what a/r is best?
Old Sep 20, 2012 | 01:37 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
what a/r is best?
I need some help in what a/r exhaust housing is best to have on my turbo. Is there a certain way to find out?
Old Sep 20, 2012 | 01:48 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: what a/r is best?
setup details and goals?
Old Sep 20, 2012 | 04:31 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Stock 4.8 with a turbonetics t70 im thinking of doing 12 psi max. When i bought the turbo it came with an extra exhaust housing of 1.10 a/r so was wondering if its better also since it is coated
Old Sep 20, 2012 | 04:35 PM
project89's Avatar
what does it spool like ? 1.10 seems a lil large id be tempted to try a .8x housing
Old Sep 20, 2012 | 04:49 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Still havent ran it the turbo wont mount it hits my fender well so ima redo my piping. Just wanna make sure i put the one thats better. Don't know if im making much sense what im trying to say haha.
Old Sep 20, 2012 | 05:16 PM
project89's Avatar
just try it out and see how it spools , if its to laggy u know u need a smaller housing
Old Sep 20, 2012 | 05:23 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Oh ok. Have a questione would the size of the turbo do a big differance?
This is how the previous owner had the car but when i bought he didnt have the turbo anymore so i bought one and it wont fit into place.
Old Sep 20, 2012 | 06:32 PM
project89's Avatar
if the ex housing is what is hitting then going to a smaller housing will free up some room
Old Sep 20, 2012 | 06:42 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Yes its the exhaust housing hittin with the small one. So i was thinking of cuttin the pipe and welding it about 1inch closer for it could clear.
Old Sep 20, 2012 | 06:53 PM
project89's Avatar
the housinig in that picture only apears to be a t4 63 or 84, id contact the guy and see what housing he was using and just get the same one. much easier then cutting up the hotpipes and redoing them
Old Sep 20, 2012 | 07:35 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
He doesn't reply to my messages i been trying for about 3 weeks and no reply. Thats why i post i up here. Ima just redo the hotpipes sounds like the best way for less headaches.
Old Sep 20, 2012 | 07:40 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
well i looked through his old thread this is what he had
T76 .81AR Turbo : Godspeed Project
Description : T76 T4 GODZILLA T4 .80ar compressor .81ar turbine
FREAKING HUGE COMPRESSOR HOUSING , 1000 HP !!!!
(check out the picture with the turbo next to the soda can. you can imagine the size of this turbo charger.)
* Intake :3.95 inch
* Outlet: 2.5 inch
* Compressor trim: .80 ar
* Compressor Wheel diameter 76.80mm / 102.35mm
* Turbine Wheel diameter 72.78mm /64.20mm
* Exhaust trim: .81ar
* Turbine flange type: t4 flange
* Downpipe flange type : 3 inch v band flange
* Cooling type: oil cooled only
* Horsepower rating: 1000+ hp
customblackbird
Oct 1, 2015 04:30 PM
WannaBeFast
Jul 4, 2008 06:05 AM
DAVECS1
Jan 1, 2007 09:22 AM
junkcltr
Mar 1, 2006 11:14 PM
junkcltr
Nov 14, 2005 11:43 PM
