Turbo vs. Super, suggestions?
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Hello! I plan on putting a 350 in my car soon, but I want it to go really fast. I want to supercharge, or turbocharge it, thing is its a carbureted engine(car was swapped to carb. so no electronics needed for fuel injection). Should I add a super or turbo? I don't want to waste much gas, but I want to get that awesome horsepower. I need ideas!
Thanks.
Thanks.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Turbo vs. Super, suggestions?
How much horsepower are you shooting for, and how high are you planning to spin the engine?
Engine: 305 5.0L
Honestly, i just always wanted a charged 350, and now i have the money to do it, i don't know a ton about them, i just need suggestions, im having a mechanic do the work.
If your going to run cast parts, go with a supercharger. Not that a turbo won't last with cast parts, but you don't need the added headache of the heat being generated from the turbo creating higher air temps, not to mention the wastegate and oil line plumbing which can be a pita. A D1SC Procharger is the way to go, just get your hands on the right boost referenced carb, fuel pump and pay careful attention to your cam specs...
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
If you asked me Use Both. Superchargers don't work well at High RPMs and Turbos Don't Work Well at Low RPMs (Turbo Lag) so why not use Both?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Compression of air naturally adds heat. Turbo just is hot to begin with so some heat transfer to air charge but they all have heat.
Dont want to waste gas but want to make hp to go fast. Those dont really go together. Lol
How fast is fast? Heads cam build will be cheaper and 500 hp capable
Car: 89 Iroc-z
Transmission: TH400
To a point. Depends on how big and how good a cooler you use as well as type... Air to air water to air, etc. its just that a turbo is already at 300-400 deg surface temps from being exposed to heat radiation from turbo exhaust housing. That does have some effect on the incoming air that gets compressed. Small amount of additional heat transfer heating of air charge but air is in and out very fast so hard to say how much a hot compressor housing affects air.
Intercooler is always a good idea. Low boost, can use an fmu to get fuel but 2 bar map conversion is proper way to fuel it. Most blower kits come with fmu's
Car: 89 Iroc-z
Transmission: TH400
Fuel Management Unit. Runs boost pressure thru it and it increases fuel pressure a certain ratio, like 6 to 1 or whatever to increase fuel sprayed thru the injectors. Its band aid tuning at its finest
say you run 5 psi, you will see 30 psi of fuel pressure increase if its 6 to 1 ratio. This is hard on the fuel pump and fuel system in general. Most injectors seem to be ok with up to 80 psi or so running through them but I have seen vids of higher pressures causing erratic spray patterns and such. Not what you want for ideal fuel control.
For lower boost pressures and lower HP levels, they do work ok. I just dont like them as much as a 2-3 bar Map sensor tune or even MAF based setups that can read that much air.
say you run 5 psi, you will see 30 psi of fuel pressure increase if its 6 to 1 ratio. This is hard on the fuel pump and fuel system in general. Most injectors seem to be ok with up to 80 psi or so running through them but I have seen vids of higher pressures causing erratic spray patterns and such. Not what you want for ideal fuel control.For lower boost pressures and lower HP levels, they do work ok. I just dont like them as much as a 2-3 bar Map sensor tune or even MAF based setups that can read that much air.
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Thanks.
Thanks.
Blow thru = carburated super/turbo engines.
Alot of good basic info and tech related to blow thru at
theturboforums/turbomustangs.com
Engine: 305 5.0L
I'm kind of stuck :\ where do i find the right turbo kits at? i'm not too sure about the ones i find?
Car: 89 Iroc-z
Transmission: TH400
You wont find any. No one makes a bolt in kit anymore. You have to fab yourself or pay a shop to do it
Car: 89 Iroc-z
Transmission: TH400
Turbos are cheaper if you do it yourself. Blower kits these days with intercoolers are pricey. Looks like 5-7 grand for some?
Car: 82 Z28
Engine: broke SBC
Transmission: 700R4, 2800-3000 stall
Axle/Gears: 7.5...,4.11..till it explodes
You would think that someone would have come up with a off the shelf header/manifold setup for twins that fit our car's by now. A Lot of us could proceed from there.
Car: 89 Iroc-z
Transmission: TH400
Well stainless works has headers that face forward but you'd have to do alot of work from there and they are pricey at 900 or so
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
I'd fabricate some headers. Like Christanz28 said surprised
There's like no company out there that already has em made.other
The stainless steel works
Car: 89 Iroc-z
Transmission: TH400
Bbs designs used to and said they were gonna make more but idk if there was enough interest in that product.
Makes me wonder how realistic the market is, as you see alot of people looking for turbo advice and and wanting headers, yet never see a finished build thread.
Originally Posted by nowerelsetoroam
Hell I was thinking once I get some welding school finished, I wana fab up a couple for the hell of it...
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
Maybe you can.make.me some!
Car: 85 camaro
Engine: 5.7
Transmission: th400
Axle/Gears: 4.10
Is that what you used? A harbor freight welder?
I've amways wanted one.to.make the set up but was always
Thinking no way could a harbor freight flux core welder do.what I want
I've amways wanted one.to.make the set up but was always Thinking no way could a harbor freight flux core welder do.what I want
Car: 89 Iroc-z
Transmission: TH400
Using a lincoln flux core setup you can buy at home depot or lowes for like 450$, did all my exhaust work, turbo manifold work, subframe connectors and various other general welding tasks
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
