ZZ3 Turbo Iroc - Round Three
Old Jan 22, 2014 | 05:23 AM
  #301
project89's Avatar
Re: ZZ3 Turbo Iroc - Round Three
Originally Posted by ZZ3Astro
Project89 there is one other major issue with those heads.. my headers are D port and that limits me to older AFR's and current Trickflows for the most part.
as long as it will seal up on the port it shouldnt be an issue
sound slike u should be up and ready to do some testing soon
Old Jan 22, 2014 | 07:35 AM
  #302
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I would hope the turbo isnt goin bad already. That thing is fairly new right?
Old Jan 22, 2014 | 02:14 PM
  #303
project89's Avatar
pull the compressor and turbine housings and check for contact between the blades and hosings , thats usually the only time a turbo will squeal
Old Jan 22, 2014 | 09:33 PM
  #304
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
gone
Old Jan 23, 2014 | 08:15 AM
  #305
DIGGLER's Avatar
man your killin me..... that gave me a headache from 2 states away.
Old Jan 23, 2014 | 02:46 PM
  #306
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I read this thread every time there is an update hoping and praying you get it figured out. I would really hate to see you give up on such a nice, strong car, but seriously it is fighting you every step of the way and now Mother Nature herself is after you. Good luck, my thoughts are you need to take a couple month hiatus from the car.
Old Jan 23, 2014 | 03:08 PM
  #307
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Dont feel to bad man, my car just stopped working over night. Ran fine on a saturday night, parked it and sunday afternoon wouldnt fire. Hasnt even coughed. Found a lose crank sensor but fixed it and not the issue. Never seen something happen overnight when i never touched it. Cars are funny creatures
Old Jan 23, 2014 | 04:27 PM
  #308
DIGGLER's Avatar
my ls1 car recently started randomly missing/sputtering and cutting off/not restarting. i looked over everything and the only thing i found was a green/corroded pin in the pcm connector. its one of the pins bringing 12v to the pcm. might be something to check.
Old Jan 23, 2014 | 04:52 PM
  #309
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Mine dont make a sound trying to start. Its like its not even trying to fire plugs. Ecm was just repinned this year and clean. But will check and not rule that out
Old Jan 23, 2014 | 10:03 PM
  #310
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Jan 24, 2014 | 07:53 AM
  #311
project89's Avatar
how old is the 02 sensor it might just be time for a new one
Old Jan 24, 2014 | 08:16 AM
  #312
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
X2. That or controller is bad
Old Jan 24, 2014 | 02:36 PM
  #313
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Do what makes you happen man. I can certainly relate, my new house is on a canal with a boat hangin behind it, and I have a turbo thirdgen that costs time and money and isn't where I want it to be yet! I have discovered that the boat is more enjoyable since it's harder to have girls in bikinis and beer in a camaro than in a boat . I just tuck the camaro away in a shop and live life, when winter rolls around or I see a bad *** car on the road I head up to the shop, or order some parts and work on the camaro for a week or two until I'm fed up then I go back to living life and trying to make some extra scratch. If you can swing the shop $$ that's the way to go, carry some insurace on the shop (or just the car!) and enjoy it. Dont change the way you live because your worried about what someone else might do. Plus, if the car get stolen, buy a C7-Z06 and forget about the iroc AND: slap a new WBO2 in there, rebuild or replace that turbo if it needs it, and drive the wheels off that thing! It's got some scratches now, time to enjoy it!
Old Jan 24, 2014 | 09:24 PM
  #314
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Jan 25, 2014 | 07:11 AM
  #315
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yep boats do have their good points (and bad!). I just like the escape. Even when work finds me on my phone while aboard it is still nice to get off the land for a while.
Whatever happens with the Iroc and a possible replacement, I certainly won't be buying anything for a while. A lot of things have to be sorted out. I figure by summer something major could change.
Tomorrow I will try to get that WBO2 sensor swapped if the plug fits. After I get that fixed it is probably the transmission or rear that will put up a fight.
My boat has been sitting on the trailer for years. Every year I say I'm going to take it out.
The horses haven't been ridden in almost two years. The car has been in the garage for two years. About the only thing I ever use these days is the motorcycle. Growing up is tough.
-- Joe
Old Jan 25, 2014 | 06:37 PM
  #316
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Jan 25, 2014 | 08:42 PM
  #317
DIGGLER's Avatar
if you decide to sell it i may be interested....?
Old Jan 26, 2014 | 12:36 AM
  #318
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Ouch I feel for you, I imaging the head gasket is blown now.
Old Jan 26, 2014 | 07:51 AM
  #319
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
All I can say is %@##@!!!!&#^#&&&%$%$
It is a damn good thing I installed the other O2 sensor because it just LEANED OUT AGAIN at 15 PSI.. it went to 17:1. Now it's pissing coolant out of the overflow. It was perfectly fine for a solid hour of driving and thrashing until I stopped by a friend's house. He took it around the block to show it to another person there.. It came back shooting water out of the overflow so I took it and yet another person there for a ride to see what it was up to. It felt flat at 15 psi so I watched the AFR on the second takeoff. We both said "17!!!" at the same time. Fueling is perfectly fine at 11 psi, which I kept it at on the third takeoff.
Done with this thing. I'm sick of it.
So I've been reading this and following best I can, but it's gone over a million different things.
The outstanding problem right now is that your leaning out under boost, and we think it's due to a fuel flow issue?
I know pumps have been discussed, amperage, fuses, bade o2 sensors, etc.. What's the current theory ?
-- Joe
Old Jan 26, 2014 | 08:05 AM
  #320
project89's Avatar
-- Joe
hes changed the feed and return line with no change, i know he talked about swapping in the walboros he has not sure if he did
if he didnt swap pumps , i still vote pump, or voltage drop issue
i still wouldnt rule out an injector issue though
if fuel presure is droping its more then likley a pump issue
like i said before ive had 2 340lph pumps go bad on me first one was my fault , second went to crap after a few days
Old Jan 26, 2014 | 08:18 AM
  #321
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
That would be pretty easy to figure out, get an electronic FP sender and wire it to a spare input on the megasquirt and log fuel pressure.
Astro: Can you post or email me your log and msq file?
-- Joe
Old Jan 26, 2014 | 08:31 AM
  #322
project89's Avatar
-- Joe
he had a mechanical presure gauge installed before
Old Jan 26, 2014 | 09:14 AM
  #323
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Jan 26, 2014 | 10:21 AM
  #324
project89's Avatar
About the return line. My friend's theory is that the pump is overheating due to the restriction caused by the factory return line. This explains why the problem occurs even after just cruising for an hour. I put a maybe on this. It should be something an amp meter would indicate by comparing engine off fuel pump running with the return line hooked up and then repeating with the return line going into a bucket. Any significant reduction in current would prove his theory.
Thoughts?
it could work for testing , why didnt u reuse the factory feed as the new return though?
when testing pinch off the return line to deadhead the pump and see what voltage/amperage does as well
Old Jan 26, 2014 | 10:30 AM
  #325
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Jan 26, 2014 | 06:23 PM
  #326
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Jan 26, 2014 | 06:48 PM
  #327
86'sportcoupe's Avatar
Car: '86 Sport Coupe
Engine: 310"
Axle/Gears: Stock 10 bolt. 2.73's
Diggler that may well be an option. I drove it today and while it is not overheating, it is getting tons of pressure in the radiator and pissing out of the overflow. Finally paying the price for the lean runs. It's really handled it well up to this point.
The only way I will keep this car and move forward now is if my friend who runs a shop offers to do it for free. I'm not going to put any more money into it. Knowing him he will tell me to just bring it and he will figure it out.
It is obvious that for me this car is cursed. For someone else it will be a blessing. I've already done all of the hard work. Someone wil pick it up for a steal, throw $2-3k into it and have it running 6's reliably.
If no one wants it as it is I am going to have the stock engine put back in and sell off the headers etc.
I think this video last night I made sums it up... and at that point I didn't know the head gaskets or whatever were shot:
Hitler finds out the Iroc upgrades failed to resolve the issues - YouTube
Man Id hate to see it go, I would keep at it, my car is as cursed as can be, it has taken 2 years to get it almost right, if you keep at it it will start treating you right eventually
Old Jan 26, 2014 | 08:04 PM
  #328
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
It was all worth it to make that video!
Old Jan 27, 2014 | 05:07 AM
  #329
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
How is the fuel tank vented ?
-- Joe
Old Jan 27, 2014 | 11:35 AM
  #330
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I think all of us think our cars are cursed at some point.
Old Jan 28, 2014 | 07:05 AM
  #331
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Let the car sit for awhile and let the bad memories go away. Sometimes coming back to it after a while will jog your memory and you will fix or remember what you forgot to do the first time around.
Old Jan 28, 2014 | 05:46 PM
  #332
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
I vote keep it.
I called my turbo regal "The Bad Luck Buick" but I miss having that car.
If anything take a break since you have other irons in the fire, or something like that lol
Old Jan 29, 2014 | 12:40 AM
  #333
Tony89GTA's Avatar
Car: 89 GTA
This has always worked for me, when my brother blew both head gaskets I didn't touch the thing for 2 years... Surprisingly I'm still using the same stock block after scraping all the built up crud off the cylinder walls lol. Good luck either way on your decision.
Old Jan 29, 2014 | 10:27 AM
  #334
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Jan 29, 2014 | 11:06 AM
  #335
DIGGLER's Avatar
need a good vent setup on there for sure. build yourself a good fuel system from all angles, 100% legit good to go. big feed line, big return, no problems inside the tank, no problems inside of the rail, make sure injectors are all good, good regulator..... and then move on to the next questionable item.
Old Jan 29, 2014 | 05:00 PM
  #336
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I would try a different fuel pump before I shipped it at a minimum since you have recorded the fuel pressure acting up in an odd way. Did you ever notice anything in the tank that could slosh and block the pump screen?
Old Jan 29, 2014 | 06:31 PM
  #337
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Between a troublesome thirdgen and a GTR, i would go GTR
Old Jan 29, 2014 | 06:54 PM
  #338
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Jan 29, 2014 | 09:15 PM
  #339
Drac0nic's Avatar
One of my problems is I have a hard time walking away from an issue. I want to fight it and beat it. It comes from my IT background where sometimes you have no choice but to win. But when the car starts interfering with my work schedule then it is time to make a change. The way I see it, right now I have more cash than I have time. That's why I am looking at something new and reliable. The only things that go as fast as I want to be cost a lot, but so does troubleshooting Iroc and replacing fuel systems over and over.
You have my sympathies on this, being in IT I can totally appreciate where you're coming from. Out of all the things in the world I despise, perhaps one of the biggest is letting a machine beat me. Besides this the time nature due to you trying to sell your house adds an element of urgency to it not too dissimilar to a (very) rough day at the office. Do what you have to IMO, and the best of luck to whatever you do either way.
Old Jan 29, 2014 | 11:06 PM
  #340
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Jan 30, 2014 | 08:38 AM
  #341
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
I know it might seem like I'm just giving up too easily here, but you can see almost 300 videos of this car on my youtube channel and I would say that 75 of them are troubleshooting problems. The very first one was about Code 59 surging, which I fought for two months trying to keep the car as factory as possible before giving up and going Megasquirt. That should have been a hint to me I guess!
When did the fuel pump issues start, did it start after swapping to MS?
Old Jan 30, 2014 | 10:25 PM
  #342
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Jan 30, 2014 | 11:24 PM
  #343
zz17iroc's Avatar
Alright then. Sorry your having all these issues with the roc. I wish there was more I could do to help Bro. If you end up moving back into your old home I would just let the iroc sit until spring time at least so you can clear your head. Good luck man
Old Jan 31, 2014 | 05:23 AM
  #344
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I would disconect the return line, let it flow into a container. Put a rubber stopper on the end going to the tank to not let air in the tank.
Key on, and go into tunerstudio and enable the pump test mode. Let it run for a few minutes watching fuel pressure. Crank the regulator up.
I suspect what is happening is under high fuel demand your pressure differential in the tank is putting too much stress on the pump. At idle and low fuel demand you're returning most of the fuel to the tank so it's not creating vacuum. When in boost, maybe your taking fuel out too quick.
That is why I asked about the venting to the tank.
I know you are frustrated, but this is a problem that can be diagnosed without leaving the garage.
-- Joe
Old Jan 31, 2014 | 07:28 AM
  #345
bonylad's Avatar
Car: 09 Honda Fit / 91 Camaro RS
Hello,
Im a subscriber on your channel and can tell you how much I love the videos.
1. God your determined. I get upset and defeated feeling over less, I cant imagine how your feeling.
2. Don't sell the car, sell the swap. A LSX with H/C/I will make what your making now and be trouble free. I think in one of your earlier videos you have commented that it was an option. Even referring to the GTO of your buddies as quick or quicker with less done. Hell a 6.0 or 5.3 outta the junkyard with a auto or t56....????
Dont give up.....
Signed your loyal fan,
bonylad
Old Jan 31, 2014 | 07:58 AM
  #346
DIGGLER's Avatar
bonylad
hp-wise maybe.... but not torque.
this thing probably makes hits its hp peak nearly 3,000 rpms sooner than a hci ls1 making 450rwhp. to do that means its making tons of torque down low.
if the fuel problem was fixed, h/c/i would put this car easily at 800hp i would imagine.
Old Jan 31, 2014 | 08:06 AM
  #347
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Heads intake this combo with fixed fuel sys and yes it will scooooot
Old Jan 31, 2014 | 08:29 AM
  #348
bonylad's Avatar
To be sure; however, Im trying to empathize with the situation. Sick of money being spent on a problem only to have another arise or the existing one get inched further away from a solution.
I would check the megasquirt.........
About 3 minutes in.
If you KNOW the car should be doing this or that with the setup you have then you have to look at how its being managed. I would suggest recalling your problem with timing and how the MS reported it. Look at that again and consider if the MS could be somehow be related to your issue, then upgrade or rebuild it? IDK. It wouldn't hurt to pull it, maybe revisit the tune? Have you thought of letting a pro tune it? Your obviously skilled but perhaps a fresh look on the situation? I had HPTUNERS on my 06 Cobalt SS/SC and thought I knew a thing or two.....but alas my tunes were crap and I relied on tweaking existing canned tunes.....more power and better driveability would be had tuned on a dyno. I was cheap.
As to why I even suggest swapping? Well for the money you could sell your whole swap for....you can buy a running LSX setup and be done with it. Not that I want you to....but it would feed my addiction for more videos...lol a little greedy here....
Old Jan 31, 2014 | 08:55 AM
  #349
DIGGLER's Avatar
i believe he checked his fuel pressure with a mechanical gauge while driving? if so, and the pressure fell off, its without a doubt something limited in the fuel system. since it has a big feed now, thats not the problem. which leaves the pump, return line, or a restriction in the rail. if the return was restricting, it might falsely raise the idle pressure. at wot there is less fuel flowing through the return, so it becomes less of a restriction... which could allow the pressure to fall off some from where it was set at idle.
how much fuel does this thing actually use? have we done calculations and all that? does it jive with the tuning in megasquirt? (injector size, duty cycle, psi)
Old Jan 31, 2014 | 09:09 AM
  #350
bonylad's Avatar
That's my point. If the parts are good and according to the man he has replaced literally everything with a system capable of supporting WAY more.....perhaps its the way the parts that are able to be told what to do - aren't being told correctly?
I recall watching videos in relation to the timing on the car and the MS was reporting it way lower IIRC than what it was actually....perhaps that or something else may be a factor? Im not sure but is fueling related to timing vs volume or air ? get one of those acting up......car not reading correctly someplace ...........it wont supply fuel in relation to timing and mass...ergo the leaning out because its being told to. He already has checked and voltage to the pump is not a factor....its dropping because its being told to.
Im just saying, that video above rings home with me. He had all this stuff and wasn't making near the power it should have been. Was related to the tune/ FAST. Take it out and look at it to make sure you don't have a cap or something wearing out.....you did build this right? Then....take another look at the basis of the tune.
