help me read these plugs
Old Sep 15, 2012 | 08:40 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
ok so these are my plugs 1-3-5-7 left to right. The wires are 5 years old MSD 8.5mm super conductors, the rotor/cap is 4 years old, and the coil is a 4 year old MSD blaster 2. The car was too hot to pull the other 4 plugs near the DP so this is all I have for now. I did burn a plug wire last month so the wire for #3 is brand new. Plugs are NGK-FR4
The car is making 5lbs of boost, afr's at WOT are 12.8, 32* timing and no detonation. I can't spin the tires in first, power is down across the board. the car can barely get out of it's own way
I have not read many plugs, but as far as I can tell #1 is rich (lots of carbon), #3 is about correct, #5 is a bit rich (lighter carbon), and #7 is ashy (oil or something burning?)
I am thinking new wires since the one new wire looks the best, and new plugs also. Would good spark on #3 and poor spark on the rest cause the plugs to look so different?
Old Sep 15, 2012 | 08:48 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: help me read these plugs
How old are those plugs?
And that just looks like a big gap but I guess your not up there on the boost so disregard that statment.
For the most part they just look pig rich(almost ready to fowl out) except the #3 but that ones close to it, that plug is what I would exspect to see if you were WOT then just shut if off to look at them, not at idle. But when did you take them out, after a WOT pull or just crusing or idling??
That last on on the right is definitly messed up. Detination?? Or too hot of a plug? And is that a hint of oil I see on the top threads??? Oil burning will cause ashes.
Are those a lower heat range plug then the stockers? Im use to ac delco numbers so I have no idea with NGK.
Old Sep 15, 2012 | 08:56 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
they are stock replacements, and have some miles on them my real concern is the differences between them - they are pretty useless for tuning. I'm hoping I'm having a spark delivery issue and not injector problems or something stupid. I am suspect of the intake gaskets as well... Just trying to get some opinions before I tear the thing down and spend money :haha:
They did run great on 5psi for 3 street pulls before the car stared having issues so they will work better than they are currently
and yeah there is oil on #7, thats part of the reason I'm suspect of the intake gaskets along with oil puddling on the intake and the crankcase getting pressurized
Old Sep 15, 2012 | 09:01 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Ahh i see, well Id say if you have a tester to do a compression test first, then if you suspect the intake gasket then check that out. But definitly get some fresh plugs on temp range colder and use them so you can sorta read them.
You dont wana see what just happend to my car a few weeks ago, found out today that the piston ring was broken, had blow by and oil slightly on the plug but this was very noticable after a WOT pull. Its been down since that last pull when it enevitably broke. Thankfully I didnt tear up the engine.
Old Sep 15, 2012 | 10:08 PM
one92rs's Avatar
Car: SOLD!!!!!
#1 plug is rich.
#2 plug is a little lean
#3 last plug is fuel/
sounds as though you have a couple other preobel,ms'
Old Sep 15, 2012 | 11:07 PM
DIGGLER's Avatar
looks like oil on the last one to me... not good with the boost.
Old Sep 15, 2012 | 11:37 PM
alex91z28's Avatar
Car: z28, g92, 5psi paxton,42lbs,eblp4
Engine: 5.7 .040bore,195cc trickflow,tpis
Transmission: 5spd
fuel injectors ok?. My cars plugs looked like that and was bad injectors.
Old Sep 15, 2012 | 11:39 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Originally Posted by DIGGLER
looks like oil on the last one to me... not good with the nitrous.
I agree oil is no good, but could hopefully be a simple fix if thats the issue. He doesnt have n20 does he??? I thought just the boost
Old Sep 15, 2012 | 11:50 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
just boost right now. injectors are brand new, hopefully they are not bad
Old Sep 15, 2012 | 11:57 PM
DIGGLER's Avatar
lmao pretend i didnt say that.
Old Sep 16, 2012 | 09:36 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
ok well since there is oil on #7, valve cover came off to do valve seals, and then I said screw it and tore the distributor out, intake off and thats as far as I got today. Since it's been deemed an issue beyond spark (oil) and I'm way further into the motor than just ignition components I'll throw the full details in my main build thread with pics.
but here is the cap and rotor - yikes!
Old Sep 16, 2012 | 09:57 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Aluminum // brass mix of rotor-to-cap
And // Or
Aluminum // brass mix plug-to-cap cause the erosion??
I've *heard* but not seen that a mix of brass & aluminum causes problems.
Just an uneducated thought
Old Sep 16, 2012 | 11:24 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
matching borg warner cap and rotor, cap is brass the rotor may be Al I'm not sure.
Old Sep 17, 2012 | 04:36 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Wow man, that cap is nasty looking.
Old Sep 17, 2012 | 08:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Those plugs aren't stock replacements for a '91 f-body SBC engine. If the stock iron heads are still on the engine they are the wrong spark plugs.
If the heads have been swapped out for aluminum ones then they are likely the correct form factor spark plug.
RBob.
Old Sep 17, 2012 | 09:12 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
yeah the cap is gross
heads are l98 AL heads, so the plugs should be the correct replacements. I'm going to try a step or two colder plug when i put the motor back togeter
Old Sep 17, 2012 | 02:50 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
heads are l98 AL heads, so the plugs should be the correct replacements. I'm going to try a step or two colder plug when i put the motor back together
Gotcha', y-body L98 heads. The plugs are OK then.
RBob.
Old Oct 5, 2012 | 04:29 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
I think you are running too much timing, at 5psi I would stick around 25* or less on 93 octane. Probably 23* i would start with.
Old Oct 6, 2012 | 10:27 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
thank you for a generic boosted small block timing value, but Al L98 heads require more timing than most, I'm 10* retarded from what I was running NA and am experiencing little to zero knock
eightsixseven
Dec 16, 2024 01:50 PM
LittleFranks
Sep 17, 2015 12:22 PM
Thornburg
Aug 30, 2015 08:05 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
BurlyChev
Aug 22, 2015 01:52 PM
