is there a single turbo kit for the 350 tpi
i was thinking about adding a turbo to my motor but i need to know what the best set up is and how much boost i can run right now the car is all stock i just bought it a year ago and now have the money to start working on it
Car: currently 91 camaro
Engine: soon to be 350 turbo
Transmission: soon to be 4l80e
Axle/Gears: 99 ss rear end with richmond 4:11's
Re: is there a single turbo kit for the 350 tpi
ebay and research prices, put together what you want and start spending
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
you have 2 posts, both of which are from this thread, do a search and youll find plenty of answers.
Im not a big fan of the whole, "use the search bullshit answer" when you could simply guide him in the right direction but in this case "renegade2592", there is ALOT more than just a putting a turbo on these cars. And no there really are not kits, just parts from here and there. Look up a few posts on the power adder section and then get back to us with your questions. And please use the search if you have any questions, then if not found make a post.
NONE OF THE EBAY KITS WORK WELL. They require HUGE modifications to have clearance. This is just to save you money and aggravation of finding out the hard way. Good luck in your search. AND WELCOME TO THE BOARDS!!!!!!!
Car: 88 Iroc, 06 S4 V8 6mt :)
Engine: 305TPI almost boosted :P
Transmission: M5
IM USING THIS http://xs-power.com/gm-turbo-manifolds-3.htm
OTHER THAN THAT ALL PARTS ARE RELATIVELY UNIVERSAL. IE TURBOS INTERCOOLERS PIPING ETC.
Terrell351
Jun 13, 2021 01:13 PM
Sanjay
Aug 12, 2015 03:41 PM
