Single turbo 352 iroc 1000hp or bust the grand finale
Old Sep 15, 2015 | 11:57 AM
  #451
project89's Avatar
Re: Single turbo 352 iroc 1000hp or bust the grand finale
Just the sake of thoroughness I pulled the ground wires off the ms and the injector circuit went open
Old Sep 15, 2015 | 12:06 PM
  #452
project89's Avatar
Resoldering the.Diodes and will retest I'm thinking the new harness I installed has a wire labeled ground were it shouldn't b
Old Sep 15, 2015 | 02:13 PM
  #453
project89's Avatar
left soldering iron at home , but im home now for lunch resoldering them now and ill let u guys know what happens , i did manage to get the wastegates on and im going to put the valve body gaskets in when i go back
i looked the car over and theres not to much to do before friday night so if all goes well im still going racing
Old Sep 15, 2015 | 02:56 PM
  #454
project89's Avatar
ecm is missing Q10 and Q13 as per this diagram
trying to figure out what they do exactly as they are apart of the flyback dampening circut
Old Sep 15, 2015 | 04:30 PM
  #455
DIGGLER's Avatar
I assume the flyback dampening circuit dissipates the reverse current caused by the injector's collapsing fields. That may be what zapped the components.
Old Sep 15, 2015 | 05:09 PM
  #456
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
The good news is that the 3904 BJTs are a few pennies a piece.
The bad news is without them the MCU can't turn on the flyback ckt.
You NEED that ckt. It probably fried the MOSFETS so quickly becuase you have low-z and PWM them. That means the MOSFETS see a lot of flyback.........and high voltage.
Must have been a mistake that they were never installed. This is what wiped out the MOSFETS Q1/Q5.
Yes, the flyback dissipates the energy stored in the injectors when they are turned off. The injector will create a high voltage across Q1/Q5 without the flyback clamp. It is a fast re-acting ckt due to the MCU turning it one istead of doing a traditional Cap & Resistor or zerer diode or diode to vsupply.
Old Sep 15, 2015 | 05:21 PM
  #457
project89's Avatar
Old Sep 15, 2015 | 07:40 PM
  #458
project89's Avatar
there we go had to get rid of the massive picture darn thing didnt even fit on my 32 inch monitor lol
shes getting darn close just hope all goes well friday night when i get the ecm to put in
Old Sep 15, 2015 | 07:48 PM
  #459
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Now that's what I'm talking about! She looks awesome Dave...
Old Sep 15, 2015 | 07:56 PM
  #460
project89's Avatar
thanks still a bunch to do , not looking foward to the header wrap , deff need to get it all cleaned up if i have time , also need to get a battery mine went dead over the winter barley holds a charge so ive been using a way oversized deep cycle battery that was laying around the shop so i could test the ecm and do the wiring in the car
Old Sep 15, 2015 | 08:24 PM
  #461
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I believe he just discovered the biggest problem with MS, and probably why it has a bad reputation in some circles.
If an idiot assembled it, these are the problems you will get.
Also, MS1/MS2 has too many freaking components.
Microsquirt module 4life
-- Joe
Old Sep 15, 2015 | 08:45 PM
  #462
project89's Avatar
-- Joe
exactly had this been somone else who had this unit and purchased it from somone they would be calling it the biggest pos ever , i dont mind to much cause i can fix it and install the missing components. however it is just my luck it would go out right now when im in a mad dash to get the car together
Old Sep 16, 2015 | 04:36 AM
  #463
jimw67's Avatar
Engine: TPI 327 SBC Turbo MS2
Transmission: 200-4R CKP Stage 2
-- Joe
That's why I bought an assembled unit. Alot of 'people' make it sound very easy to assemble, but I couldn't justify the time needed to assemble the module for the additional $150ish, keeping in mind that the assembled units are extremely close to plug and play for GM TBI or TPI setup. The assembly appeared a bit intimidating to me also considering I had never done anything like that before. We had to install the HEI mod kit that took 5 minutes, plugged it in and loaded the firmware - it was truly that simple - hence the reason for purchasing the assembled unit. If you're into the assembly ordeal, then more power to you, but I was much more into building the car and being able to tune it.
I've never been around a Microsquirt, is there an advantage with it?
Old Sep 16, 2015 | 06:49 AM
  #464
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
MS1/MS2 is what I believe is called a "through hole" board, where all the components are directly soldered. It has a LOT of components.
The Module is 100% surface mount. It uses less components, is less susceptible to interference and vibrations, etc.
MS1/MS2 through hole: http://www.diyautotune.com/images/ms230/ms230-c_2.jpg
Module SMT: http://members.cisdi.com/~anesthes/p...V2.2_front.jpg
The Module is the size of a credit card. You mount it using 4 standoffs. You can then plug or solder your harness:
http://www.mjscrane.com/GTS1000/file...irt_module.jpg
Most of the PNP Ms ecm's are based on the Module, because it's easier packaging. I put mine in a stock '165 ECM case, and used a stock Delphi 56 header to make it plug and play with '86-89 Fbody/Corvette
-- Joe
Old Sep 16, 2015 | 08:01 AM
  #465
DIGGLER's Avatar
That little module looks slick..... hard to believe I soldered all that crap together building my ms2. Even more amazing how the car fired right up into an idle after going through the setup wizard.
Old Sep 16, 2015 | 10:37 AM
  #466
project89's Avatar
the only thing i dont like about the microsquirt/mod is that it wont do low-z injectors
when u start getting into large injectors the low-z/peak and hold stuff opens much faster so its easier to get the engine to idle on them
heading over now to install the correct valve body gaskets and button up everything under the car , and finish the cold side plumbing , i might actually have time to buff the paint and wheels before i go racing lol
Old Sep 16, 2015 | 11:32 AM
  #467
Originally Posted by project89
heading over now to install the correct valve body gaskets and button up everything under the car , and finish the cold side plumbing , i might actually have time to buff the paint and wheels before i go racing lol...
Proud of you bro. Get it done so we can see some videos...
Old Sep 16, 2015 | 01:50 PM
  #468
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
All depends on the motor possibly, but there is no need to use low z injectors in this day and age
My 127's do just fine at small pulsewidths and fid makes 2000cc injectors that also work well on all kinds of vehicles including small 4-6cyl motors. High z and still idle fine
Old Sep 16, 2015 | 01:56 PM
  #469
project89's Avatar
intercooler to motor pipe done , i left the upper 90* turn to the tb not welded on as it would be to much of a pain to take the pipe the pipe in and out of the car, leaving that last bend as a coupler joint makes things much easier
Old Sep 16, 2015 | 07:13 PM
  #470
jimw67's Avatar
-- Joe
So it will handle a GM 8 pin dizzy?
Old Sep 16, 2015 | 07:39 PM
  #471
project89's Avatar
we are ready to rock , i justr need to wait for an ecm , got a few minor things to do but nothing i cant do in very short time
gota love the front exit downpipe lol this thing is going to be LOUD
Old Sep 16, 2015 | 08:15 PM
  #472
alex91z28's Avatar
Car: z28, g92, 5psi paxton,42lbs,eblp4
Engine: 5.7 .040bore,195cc trickflow,tpis
Transmission: 5spd
great set up!, like the forward radiator mod. is it the stock size radiator or a smaller one?
Old Sep 16, 2015 | 08:31 PM
  #473
project89's Avatar
its not a direct fot for a camaro , its something i bought that was for a nova if i recall correctlly, i belive it was 1 inch narrower , even with a std camaro radiator there is still room to put the radiator were i did.
im glad i did it it opened up all kinds of room , this winter when i put the second 76mm turbo on it ill still have a ton of room
edit
i still need to weld in the reinfocement bar were i cut out the top of the radiator support , its some 3/4 inch tubing that runs across and ties the 2 sides back together
Old Sep 17, 2015 | 07:54 AM
  #474
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yes. That's how I ran for a couple years before switching to DIS.
-- Joe
Old Sep 17, 2015 | 10:56 AM
  #475
junkcltr's Avatar
Engine: 3xx ci tubo
edit
Looks great. It would be nice to have it run a little bit to check the transmission. Got any old ATX power supplies? They have MOSFETs in them. They would squeak by for now.
Old Sep 17, 2015 | 02:13 PM
  #476
project89's Avatar
i have a ton of atx psu's that i used to use to power my bitcoin miners , ive since switched to server grade 94% efficiancy psus to save on power costs so all my old atx's are stacked up int he closet
i dont want to take apart any of the atx psus as they are still worth 80-150$ each used on ebay so ill just wait for my buddy to get here tom and use his ecm till i can get the parts ordered for mine
Old Sep 17, 2015 | 02:18 PM
  #477
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'll give you my Megasquirt for free if you buy the rest of the car
-- Joe
Old Sep 17, 2015 | 02:33 PM
  #478
project89's Avatar
-- Joe
lol sure but u have to buy my car as well
Old Sep 17, 2015 | 07:13 PM
  #479
project89's Avatar
wohoo the car is ready
going racing on saturday !!!!!!!!!!!!!!!!!!!!!!!
Old Sep 18, 2015 | 01:05 PM
  #480
Just hope that big cubed, big turbo, high stalled engine is faster than my little ole 305 lol...
Dave, put your memory cap on, do they sell oil drain flanges locally around here...?
Old Sep 18, 2015 | 06:39 PM
  #481
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
What have you been running for MPH ?
I was actually thinking about putting a 305 in my boat.
-- Joe
Old Sep 18, 2015 | 07:35 PM
  #482
-- Joe
With the amount of fuel consumption I am seeing in boost, it's telling me that without boost I am at about 275-300 horsepower naturally aspirated. The only thing different with this bigger turbo is it leans out way faster up top running the same bin. I haven't even touched the VE table yet. I'm waiting on Dave to get his done, then I will start updating my thread, as we have a little competition brewing here lol. I say go for it in terms of the 305. My cam is pretty damn big for the small cube, small runner and stock throttle bodied 305, yet she idles so well I am still taken by it. I remember thinking 220+ duration in a 305 would be horrible in a street setup, and here I m running 230+ and am happy with the way she runs on the street. Gas mileage isn't too great as you would expect...
Old Sep 18, 2015 | 07:51 PM
  #483
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The boat originally had a 4.3 in it. I put a 350 together, but I'm weary that the rating on the boat will be so vastly exceeded. I'm thinking of just tossing a l03 in it with the marine cam, I figure 200 or so hp max.
The problem with a 305 has never been displacement, but valve shrouding. I suspect boost would help with that issue.
I kinda want to take my car apart again.
I'm excited to see what you guys run for MPH. I was hoping to get my car ready for the track for the october racing, but I just bought a lake house and I'm remodeling that before it gets too cold.
-- Joe
Old Sep 18, 2015 | 07:55 PM
  #484
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Me too
Old Sep 18, 2015 | 09:04 PM
  #485
project89's Avatar
It's an all nighter for me guys that's why I ain't been posting today. Trans issues I'll b sleeping in the shop tonight to b sure.it's fixed for the morning
Old Sep 19, 2015 | 01:09 AM
  #486
project89's Avatar
got the trans issue fixed but the trans leak was masking the other issue , rear main is leaking so im not going , they have another race in 2 weeks im going to go to that instead
Old Sep 19, 2015 | 09:21 AM
  #487
Ahhh that sucks, sorry to hear you're missing this weekend bro...
Told you I would wait for you to get done, so I'll get some little stuff finished in the interim.
Didn't you pressurize spinning the oil pump with a drill prior to installing into the engine bay to check for leaks...?
Old Sep 19, 2015 | 09:30 AM
  #488
project89's Avatar
i did im not sure if its the rear main or the oil pan itself im going to tear into it a lil more today.
the leak didnt show till i put my friends megasquirt int he car and fired the engine.
it is possible maybe its leaking up higher up on the block i wont know till iget the trans out of it again and crank the motor over
its prolly something stupid , or i over looked something after all i did build a complete car including paint in just over 3 weeks
Old Sep 19, 2015 | 09:34 AM
  #489
Check where you tapped into the engine for oil to the turbo's on the back of the block, more than likely the culprit. Either too loose, or no teflon sealant. Another guess would be the oil dipstick, I hope you remembered to re-install it lol because the pic has it missing...
Old Sep 19, 2015 | 09:47 AM
  #490
project89's Avatar
dip stick is in , only think hooked up on the back of the block is my oil presur egauge , im pulling turbo feed oil from the plug infront of the block above the timing cover , ill snap some pics
Old Sep 19, 2015 | 09:50 AM
  #491
... bingo, kink or tear in the mechanical gauge line, or its' hookup is loose.
Old Sep 19, 2015 | 09:55 AM
  #492
project89's Avatar
i dount it it didnt leak at all when i primed the oil pump , and the leak isnt huge thats whyy im thinking oil pan to block is whats leaking , which sucks cause i cant fix it int he car.the leak is big enough to be concerned about though for sure
me and my friend are going to take a look at it in about 30 mins , were going to see if its possible to sawzall out the center of the kmember and fab in a removeable piece with the engine in the car so i dont have to tear the motor down and pull it out
Old Sep 19, 2015 | 09:57 AM
  #493
project89's Avatar
also if anyone has 80 pound or larger high z injectors for sale let me know
  #494
Look at the mechanical oil line, it was crushed and kinked...
Old Sep 19, 2015 | 09:59 AM
  #495
project89's Avatar
its not crushed i checked it
Old Sep 19, 2015 | 10:12 AM
  #496
Dave, you never got back to me, do you remember if they sell return line flanges locally around here in central NJ? Like Turbo Trix, etc.? Gotta get a new one...
https://www.thirdgen.org/forums/powe...ml#post5963009
Old Sep 19, 2015 | 10:17 AM
  #497
project89's Avatar
turbo trix should , if not ebay
Old Sep 19, 2015 | 10:30 AM
  #498
Haha, I know ebay has them, I just wanted to get it done this weekend without having to wait for it to be shipped. Will give Turbo Trix a shot, not even sure if they are still there or not, it's been awhile. Was hoping you might have remembered other areas that might have carried them as well, I don't remember any Import stores being around that would...
Edit: Found a place in New York for those who are curious, heading out there in a little bit...
http://skspeed.com/search.php?search...flange&Search=
Old Sep 19, 2015 | 10:10 PM
  #499
project89's Avatar
ok its the oil pan leaking , now i need to figure out how to get the oil pan off without pulling everything out of the car , i think were going to cut the center of the k member out , and make a new center piece that bolts in and out and reroute the front brakline off the kmember
local radioshack didnt have mosfets but they did have my missing transitors , so no i just need to source the mosfets online somewere
Old Sep 19, 2015 | 11:30 PM
  #500
DIGGLER's Avatar
can you just lower it enough to redo it? not sure what kind of gasket you are running on the pan...
