Wastegate tubing angle help?
Old Feb 7, 2015 | 06:20 PM
1992Vortec's Avatar
Car: 1992 camaro
Engine: 5.7L single turbo GT45
hey guys i just got all the goods to install my wastegate and I'm trying to get the best possible location to have good exhaust flow with my limited amount of space. I was wondering if coming straight off would work ok or straight into a upward bend would be better? Ive read about ideal flow for wastegates but sorta limited on space and trying to mount in a weird location. Any ideas help thanks guys.
Attached Thumbnails Wastegate tubing angle help?-photo-2-1-.jpg   Wastegate tubing angle help?-photo-1-1-.jpg
Old Feb 7, 2015 | 07:24 PM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: Wastegate tubing angle help?
Why not right out the front? Oil drain issues? Or even on a 45 degree toward the rad? Im sure this would have been a choice if the space was available though.
Jay
Old Feb 7, 2015 | 07:34 PM
1992Vortec's Avatar
Car: 1992 camaro
Ya out the front a few different things start to make issues oil return, compressor housing, and then if i managed to dodge all that id have to run 2 feet of pipe back to the down pipe for the return. Been scratching my head for a few hours looking at every way possible then i decided to turn here lol when i get back to the house ill throw the manifold and turbo on and give you a better idea of what space im working with
Old Feb 8, 2015 | 08:59 PM
1992Vortec's Avatar
Car: 1992 camaro
A few more pics
Attached Thumbnails Wastegate tubing angle help?-photo-1-2-.jpg   Wastegate tubing angle help?-photo-2-2-.jpg   Wastegate tubing angle help?-photo-3-2-.jpg   Wastegate tubing angle help?-photo-4-1-.jpg
Old Feb 9, 2015 | 01:32 AM
project89's Avatar
put a 44-50mm gate in the crossover tube and u shouldnt have issues.
hell u could come off the main part of the log nexto the downpipe with a 44 gate and not have issues
Old Feb 9, 2015 | 07:50 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Either if your pics will work fine lol mine comes off straight and i can control down to 6.5 psi with 40mm gates
Old Feb 9, 2015 | 03:49 PM
1992Vortec's Avatar
Car: 1992 camaro
Ya i starting reading into correct location on wastegate and angles and started getting paranoid on boost creep issues seeing how i only want to run 7 PSI. I think ill go straight off with my 44mm gate i figured a big gate would do the trick almost anywhere on the manifold. Thanks guys that's just what i needed to clear my head ill post pics after i weld it up tomorrow.
Old Feb 12, 2015 | 11:31 AM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Not knocking your build but damn Im glad I just turbo'd the v6. Thats a tight fit right there.
Old Feb 12, 2015 | 05:32 PM
project89's Avatar
lol check my build thread few cuts witht he plasma and sawzal and theres tons of room
Old Feb 14, 2015 | 01:24 PM
1992Vortec's Avatar
Car: 1992 camaro
It not all that tight my 4'' cowl helps a bit lol But here is a pic of what i decided to do..
gixxer92
May 18, 2017 11:20 AM
no green
Jan 9, 2016 09:22 PM
FormulasOnly
Oct 2, 2015 05:52 PM
zman1969
Oct 1, 2015 11:09 AM
mfp189
Sep 27, 2015 09:25 AM
