 220cc runner heads, 8,500rpm solid camshaft 315*duration advertised roller cam 110LSA.
I would want a turbocharger(s) that can flow total about 135lb/min, because:
355x8500/3456*2.1*.069= 126lb/min
We are making 1000rwhp on pump gas now. A small 6x or 8x turbine is not going to give us that nice flat torque curve we desire at 8500rpm.
Old Jul 29, 2012 | 11:42 AM
iroc90dfi's Avatar
Car: 1990 IROC-Z
Thanks for the info
Old Jul 30, 2012 | 10:18 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Good info if talking turbo but he wants a supercharger.... if your goals arent too extreme, then just keep the zz9...its got a good bit of split and will work ok with boost.
Old Aug 1, 2012 | 10:33 PM
iroc90dfi's Avatar
Car: 1990 IROC-Z
Yes I think I will just keep the ZZ9 for now and see how it does. I can change it out later. Thanks
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
