PCV Set Up for Supercharger
Old 04-15-2014, 02:38 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Currently for my cars pcv set up I have the pcv valve located in the drivers side valve cover and hooked to the intake manifold. On the passenger side valve cover I just have a push in breather. Will this set up work for a supercharged motor?
Old 04-15-2014, 08:00 PM
Street Lethal's Avatar
Re: PCV Set Up for Supercharger
It'll be fine, just run a check valve in the PCV line, and zip tie the ends...
Old 04-17-2014, 09:09 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Old 05-06-2014, 12:01 PM
chevyredneck8's Avatar
Car: 88 Iroc Z
Engine: L98 350
Transmission: 700 R4
Is the pushed in breather just a breather not tied into the intake correct?
Old 05-06-2014, 05:49 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Right, not tied into the intake.
Old 05-06-2014, 07:16 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Problem is: that open breather is allowing unmetered air into the engine, similar to a vacuum leak. Try to plumb it somewhere after the MAF and before the SC.
If you converted to Speed Density / no-MAF, then never mind.
Old 05-06-2014, 07:52 PM
Tony89GTA's Avatar
Car: 89 GTA
The PVC valve is the meter for the vacuum leak, I believe it should be factored in the tune if I'm not mistaken even for a MAF setup.
Old 05-06-2014, 08:19 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
For a Speed Density system, I agree. But, for a MAF system, that metered leak is not measured my the MAF, therefore there is more air than the MAF is reporting... just like any old vacuum leak.
Old 05-06-2014, 09:42 PM
Car: 88 Iroc Z
Engine: L98 350
I believe the pcv going in the intake would be correct for maf or speed density no factory pcv that I know of does that differently. If it entered before the maf it could dump oil residue on the sensor and no one would want that.
For the breather I can't imagine wanting to hook that up to a boosted intake that would be a boost leak and for excessive boosted air would be forced into the motor. Does anyone know how a factory system like a grand national does this?
As far a breather being a vacuum leak how is a breather different than a tbi that pulls it though a hose through the air cleaner housing what is the control for the leak that I'm missing?
Old 05-06-2014, 09:59 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Go over to dat dere tech site--> Gen III external engine --> search for "My catch can routing ok?"
A plethora of info
Old 05-07-2014, 02:14 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I am swapping to speed density.
Old 05-10-2014, 04:47 AM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Im a bit confused about this, I have a PCV valve on the drivers side, goes to a catch can, then to the intake manifold. The breather is also on the drivers side. The car is using quite a bit of oil, and the breather seems to be spraying out oil over the engine? Maybe even the gaskets leaking? Would moving the breather to the passenger side help?
Old 05-10-2014, 11:14 AM
Car: 88 Iroc Z
Engine: L98 350
Is your breather and pcv on the same valve cover? is your breather just a filter or is it tied in to the intake. Just out curiosity did u set extra ring gap for the procharger when u built the motor?
Old 05-10-2014, 11:50 AM
Car: '92 RS Camaro
Transmission: TH400
They are both on the drivers side. The breather is a filter, the pcv goes via a catchcan then to the intake. The catch can is a cheap one, probably not doing the job.
Old 05-10-2014, 07:37 PM
Tony89GTA's Avatar
Car: 89 GTA
Maybe your pcv valve is not sealing as good as it should and to much boost is getting through.
deracer
04-11-2016 12:04 AM
toronto formula
11-10-2015 06:17 AM
anesthes
08-24-2015 08:32 AM
PestilenceIV
08-20-2015 03:32 PM
1985chevydude
08-20-2015 12:29 AM
Quick Reply: PCV Set Up for Supercharger
