Blow through 5.3 turbo questions.
Old Jul 23, 2013 | 11:31 PM
Frqnkie's Avatar
Car: 1985 IROC.
Engine: LQ9.
Transmission: TH 350 with Hughes 3500 stall.
Axle/Gears: Moser Axles and 4.10 gear.
I had a few questions about the setup that I'm building for my 85 IROC. It's a blow through 5.3 LM7 with a 76mm On3 turbo, Brian Tooley spec'd cam, springs, pushrods, and ARP rodbolts and head bolts.
1. How do you control boost with a carbureted setup?
2. Is 3 inch piping too big for my setup? And can the intercooler be too big?
3. Can you control boost with an MSD 6LS box? I know you can set a boost timing map, but I was wondering if you can actually control the boost with it.
It may be some stupid questions to some people, but I've never messed with anything boosted before, and you've gotta ask to learn.
Old Jul 24, 2013 | 09:30 AM
Frqnkie's Avatar
Car: 1985 IROC.
Engine: LQ9.
Re: Blow through 5.3 turbo questions.
Somebody at least tell me they were stupid questions or something! lol.
I just need some kind of feedback.
Old Jul 24, 2013 | 09:38 AM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
You control boost with a waste gate and a boost controller
Old Jul 24, 2013 | 01:02 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
ANS: Wastegate valve dumps extra exhaust bypassing turbine. Controlled by intake pressure and spring in wastegate
No and No
No. See answer 1
Why the On3 turbo instead of Borg Warner S400CW75 ?
Old Jul 25, 2013 | 12:41 AM
Frqnkie's Avatar
Car: 1985 IROC.
Engine: LQ9.
On3 because of the major price difference. I was just wondering how the boost controller wires up to a carbed car?
Old Jul 25, 2013 | 12:59 AM
You have alot of research to do before you can start.
Here you go:
http://lmgtfy.com/?q=how+to+install+...controller&l=1
http://lmgtfy.com/?q=how+to+install+a+boost+controller
Old Jul 25, 2013 | 08:38 AM
junkcltr's Avatar
Engine: 3xx ci tubo
What is the cost of the On3 76mm?
Are you talking about controlling boost max PSI, or boost spark timing?
Boost Max PSI is "normally" controlled all mechanically using a wastegate. There are no wires. Just some exhaust pipe and some intake silicone rubber lines. Look up turbo wastegate. It is just a valve that is in parrallel of the turbine to bypass the exhaust going through the turbine. The valve is controlled mechanically by a spring and diagram sensing intake pressure (boost). BUT you can get fancy with an electronic wastegate controller if you want.
Old Jul 30, 2013 | 12:35 PM
Frqnkie's Avatar
Car: 1985 IROC.
Engine: LQ9.
On3 76mm is 340 shipped to your door brand new.
ZZ3Astro
Aug 13, 2019 12:57 AM
cheesehomer
Dec 31, 2015 08:48 AM
customblackbird
Oct 1, 2015 04:30 PM
meeklay812
Oct 1, 2015 03:46 PM
raymondandretti
Sep 27, 2015 06:43 PM
