Single turbo 352 iroc 1000hp or bust the grand finale
Re: Single turbo 352 iroc 1000hp or bust the grand finale
Was a typo, quoted him saying he installed it +4, but wrote retarding w/advancing effects.
This is why I didn't agree with it. I advanced my cam to take advantage of the Tuned Port Injection intake, smaller valves, lower stall, and lower RPM ability. I needed to enhance my torque curve. You are running a big turbo, better flowing heads, better flowing intake, and much higher stall, which would negatively impact your setup if you advanced the cam. Just set it straight up for the time being...
Engine: TPI 327 SBC Turbo MS2
Transmission: 200-4R CKP Stage 2
Sounds damn good for an initial start up (to me). I'd say the base tune is close anyway. Looked a little rich, but that's always better than a little lean!
Get it rolling.
Best of luck - Jim
Get it rolling.
Best of luck - Jim
heading over now to put the rearend back together and start putting the interior back together
first time the hood has been closed in a while
got the first hoodpin installed , will do the second after lunch didnt want to rush it and **** it up , rear end is also back together and ready to go , gota hookup the trans cooler and boltthe converter to the flexplate and then shes ready to go besides gauges and cleaning up the interior
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Are you freaking drilling the hood for those hood pins latches after you painted it?
cars officially ready i just packed the chute lol , anyways ill post some more/pics tonight when i get home
next mod = carwash
Looking good Dave. Was going to photoshop one of Hawks five inch spoilers to see how it looks out back but I am too lazy. Did you wetsand that paint yet?
havent touched the paint since i sprayed it , only thing i did was rinse it off that day , im putting a aluminum drag wing on the back was going to do it before this race but ill just do it over the winter
thanks
this weekend , though im going to say it now so i dont get any bs
i am only making test passes at the track , it snowed here last night so there is 0 chance of me getting the car out on the road to try to make sure the tune is close enough to make full passes,
witht he snow i will have 0 drive time to try to tune it so everything will have to be done at the track , and i will not risk hurting the motor by making a full pass till i know the tune is good enough
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
You have 3 days. Lol is it snowing every day til weekend? I kinda wouldnt bother wasting time and money at the track if car isnt ready to do some hits
should be in the 70's at the track down south , its not really a watse of money and im pretty sure the tune should be close just wont know for sure till i can get the car out , im also running a bike down there , so either way im going to have fun between the bike and the car
wish there was local dyno , but the nearest one is in the same town the track is in lol
Car: 89 Iroc-z
Transmission: TH400
I would do dyno time to start. Very helpful and not just for airfuel and power. Can listen to noises, check for leaks, etc. monitor more things staying still than going down the track. Its not uncommon to see a leak from tranny vent or some oil somewhere that would never see on the track.
Car: 89 Iroc-z
Transmission: TH400
You do any tuning at all? Idle, driveway moving around type stuff, cold start/hot start? Is base file close? Heat cycles
As long as everything seems to be doing ok, i suppose its ready. I just always use street to do some quick pulls. Nothing major, just short stuff. You can extrapolate from there
Car: 89 Iroc-z
Transmission: TH400
Yeah not gonna make any real decent pulls on wet roads but still even spinning for a second you can tell air fuel in boost to make sure its atleast safe and ready. Hope it clears up out there and you can get some seat time.
i have moved it around a bit and low end is pretty close , need to work on cold start but thats not an issue for the track
spent the morning wiring up my gauges , and checking over oil lines fuel lines etc .
need to pick up some fine thread bolts for the converter , alls i can get locally in stock was 3/8's course thread , i know they will loosen up so i will stop at fastenal on the way to the track and swap them out at the track.
my last big task is to build ramp extensions for the trailer , all we have is a big 5thwheel construction trailer that we use to haul hay bails on and a smaller hay bail trailer , need really long ramps on either to get a f-body up on the trailer
was uspposed to borrow my buddies uncles trailer but hes going racing at the same place this weekend
edit not sure what im more excited for #1 seeing the car out in the sunlight and all washed up , #2 racing the damn thing or #3 running the bike , though i wish my turbo bike was done im sure that thing would be a blast
If you don't make the race then you don't make it, I'm sure the fella's here are happy for you either way. Why not set your sights on dyno tuning if you don't make the track, how far are you from FNP in Utah...?
http://www.fnptuned.com/
and im going racing this weekend one way or another if we have to load the car on the trailer with the cat loader and haul the loader down with to get the car back off we will
though my bike project may sidetrack me a lil bit, this lil turbo bike project i think is going to drive me to buy another street bike this spring
building trailer ramps lol 11ft long extensions currently , but i have another 6ft piece im going to cut in half o make them longer just to be sure , so ramps will be 14ft long each lol
ramps are 90% done car should go right up on the trailer , ill finsh them up in the morning , well late morning i have to go grab a 5kw generator out of the storage unit first thing int he morning
my pair of 400lph pumps showed up since i have an access door in the hactch area and can swap pumps out in 10 mins or less ill swap the pumps out at the track and ill have to reset the hobbs switch for the second pump at a higher psi , main reason for the pump swap is for alky/e-85 in the future
ill post up some pics when i find the cable for my phone
one of the ramps
and one of the 400lph pumps
around here you could be considered "ghetto". but i admire your out of the box thinking! and ***** to drive your car up those.
its what we had laying around the farm , im not worried about it its 10inch wide steel I-beam they are friggen heavy , i will have support legs under it so it cant flex at all .
oh yeah to scared to drive the car up and down off the trailer so were winching the car on and off the trailer instead
Can't believe you're even considering that. All I hear in my head right now is the theme music to the Benny Hill show when looking at those pics lol. Don't mess up that damn paint...!!!!!
Edit: Does that flatbed at least come out and down, or is it just stationery...?
Car: 92 formula, sd,730ecm with $59
Engine: 383/ t-76 turbonetics
Transmission: 700r4 3200 vig converter
like i said no matter what im going racing this weekend, and this is what its going to take to get my car on the trailer i have available to use
Benny Hill Theme - YouTube
functionality should be good with a 10" i-beam i would think. main thing about them is weight and moving/hauling them around. i will say i drove my s-10 pickup onto a trailer like that using the stock short ramps, so it might not take all that much ramp to get a camaro on it?
ramps r done , home for lunch , few minor odds and ends to take car of when i go back but i should be posting pics of this thing on the trailer tonight ready to go for the morning .
first stop of the day is a carwash , then breakfast , and finally the track !!!!!!!!!!!!!!!!
just about ready to load up , heading back to the shop to swap out the pumps for the 400lph pumps , and then should be loading the car up on the trailer and be doen for the night
ramps worked great
were going racing
were going racing
ill report in during the day , friggen 4:30 am right now , and leaving for the track
Dude, doesn't your phone camera have flash lol...?
Front tire looks low on air, don't forget to fill it...
18 psi hung a valve open in the box. Buddy got cell video
