Paxton Added to my 5.0 tpi
Car: 89 Firebird Formula
Engine: 383 tpi vortec heads Xr 269 cam
Hi , I just finished completing the install of my Paxton SN 2000 and devils own water meth/injection kit. Picture is before all gear clamps, injection and belt installed. Total install only took about 60hrs
I had to fab a lot of parts and I am a little slow
Everything seems to be working fine. No strange noises squeaks, rattles etc. Thanks Ed the SC you sold me seems to be working fine. I haven't measured actual boost at WOT but I can definitely feel a huge difference
I wondering what upgrades I should consider next since money is tight
Right now I have
Stock 305 tpi
Paxton SN2000
Devils Own Meth /Water injection
my upgrades in order of preference
Catback- what size? 3 or 3.5" or true dual- where does O2 sensor - I guess cross pipe is needed
Headers
Larger injectors 27# and inline fuel pump
Any suggestions /comments would be appreciated
I had to fab a lot of parts and I am a little slowEverything seems to be working fine. No strange noises squeaks, rattles etc. Thanks Ed the SC you sold me seems to be working fine. I haven't measured actual boost at WOT but I can definitely feel a huge difference
Right now I have
Stock 305 tpi
Paxton SN2000
Headers
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Paxton Added to my 5.0 tpi
Originally Posted by toronto formula
Suggestions. Anyone...
http://dynamicefi.com/EBL_P4_Flash.php
From a hp perspective do you think a tune will give me more hp than catback and headers
The car seems to running well no predetonation,good rpm at idle, etc
Car: '88 Trans Am GTA
What are you using to compensate for boost? Or did you just install the supercharger and meth injection and made no other changes?
From a hp perspective do you think a tune will give me more hp than catback and headers...
The car seems to running well no predetonation,good rpm at idle, etc...
Lb9
I have not done anything to compensate for boost other than water/meth injection reduce air temp and increase octane rating
I have a Paxton btd but have not installed
Street letHal I am asking for suggestions/ideas. I am not challenging your ideas but asking questions to get more knowledge. Not sure why your. Response ends with the attitude
Street letHal I am asking for suggestions/ideas. I am not challenging your ideas but asking questions to get more knowledge. Not sure why your. Response ends with the attitude...
This is what I was getting at, and there was no attitude on my part...
Ok thanks
You are right I am using stock maf and stock ecm. To be be quite honest I have no idea what parameters should be adjusted for the tune. I am a little worried to have my car tuned by someone and potentially makes things worse. If I change the eprom or ecm will the tuner what specific parameters needs to be changed based on my app?
Thanks for your feedback I do appreciate any support I can get
Ok thanks
Most commonly used is an FMU. A vacuum line runs to it, it then increases the fuel pressure as boost goes up thereby increasing fuel flow thru the injectors.
Please start reading up on tuning for boost before you go full throttle.
And don't take offense from any posters being blunt.....they're tryin to save you a new engine!
Does anyone know who can provide a good tune in. Southern Ontario?
Also is the EBL P4 and 7730 ECM the best based on experience of everyone on this board ?
Car: check
Engine: check
Transmission: check
From your pic there appears to be a MAF installed. See this link in Street Lethal's thread for more info:
https://www.thirdgen.org/forums/post...3-post180.html
RBob.
RBob.
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i'm running the sn92 with 6psi and water/meth injection I run the stock computer and Maf but I run an external pump with boost reference regulator for more fuel psi and haven't had any problems with it I also have 36 psi injectors
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
Also, the Paxtons didn't come with any other supplemental fuel delivery. SN89s, 92s, 93s and 2000s only came with the meth injection. The kits didn't come with a FMU. I have 3 installation manuals, and none of them even mention the fuel delivery. Paxton did have a MSD BTM as an additional cost option. You could also buy The PaxtaMap Fueler, which had a separate computer and 3 fuel injectors that mounted between the throttle body and the plenum.
Car: A few things lol
Engine: 350 tpi supercharged and a 383 stro
Transmission: Both 700r4s
Axle/Gears: 3.23s and 3.54s
The intake you make to grab air from the blower looks cool where did you get the tube to make that???
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Buy a wideband 02 sensor and check your AFR at WOT before changing anything else.
Clean looking install. I like it a lot.
After that, I would make sure your tune is right and add headers!
The intake pipes are 3 in mandrel bend and straights from siliconintakes.com .
Does anybody know anyone who can tune in the Toronto area?? My only other option is a five hour round trip to Buffalo.
From what I've heard Champion Motors is the best in Toronto for tuning the 24x (LS1). No idea how well they tune other computers. I spoke to them about how I wanted to turbo my TPI and they suggested a 24x conversion. I also recently spoke to the guys at a new shop in Scarborough, Authentic Performance and they suggested a self learning engine management system from AEM. I'll be getting a baseline on their dyno Friday afternoon if you want to check the place out and hear a stock 5.0 make a little noise. Aside from that no one really tunes TPIs in Toronto.
Car: 1989 GTA
Engine: 5.7 w/Paxton
Have you thought about getting the Paxton Installation manual and reading through it? There are a few good things in there about the very things you are asking about. PM me might be able to help with one.
Iroc8t8
May 4, 2026 08:09 PM
colton_carlson
Mar 8, 2019 12:21 PM
toronto formula
Nov 10, 2015 06:17 AM
Sanjay
Aug 12, 2015 03:41 PM
