Single turbo 352 iroc 1000hp or bust the grand finale
Old Jan 15, 2016 | 11:50 AM
  #801
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: Single turbo 352 iroc 1000hp or bust the grand finale
Originally Posted by anesthes
Here is my problem with Racecraft:
"Just to clear the air. When we received the spindle from the customer I had asked him if he was street driving or road racing. His reply was that he was not racing and did some street driving. At this time I told him that the spindle we received was not intended for street or road race use. "
I understand that parts break from abuse, but I expect RACE parts to be stronger than OEM parts. (to a degree). If normal street driving breaks a spindle, it's an epic POS.
The spindle brakes at 40mph in traffic and you want me to use it at 130+mph in the 1/4 mile?? No..
"Being that he was so polite about his spindles cracking I offered to replace his spindles with the correct spindle for the application, which is our road race spindle. "
What?? They have two spindles? A crappy one, and a less crappy one?
Why not just sell one good strong spindle?
"Being that it is a custom spindle with the road race option it took us a few weeks to get it done for him."
This is where my BS meter starts pegging. Translation "First design sucked ***, we made some modifications and we hope it won't break this time".
This gets even better:
"It was special order and is no longer available due to people not using the correct spindles for their application and then blaming us for the failure."
So the road race option doesn't even exist anymore. Translation "Uhh yeah, those mods we made didn't actually fix anything, so uhmm. We don't support that anymore.".
If you wanna trust your life to their crap products, so be it. I have a lot to live for
-- Joe
Well I guess thats your OPINION, but i'll gladly continue to run there product on the street.
Old Jan 15, 2016 | 11:52 AM
  #802
Car: 1979 Malibu
Engine: Blown LSx
Originally Posted by lt1z350
Do u happen to know what springs are on your setup. I just did all pa stuff and got his recommended springs 150-200 I think. Just seems like I am having to run them way up to get any stiffness in them. Motor out of car at moment so not sure how it will sit yet. Just know no where near as stiff as the stock springs sat with motor out. Mine are a hyperco Spring 12 inches long.
They are 175lb springs, 10" hypercoils.
Old Jan 17, 2016 | 09:35 PM
  #803
project89's Avatar
thanks guys im going to look into some of the brands u guys are running and ill end up with something , cars on the lift alot so ill be able to keep en eye on the stuf fpretty close
cars pretty dang heavy so i needs to go on a diet
Old Jan 29, 2016 | 02:03 PM
  #804
project89's Avatar
started the car up today , prolly bring it back int he shop this weekend and fit that big ole turbo , finish the wiring and the cage
surprised it fired right up after being outside in the -20* cold overnights for the last 2 months
Old Jan 31, 2016 | 07:19 AM
  #805
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Wouldn't worry so much about that big ole turbo until you have the tune down. It looks like your having cold start and/or idle issues because you need to hold the pedal down, unless this is because you're still not running an IAC and need to manually crack the throttle a tad when its cold. Either way, looking forward to Spring Dave, get it done.
Old Jan 31, 2016 | 08:38 AM
  #806
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Why No IAC ?
-- Joe
Old Jan 31, 2016 | 11:38 AM
  #807
project89's Avatar
Why No IAC ?
-- Joe
correct no iac gota hold the pedal till it warms up a lil bit
joe using ms1 it wont control the stepper iac, i just need to swap in my ms2 cpu back in one of theese days
its really no big deal unless u wanna put remote start on something takes 30-60 seconds of slightly holding the pedal on a cold start before the car will idle without an iac
Old Jan 31, 2016 | 11:49 AM
  #808
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Are you using coolant or did you drain the block for the winter??
-- Joe
Old Jan 31, 2016 | 12:44 PM
  #809
project89's Avatar
-- Joe
haha after what happened with the original motor i made sure i put antifreeze in it this year , last motor i had water in it , and didnt get it changed out in time before it got to cold.
track will just have to deal with it , they dont want u to run antifreeze but im not changing it out for water this year
Old Jan 31, 2016 | 02:39 PM
  #810
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
They usually deal with it by telling you to put it back on the trailer and come back after you've read the rulebook.
How do you get through tech?
-- Joe
Old Jan 31, 2016 | 06:20 PM
  #811
project89's Avatar
-- Joe
they dont even check
tech basically is
open hood check battery hold down and coolant over flow , close hood look in car check belts , turn to u and ask if everything else is what it should be , then hand u ur run card
Old Jan 31, 2016 | 07:13 PM
  #812
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
tech basically is
wtf
Tech here is basically a prostate exam.
-- Joe
Old Jan 31, 2016 | 10:45 PM
  #813
project89's Avatar
wtf
-- Joe
my dragstrip is an old abandoned airport ontop of a mountian that they turned into a 1/4 mile track , the events are run by volunteers , its very laid back.
hell there aint even walls except for the burnout box/starting line
though we r at risk of loosing it as the town its in is pushing for the college to get the property , if we loose it ill have to start going to rmr in slc or down to vegas
ill goto vegas before i goto the track in slc just cause vegas is a nicer track
Old Feb 1, 2016 | 10:01 AM
  #814
project89's Avatar
well damn im not getting the car in the shop for a lil while , 17 inches of snow dumped on us since sunday , and its not supposed to stop till tommorow afternoon
Old Feb 1, 2016 | 10:32 AM
  #815
When is car number 3 w/the V6 and 4-71 going to be underway...?
Old Feb 1, 2016 | 11:44 AM
  #816
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
wtf
-- Joe
You mean no factory stock car is allowed to run there?
Old Feb 1, 2016 | 11:58 AM
  #817
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
If you drive it in, it can have coolant.
If it comes in on a trailer (His, and mine) it has to have water.
A "Factory stock" 2008 or newer can run 135 mph though with just a helmet and no safety stuff, and coolant as long as it's not altered (tuned, exhaust, brakes, nothing).
-- Joe
Old Feb 1, 2016 | 02:58 PM
  #818
Mrich0908's Avatar
Project89 ,
Do you have a link to the valves and srings you ordered from summit ?
Old Feb 2, 2016 | 12:07 AM
  #819
project89's Avatar
sold it as a roller need to pick up another car for the project
Originally Posted by Mrich0908
Project89 ,
not handy but ill dig threw my reciepts and see if i can get the part numbers for ya
Old Feb 2, 2016 | 12:15 AM
  #820
Mrich0908's Avatar
No rush , I would truly appreciate it.
Did you just lap you valves and call it a day or get a full valve job. The seats are very well machine I didnt see a need to .
Your build is awesome though very inspiring. I read 90% , but didnt see if you made it to the dyno. I was wondering what numbers your putting down.
Old Feb 6, 2016 | 09:35 PM
  #821
Mrich0908's Avatar
So I pretty much choose my valve , springs ,retainers , locks and guides . I ended up going with GMs LS2 beehives , comp SS valves, locks and comp retainers.
What valve locators did you use or how do I choose what the proper valve locators I need are?
Thanks for the help.
Mark
Old Feb 6, 2016 | 11:38 PM
  #822
project89's Avatar
Mark
by the size of the guide and od of the valve springs
Old Feb 14, 2016 | 09:03 AM
  #823
Meh, at least someone got a solid roller out of it.
How is this one coming along, still mucho frio over by you? Here it's one degrees Fahrenheit...
Old Feb 14, 2016 | 12:25 PM
  #824
project89's Avatar
been 50-55* that 2 ft of snow we got is almost gone , but everything is currently a muddy swampy mess.
the plan is to readjust the valves get the s475 on the car the first week of march and street drive the car all of march
i want to hit the track in april/may/june , then take july/august/september off as its well into the 100*'s , and go racing again in october/november/december
i also wanna do some desert races on the bike this year so im no sure how that will interfere with the racing the car schedule wise
Old Feb 14, 2016 | 12:30 PM
  #825
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-10 last night here. Horses are not happy..
Garage is about 55*. Gonna head in the shop in a little bit and work on the car some more.
-- Joe
Attached Thumbnails Single turbo 352 iroc 1000hp or bust the grand finale-img_20160214_110220.jpg
Old Feb 14, 2016 | 12:59 PM
  #826
Both of you guys are getting it done, good deal. Can't wait to see some dyno numbers from both of you, although Joe has enough blower on that engine to boost the next NASA trip to Mars lol. Here's some inspiration for you guys, and this is from an aluminum TA stage two block capable of 2000 horsepower. Owner is a guy named Dave, super cool guy, and his best run was 7.80 @ 183. Not bad for a V6. Don't ask me about the blocks' metallurgy though...
Old Feb 14, 2016 | 06:53 PM
  #827
DIGGLER's Avatar
thats a seriously badass car, but if he would have left the purple off it would be absolutely friggin SICK.
Old Feb 15, 2016 | 11:08 PM
  #828
project89's Avatar
new toy
an 05 KX250f
after trying to get my buddy to sell it to me for 2 years hes finally selling it
taking bets on what bones i break first lmao
tried to get the car intot he shop today but with all the warm weather latley the snow is melting off super fast and the yard is like a damn swamp , tires sink into the mud a good 6 inches atleast if u try to drive threw it so i need to wait another week till things start to dry out
Old Feb 16, 2016 | 07:53 AM
  #829
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
new toy
an 05 KX250f
250? Cute kids bike. I had one when I was just a little Joe.
-- Joe
Old Feb 16, 2016 | 08:40 AM
  #830
Oh yeah that car is definitely badass, I think he's expecting to see even faster times this year...
Really nice guy too.
-- Joe
You can't really blame him, ebay makes it too easy. Damn if I had access to ebay at say thirteen years old, I could see myself turbo charging a used up moped and blasting it all over NYC. That would have been awesome. Dave is living the dream lol...
Old Feb 16, 2016 | 09:27 AM
  #831
project89's Avatar
-- Joe
its an mx bike so no need to go much bigger then 250 things got more then double the power of my honda , and i managed to put myself in the hospital in the hospital last year on the honda
a 450 mx bike would have been a good way to seriously hurt myself
Old Feb 17, 2016 | 11:44 AM
  #832
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
How do all of these build threads turn into dirt bike threads....
Old Feb 17, 2016 | 01:44 PM
  #833
project89's Avatar
lol polly cause im actually friends with a bunch of ppl that post in my threads so they like the oddball updates on my other projects
will be a bunch of iroc updates comming things are starting to dry out here pretty well witht he exception of the rain we will get tommorow , so if the weather holds the way its been ill be out driving the iroc in a week or so and get this thread back on track
Old Feb 18, 2016 | 07:15 AM
  #834
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
We actually had a discussion on the Mod/Admin forum regarding those posts specifically. It was decided that while not thirdgen specific, since you were turbocharging the bikes and many of the same principles applied to thirdgens that the tech value of the thread far outweighed the fact that the target platform was not a thirdgen.
Honestly, only 3 people ever complain about posts in this forum to the staff, the same three people, over and over again. But we keep them around because they have big money builds which generate clicks which is good for TGO.
Although I think you and Orr have some of the highest click numbers on the forum last I checked.
This forum has improved quite a bit over the years. For a while it was absolutely dead, or it was the same old P1SC kits installed car after car.
Now we've got guys putting turbos on all kinds of things, all sorts of custom fabrication and backyard engineering. If nothing else it inspires other members to jump into the forced induction world.
-- Joe
Old Feb 18, 2016 | 09:36 AM
  #835
project89's Avatar
i have no idea why ppl bitch about my builds taking so long , ive prolly built and helped build more forced induction cars on this board then 99.5% of the ppl here.
my builds might take a while but they always run and do what they should
anyways so far the rain hasnt been bad at all so i may get my iroc back out sooner then expected , would be nice to have the car back home ready to go the beggining of next week
Old Feb 18, 2016 | 10:18 AM
  #836
I'm going to speak for the people doing the complaining this time, although my thread received its' fair share of the criticism. I've been promising a nine second 305 for quite a few years now, and although there is no question that those who were in my Trans Am now know it will run a nine second pass, I was honestly never in any hurry to blow up the engine just to make a point until I had a backup plan with another engine, which is now done, and waiting for install for when the cast 305 gives way. For those who argued in my build thread, I no longer blame you for what you said, because to be honest, mine has taken awhile and I still get PM'ed all the time asking when I will have updates, and that is definitely my fault. I don't have any excuses, I just update when there is an update, so the thread's been sitting. That being said, you can't really blame the members. When they receive a notification that someone posted in a thread, they want to see some more progress of the subject in question, they are getting tired of hearing "getting close" or the "snow is almost melted". I too thought they would want to know where it stands along the way and would update the slightest of updates, but I've realized they don't want that, they just want to get to the meat and cheese of it and see it tuned or at least running something. They're just venting frustration, no big deal, so don't take it personally.
Old Feb 18, 2016 | 10:21 AM
  #837
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Wow what a change in mindset lol you finally get it
Old Feb 18, 2016 | 10:26 AM
  #838
Haha, I do bro, and I apologize for all that crap that was spewed in the past.
Old Feb 18, 2016 | 02:32 PM
  #839
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Wow. Glad you see where we are coming from
Old Feb 19, 2016 | 07:58 AM
  #840
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Well, I'll just open up right now before anyone misunderstands my position on my build.
I don't care if it blows up, goes 17 seconds in the quarter, or even leaves the garage this year.
Don't get me wrong, I enjoy the 1-2 hours a week I get to play with my car, but it's so far down the bottom of my priority list it's not even funny.
I appreciate the passion you guys have, but when it turns into a pissing it really bothers me. I wish all of you guys the best on your builds and hope you get what you want out of them, I just hope that you are also getting what you want out of life in general. Cars are just cars.
I'm glad everyone is getting along. Thank you!
-- Joe
Old Feb 19, 2016 | 10:11 AM
  #841
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Well that also makes sense then too lol
Old Feb 19, 2016 | 03:29 PM
  #842
mw66nova's Avatar
Engine: 7.0L
i grew up around drag racing. it's all i've ever wanted to do with my life so i'm already living my dreams. my wife supports my efforts 100%, so long as it doesn't drive us into the poor house. my daughter is 1, and i hope she grows up with the same passion i do, but if she doesn't, my priorities are her happiness over mine, and if she decides not to race, we will do whatever she wants.
...but i'll still sneak out to the track
Old Feb 20, 2016 | 07:22 AM
  #843
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
That is good then. Do what makes you happy.
I enjoy the science aspect of drag racing. I'm not really into the competition. After a crap winter and not being able to use my sled once (lake never froze), I really wanna get the boat ready for summer. But I suspect I'll drag the car to the track at least once.
Race track is 15 minutes from my house..
-- Joe
Old Feb 20, 2016 | 09:11 AM
  #844
project89's Avatar
-- Joe
i wish i lived that close to a track anymore , i gota tow my car 200 miles each way almost to go racing , which costs a decent bit , could street drive it back and forth which would be alot cheaper but a 200 mile tow bill if i hurt it is going to be alot more expensive then just towing it to begin with
Old Feb 20, 2016 | 09:30 AM
  #845
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You couldn't race here at your e/t. Tech is .. strict.
-- Joe
Old Feb 20, 2016 | 09:54 AM
  #846
project89's Avatar
-- Joe
im bringing my car upto tech specs , i just didnt have the time last year
Old Feb 21, 2016 | 08:30 AM
  #847
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
-- Joe
Indeed I can agree with most of this. But I still wish the track was closer for me haha
Old Feb 24, 2016 | 01:50 PM
  #848
project89's Avatar
cars back int he shop hope to have it ready for inspection and to bring it home on friday so i can start street driving it
Old Feb 25, 2016 | 03:04 PM
  #849
project89's Avatar
joe and rob this ones for u guys , got the cold start , idle , and ae dialed in today , perfect idle and cold start with no idle air motor. long live the ms .dam phone doesnt pick up the turbo whine
i also swapped out the wastegate springs for a couple 15 pounders instead of the 10#'s that were in it
tommorow i will finish up a lil wiring and take it to be inspected then to the car was so i can cut buff and polish the paint finally over the weekend
enjoy
Old Feb 25, 2016 | 06:24 PM
  #850
Sounds good Dave. The throttle body suction overcame the audio being exposed and not connected like that, but I was still able to hear the turbo. Had the video hooked to the stereo system in my Chevy Cruze turbo, surround sound lol, engine sounds very healthy. Lower VE still needs some attention, but I'm sure you'll take care of that sooner or later. Looking forward to it buffed and on the pavement...
