More 305 power
Old Jun 3, 2015 | 10:48 PM
'87camaro305's Avatar
Car: 1987 camaro
Transmission: 700R4 4 speed automatic
More 305 power
Are they any ways that I can give my 305 more power? I'm tired of topping out at like 100 or 110 mph and having rice burners and v6 4th gen camaros giving me **** about having a slow muscle car?
Old Jun 4, 2015 | 12:44 AM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
Re: More 305 power
There are many avenues, just search the threads on here. As far as directly helping you, first need to know exactly what you have to start with. Also need to know your level of technical competence, and your budget. Feed us that information and you'll find plenty of help here.
Old Jun 4, 2015 | 08:29 AM
Drac0nic's Avatar
Re: More 305 power
This section's for blowers, turbos and nitrous. Are you thinking about using one of these systems? If not, you may be better off asking in tech/general engine or the respective subforum for your induction type (TBI, TPI or carb.) These sections also tend to have stickies with the basics of how to get more power out of each engine. It will also determine what you need to do next to get started.
Old Jun 5, 2015 | 12:31 AM
Car: 1987 camaro
Re: More 305 power
I'm slightly mechanically inclined, but have family friends that can help. Budget would probably be around $1250 and I don't plan on putting forced air intake on it like turbos or a pro or super charger
Old Jun 5, 2015 | 10:43 AM
Drac0nic's Avatar
Re: More 305 power
My first peice of advice is spend a few $ on some books and READ as well as reading the forums a lot. You'll get a lot conceptually and figure out what works and what doesn't. With that sort of budget, I'd be looking into swapping in another axle with 3.42 gears if you don't have htem, a used full exhaust and if you have some cash left over tuning capabilities. Minimally an adjustable FPR. The intake tract stuff is obviously specific depending on it being a TBI vs TPI vs Carb.
Old Jun 5, 2015 | 03:21 PM
Re: More 305 power
Definitely exhaust first, that is the most restrictive part of our car's systems, and always a good starting point on any build. Agree 100% with the research aspect first, and don't buy ANYTHING until you have a well thought out plan. The worst thing you can do for yourself, especially with a fairly low budget and moderate experience, is to start buying parts that may or may not work well together, end up with a hodgepodge that runs mediocre at best and a drained budget.
Old Jun 6, 2015 | 12:55 PM
Car: 1987 camaro
Re: More 305 power
Alrighty thanks guys!
jaridjohn
Jul 8, 2024 03:49 PM
jhawkeye
May 25, 2022 06:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
Brcharrelson
Aug 26, 2015 07:47 PM
