3rd gear pull at 1000whp
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Kinda what it looks like at 25 psi and 3rd gear start
Car: 1983 Z28
Engine: 385 Fastburn
Re: 3rd gear pull at 1000whp
Gimme a second while I pick my jaw up off the floor.
Holy cow that's awesome.
Car: 89 Iroc-z
Transmission: TH400
Lol if i start and hook in second, it will snap the speedo in a few seconds. 2nd i shift at 108 mph
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
nice...what are you using for a hood? I know our turbo cars generate a lot of underhood heat and my hood is starting to see the effect of it.
Car: 89 Iroc-z
Transmission: TH400
Just a harwood cowl at the moment. Gonna add some heat extractor vents over winter. It does get warm on hot days if i have to idle a long time
yes I agree...the hood starts to get a little flexible when idling for awhile
Car: 89 Iroc-z
Transmission: TH400
When i used steel hood struts on this car it would lift hood corners and bend/warp it. Extreme heat kinda molded it like that. Then i took the struts off and drove around. Heat softened hood again and it molded back into shape lol. Its crazy
I'd like to get hood painted but i am nervous the paint wouldnt last, it gets hot
Extractors will be there to eliminate heat when sitting. Hopefully it helps. It doesnt seem to go over 235-240 deg when sitting for very long time in warm weather. Most of time while moving its 205-210 on hot days. Cold days it wont get warm at all. It will stay 170-180. I have no t stat lol
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
im running 180 or 195 t stat......I have seen 220-230 on humid days.....my hood is painted but im thinking of going with a carbon fiber hood.....not really sure yet....
Car: 89 Iroc-z
Transmission: TH400
I was thinking of something like that if the fan can withstand the heat. Everything remotely close to that header and downpipe has not survived without heavy heat shielding. After a full pull the headers are orange hot glowing haha. Paint on the strut tower has bubbled. Wire looms along the fender have completely melted. Plastic shock tower caps melted
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
That's crazy it gets that hot under the hood! Melted strut tower caps? Wow!
I haven't taken any under hood temp readings while driving but mine stays amazingly cool. My hood is fiberglass too and I have always had some heat reflective mat on the underside above the turbo and downpipe but I'm thinking of just removing it since the adhesive never holds that well. Every time I stop and open the hood the underside is no warmer than if it was a completely stock car.
IIRC you have everything heat wrapped? Just the fact that you are running twins which have a lot more hot side surface area mixed with the fact you are making over twice the HP, that might be a pretty big factor!
I ceramic coated my entire hot side this year and I've noticed a big difference in radiant heat coming off of everything.
Car: 89 Iroc-z
Transmission: TH400
I have wrap and heat shields everywhere lol.
I tell you what, i'll take a pic of my wideband controller box that got exposed to the heat. Can see where the plastic turned liquid and rolled down the corner like wax on a candle lol. Still works
Car: 89 Iroc-z
Transmission: TH400
Car: '88 Iroc
That's crazy about the wideband too. Where is the controller mounted? Which tires are those that you are running? And what type were the Mickey Thompsons? I'm pretty amazed anything hooks at 25 psi from a roll on the street. Are we talking even in first gear?
Car: 89 Iroc-z
Transmission: TH400
These are et streets 295/55/15. My other street tires are et streets 305/35/19. Similar if not same compound. Just dont work as well lol
No first gear. First can hold maybe 10-12psi occasionally, but second has held 22-23 psi from a 50 ish roll. Its nuts. Car is a monster once spooled
Car: 88 GTA, 74 T/A
Engine: 383 stroker (Procharged)
Transmission: TH400 w/brake (new 2013)
Axle/Gears: 12-Bolt S60 - 3.73 (new 2013)
Car: 89 Iroc-z
Transmission: TH400
Ls1 factory fans and a mishimoto 8" on the oil cooler at the moment. Gonna place that on trans cooler soon
Car: 88 GTA, 74 T/A
Do you run your fans off of temp relays or just have them wired to run full blast when switched on? Can you PM me some additional info on your oil cooler? Possibly some pics? Thanks!
Car: 89 Iroc-z
Transmission: TH400
One is pcm controlled. One is switched. Oil cooler fan is also switched
Car: 88 GTA, 74 T/A
Car: 89 Iroc-z
Transmission: TH400
No idea on oil temp but i noticed oil pressure stayed higher longer, so its taking some heat out.
Coolant temps didnt seem to matter once it got to operating range. Always had 2 fans running on warm days. I may be seeing 5-10 deg less than when i ran without oil cooler but thats just a guess
Oil cooler is small tho, something like an 8x8?
Car: 89 Iroc-z
Transmission: TH400
Trans may have been slippin on this run lol got a new one in. So far feels better but still early. Havent beat on it
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
That thing is pulling like a rapped ape!!
Car: 87 iroc Arctic White w/gold ss stri
Engine: Turbo'd 5.3 in process
Transmission: T-56 w/SPEC stage 3+ clutch
Axle/Gears: 9" Moser w/3.25's
Nice pull! Looks like it will make things blurry in a hurry!
Car: 1989 Trans Am GTA
Transmission: M28 T56
Nice, 25psi on a V8 is a wonderful thing.
Car: 89 Iroc-z
Transmission: TH400
Lol it did move abit but think it was just all pushed back to the back of the tank from the force! Haha
Transmission: T-5, TH350, T-5
So when you drive normal cars, do you have a hard time staying awake? Man is that fast.
Car: 89 Iroc-z
Transmission: TH400
Lol i have a hard time driving my all stock 91 305 tpi z28 haha. Thats why its getting a turbo
Good one Giraffe
