Turbo Timing
Old Apr 21, 2013 | 03:41 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Turbo Timing
Just curious on what everyone does for timing before i start cranking in the boost. At the moment i have just a plain old hei Dizzy and im assuming the vac advance isnt going to help me so what should i get instead? Have had a few people say just to get the MSD BTM and call it quits but like I said id like to see what everyone else says as well. Plan is 10-15 psi on a 355 running the professional products Power injection system.
Old Apr 25, 2013 | 10:35 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Re: Turbo Timing
need to know:
1. turbocharger size
2. engine compression ratio
3. engine material (aluminum/iron head/block)
4. tuning experience
5. vehicle weight
6. EGT sensor location / wideband sensor location
7. intercooler design, plumbing length/path
8. Fuel injection type: mpfi/tbi/sequential
Old Apr 25, 2013 | 12:09 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo Timing
turbos will be 57mm t3/4 hybrids comp will be right around 8:5:1. iron block iron heads. As far as tuning the the professional products system. Not very much on this system. Its a self learning Tbi system and once you get the basic fuel curve you can play with it. Wideband is maybe a foot off on one of the turbos or directly after y pipe depends on how i run my exhaust. As the plan sits turbos by the bat. boxes and piping directly routed through the metal there and to the intercooler. Once i find one.
Old Apr 25, 2013 | 03:46 PM
project89's Avatar
Re: Turbo Timing
ebay turbos i take it ?
sounds very similiar to the 355 tt engine in my iroc
355 shortblock with ported 882 heads and tpi system 9.2-1 cr
21* total timing from 5-12 psi
20* total from 13-16 psi
19* total from 17-19 psi
18* total from 20-23 psi
engine lives on (91) pump gas with a larger intercooler just fine
Old Apr 26, 2013 | 09:54 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo Timing
How did you do the timing? Should i use a box or can i get my Hei Dizzy to work out well?
Old Apr 26, 2013 | 11:25 AM
project89's Avatar
Re: Turbo Timing
i use a megasquirt ecm which controls fuel and timing
im not sure about the system u are using does it do ignition control? if not u need to get the programable msd box or something
Old Apr 26, 2013 | 12:26 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Turbo Timing
Sounds like fueling only and no spark control. Would need a boost referenced spark retard system then
Old Apr 26, 2013 | 12:27 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo Timing
Nope just does the fuel end. Looks like ill be in the market for that msd btm then. Unless there's another box I can run? Anyone know wnything abot the btms?
Old Apr 26, 2013 | 12:36 PM
project89's Avatar
Re: Turbo Timing
u dont want a btm u want the programable box, i just cant htink of the part number off the top of my head
edit i think this is the box u want
MSD Digital Programmable 6AL-2
Part No. 6530
Old Apr 26, 2013 | 12:38 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Turbo Timing
I ran a mallory 685 ignition box on my car and its for sale lol. It has boost referenced timing retard, set to pull whatever degs of timing per psi boost you want. Also has loads of other features like rev limiters window switches and other timing retard functions
I havent used the boost timing but did use every other feature for nitrous controlls
Old Apr 26, 2013 | 02:30 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo Timing
Just as long as it works with my dizzy now that would be great. Ill take a look when I get on the pc instead of my phone
Old Apr 26, 2013 | 03:14 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo Timing
Out of the two what would be better? As far as the 6al 2 looks good just would need to get my timing right the first few times around or detonation could be a problem
Old Apr 26, 2013 | 03:38 PM
project89's Avatar
Re: Turbo Timing
im not familiar with the mallory box but the msd u program the entire timing curve into it
if the mallory is the same thing and not just a boost retard then its upto u because both are good brands
Old Apr 26, 2013 | 06:41 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: Turbo Timing
Question is. Would \ coulda ya help me with the timing curve? I'm kinda new to the fuel injection and programing timing lol
Terrell351
Jun 13, 2021 01:13 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
camaro71633
Sep 1, 2015 10:24 AM
PestilenceIV
Aug 20, 2015 03:32 PM
86White_T/A305
Aug 17, 2015 12:16 AM
