Treadstone TR1245 Intercooler
Old Oct 6, 2013 | 03:15 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
My new intercooler came the other day after a long back order and I must say this thing looks pretty good. I'll be updating this tread as time goes with the install and final testing. For now though I have some pics of the unit itself. I'll be trying to mount this thing straight up compared to my procharger intercooler that's mounted horizontal. I already removed the front triangle support bar that would get in my way when I did my cam change, hopefully it will fit right in.
Link to the intercooler http://www.treadstoneperformance.com...rcooler++860HP I got it from Modern Automotive Performance, and had it priced matched for $315 or so plus international shipping.
Old Oct 10, 2013 | 08:44 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Re: Treadstone TR1245 Intercooler
Same one I'm running and it's doing it's job just fine keeping the IAT's in check.
Old Oct 10, 2013 | 08:56 AM
Car: 1986 Iroc
Engine: Afr 408
Here's some pics of how I have it mounted, don't know if helps or not. Just thought I'd share.
Got it to fit behind the bumper with minimal trimming. I should probably remove the center liscense plate section, but it just seems like I would be butchering it too much.
Old Oct 11, 2013 | 12:17 AM
Tony89GTA's Avatar
Car: 89 GTA
Looks good, thanks for sharing. Thats the basic idea how mine will sit if it all works out. How do you find your intake temps with that setup, any recorded data?
Old Nov 16, 2013 | 06:15 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Some data for you... I have the big 1300 hp treadstone.
Last year I recall seeing 12-13 psi, using fast acting open element IAT, i was seeing 25 deg rise on intake temps
Today we tested my car on the dyno, it was 55-60 deg today ambient. I was on 16-17 psi. We saw 35-40 deg rise in temps! Not good. Thats only 770whp but through the big automatic and converter... Big fan in front blowing cool air.
that aint no 1300 hp but still a good intercooler for most street builds.
Old Nov 18, 2013 | 11:19 PM
Tony89GTA's Avatar
Car: 89 GTA
That's some good data there, thanks for sharing. Have you ever tested the temps after the turbos? My D1SC would jump to 350* at around 10-12 psi and now that I'm pushing 15-16 psi it probably go over 400* . Let's just say the intercooler has it work cut out for it lol! I guess any gain over the 3 core procharger would be a bonus.
Glad to see you finally got the car running, I'll be looking forward for the track videos!
Old Nov 19, 2013 | 06:44 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
No data precooler. I'd like to get pressure data precooler but for now running as is. Going back to dyno saturday if weather is good and we will push it to 20-25 psi to see if we can find 4 digit numbers
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
toronto formula
Nov 10, 2015 06:17 AM
Willie
Jun 13, 2001 12:24 AM
