Procharger 12 rib upgrade
Old Jan 26, 2014 | 06:49 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I purchased my procharger d1sc set up a week ago, but when I asked for the 12 rib upgrade, they said that they didn't have one listed for our cars. How did everybody else get theirs? Do I just have to call procharger and get it from them? Also, what size crank pulley do I need?
Old Jan 26, 2014 | 08:27 PM
Eric89sc's Avatar
Car: 1989 camaro
Engine: 357 procharged
Transmission: turbo 400 with Transbrake
Axle/Gears: 342 posi
Re: Procharger 12 rib upgrade
I have a F1A 12 rib kit installed on my 89 camaro. The brackets are just a sbc kit not just designed for the camaro, I also then have the relocation bracket that bolts onto the head to lower and move the charger out to clear the hood. If your interested i have the brackets and steering pump for that set up Im going to a manual steering rack.
Old Jan 27, 2014 | 12:29 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I ordered mine throught Lonnie P. http://www.lonniesperformance.com/
Std crank pulley is 7.65"
I upgraded to a 8" or 8,25" can't remember
Old Jan 27, 2014 | 08:10 AM
Guest
Guest
Posts: n/a
Procharger has them, lot of money. Iv heard the 12 rib is a tight fit at best.
Old Jan 27, 2014 | 12:08 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Looking at my reciept/packing list and the 12rib stuff is packed at procharger so call them and they can set you up with the stuff you need, basicly the pulleys and som bolts.......
and yes its a tight fit with 12rib
Old Jan 27, 2014 | 08:12 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
So would these 3 parts complete my upgrade?
http://shop.brutespeed.com/ATI-DPxxx...ATI-DPxxxx.htm
http://shop.brutespeed.com/ATI-DCxxx...ank-Pulley.htm
http://shop.brutespeed.com/ATI-DC003...DC003A-012.htm
Old Jan 27, 2014 | 09:32 PM
Eric89sc's Avatar
Car: 1989 camaro
I'm running 12 rib belt and two v-belts plenty of room up front.
Old Jan 27, 2014 | 11:58 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
There are two option.
Std chevy kit or for a serp.setup.
With serp.setup ( so called TPI kit for thirdgen) its a tight fit with 12rib.
Will check the part.nbrs later today..........
Old Jan 28, 2014 | 01:52 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
here are the partnbr I got.
Double check since its been 9years ago...
DC009A-12 crank pulley
DM002I-7 adj. idler bushing
BO06CI-56SS Adj. idler bolt
DC004A-12 3" OD Idler with bearing
DC003A-12 2.3" OD Idler with bearing
BO06CI-48SS Idler bolt
DM002I-1Idler bushing
BO06CI-40SS Bolts
DPxxx-12SC Blower pulley ( should be a offset if using std tpi kit.)
Old Jan 28, 2014 | 10:22 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Thanks for all the help so far. I called procharger today but didn't have any luck ordering it yet.
Old Jan 28, 2014 | 10:52 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Would I need all of the idler parts from them? I am going to be adding a dayco tensioner onto the main bracket as a few people have done on here.
Old Jan 28, 2014 | 11:45 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
No, I guess not, depends on how your planning to use. There are a few diffrent way of doing it.
I use one Idler on my spring loaded setup.
Old Jan 29, 2014 | 12:30 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I never had a problem ordering pulleys or belts before.
For my tensioner setup I used no extra idlers and rev to 6400 no problem so far. You might be able to get away with the 8 rib and spring loaded tensioner. How much do you plan to spin the d1sc?
Old Feb 4, 2014 | 12:12 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Probably no more than 6000rpm
Old Feb 4, 2014 | 01:17 PM
Beater79TA's Avatar
Try doing it with a cog setup using ATI's sprag clutch pulley on the blower...
Anything other than the standard belt setup gets very tight on the radiator with the serpentine TPI setup.
Linson
Oct 24, 2025 02:00 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Zell1luk
Sep 29, 2015 10:36 AM
-=Z28=-
Sep 24, 2015 10:21 AM
