Single turbo build 350
Old Jun 21, 2013 | 09:16 PM
b_the_j's Avatar
Car: 92 RS
So...I have reading the boards for years now wondering if i can pull off a mild build. So lets start with what I have to work with.
A Precision 6031e housing 64mm inlet .63A/R
Some rectangular tubing .25 wall 1.5x3
A set of stock 350 manifolds that i will notch out as I saw in another thread
Plenty of flat steel and angle iron to make flanges/braces etc
A cheap single in single out intercooler
A cheap wastegate and bov
I have a 80k mile tpi 350 with siamese runners, billet 24# injectors, and bbk throttlebody just laying around taking space so I might as well use it
My question at the moment is...Is the turbo even close to the size i need for a 350? I still had a 305 in the car when i bought it and i wondered if it was kinda small then. 305 now resides in a 88 4x4 yota
[IMG][/IMG]
Old Jun 23, 2013 | 12:57 PM
b_the_j's Avatar
Car: 92 RS
Re: Single turbo build 350
I'm not sure why that pic isn't working
I made some progress cleaning the garage and I took a bunch of stuff to storage(I really need to start selling stuff) and brought home some manifolds. I'm entertaining the idea of cutting a hole in the wall for a window unit a/c.
Can anyone help me find a compressor map for that turbo...I wish I could find another one they would be perfect twins.
Anyone opinions on these, they are for a vette I guess
http://www.ebay.com/itm/280940286115...84.m1438.l2649
Old Jun 23, 2013 | 01:09 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I had those headers once, they are fine, just have an exhaust shop redo the crossover if you plan on running over 15-psi because they crack due to being as thin as a potato chip. Must have welded my old ones twenty freaking times. I'll be following this build...
Old Jun 23, 2013 | 01:26 PM
b_the_j's Avatar
Car: 92 RS
do you have any pictures of these installed?
Old Jun 23, 2013 | 01:29 PM
Not of mine installed, but I think I still have a picture on photobucket somewhere of these installed in a carbed setup. Hold on, let me see if I can find it, I will edit this post and add it to it when and if I find it, k...
These were my set in the meantime...
Old Jun 23, 2013 | 01:39 PM
Here you go...
Old Jun 23, 2013 | 01:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Its small for a 350. Depending on power goals but i dont like the tiny a/r for a single. It would spool quick tho but run out of steam up top and have higher backpressures. Turbine probably alittle small to although i didnt find complete specs. Just that its a 59mm comp they say not 64. Unless you got something different or thats the turbine size.
350-400 whp should be good with that but would be turning it hard at 400 hp
Old Jun 23, 2013 | 02:56 PM
b_the_j's Avatar
Car: 92 RS
Thanks guys... I think I will stick with my homemade manifold idea...I can't stand the idea of buying stuff lol... as far 3-4hundred horse that is plenty for me at this point, the goal of this build is mostly just to break the learning curve and build a fun street car on a budget. I would look to keep the boost conservative at this point and work within the limits of the injectors that I currently have, then when I get bored with that, the all out build can commence.
Old Jun 23, 2013 | 03:16 PM
Let's see what ya got to work with...
Old Jun 23, 2013 | 05:04 PM
b_the_j's Avatar
Car: 92 RS
[IMG][/IMG]
Old Jun 23, 2013 | 09:25 PM
b_the_j's Avatar
Car: 92 RS
alt mounted to air pump location...the p/s bracket was busted off in the crash so I have to get a new one if if want to return the alt to stock location
[IMG][/IMG]
Not much progress yet but I have been thinking about putting the turbo on the driverside... I had already moved my altenator to the a/c compressors location and cut the top of the p/s bracket down. I have been entertaining the idea of putting ac back in the car. i remember see a pic of an alt hangin where the air pump goes, so I decided to try that out. I tried a search for a thread on this but was unsuccessful.
Looks like it will work just need to shim the pulley out about an 1/8th of an inch .
Old Jun 24, 2013 | 07:10 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Just buy the biggest wastegate you can afford lol 44-50 mm i'd say to accurately control boost on that small hotside
Old Jul 30, 2013 | 10:05 PM
b_the_j's Avatar
Car: 92 RS
[IMG][/IMG]
Progress update.... engine and trans out, wire harness, brake booster, strut caps etc out. Started cleaning things up for paint. Got some rust repair to muddle through before i can start spraying.
I'm getting discouraged a little about using this turbo, thinkin about selling all my small block stuff and going lsx... at least i got some work done finally, either way
Old Jul 31, 2013 | 04:17 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Well you do have a blank slate to work with now lol! Guess you just have to ask yourself how much work your willing to put into this...
I have a question for you about the alternator relocation, how much work was involved to put it into that location? Looks like it just plugs right in.
Old Jul 31, 2013 | 03:22 PM
b_the_j's Avatar
Car: 92 RS
yeah tony I'm not sure if the alt will work there definitely would require an idler pulley somewhere. basically i just elongated the hole and clearanced the bracket for the fan but it also sits back about a 16th or 1/8th out of line with the belt. so i abandoned that...i got the idea from another thread not sure if that guy was successful. I did work out a system using stock brackets to delete a/c and smog without idlers if you are interested i can describe it to ya. I want a/c on the car now so maybe I'll sell ya mine
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
lt1z350
Aug 28, 2015 05:57 AM
crazynights
Aug 21, 2015 06:53 AM
