look at this plug
Old Sep 18, 2012 | 09:22 AM
Ronny's Avatar
look at this plug
[IMG][/IMG]
This is a Cham RCY10YC4. Cylinder #2. I pulled one plug last night. It is N20 plug one heat range colder. I placed in car about 4000 miles ago. I have sprayed about 6 times last season and was very rich. I jetted leaner for N20. Not used N20 this season as chasing a misfire that was determined to be cap rotor and now fouled plugs. I am EFI and run CL EBL.
The ground electrode appears gray with a builup of gray where it meets the body of plug. The porcelin is caked with a gray deposit on one side only (prob facing away from intake valve). Other side has a black trace from center electrode down porcelin. The center electrode is black. A black deposit encompasses the flat base of plug facing combustion chamber.
Is that oil fouled? When we pulled the prior plugs RCY12C my friend thought oil foulded on #2 only. Others OK. I did not see plugs at that time. I see no evidence of oil at exhaust at idle. Heads are Edelbrock with 40K miles. Engine has 122K on it original motor. Blowby? Suggest a leakdown test?
Old Sep 19, 2012 | 03:38 PM
Ronny's Avatar
Re: look at this plug
ttt
Old Sep 19, 2012 | 05:12 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Sure looks oil caked to me.
Old Sep 19, 2012 | 09:06 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
yes...definitely oil fouled.....either oil getting in thru the intake port or a bad valve seal or possible cracked piston rings..........best bet would be to do a cylinder leak down test.....should be no more than 10% of your highest compression reading of the other cylinders
Old Sep 20, 2012 | 10:49 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
I would reccomend not using a projected tip spark plugs in a nitrous application. Depending on the heat range i'd use NGK 5671a-7 -8 -9 -10 or -11. Until you find out the source of the oil I would not use the nitrous again. A leakdown or at least a compression check at the minimum should be done. It is quite possible that you valve guides are leaking once the car is shut off or the rings have just had it. Either way find the source of oil.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
