nos sniper kit
Old Mar 5, 2016 | 06:24 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
nos sniper kit
i have this kit, and it doesn't seem to "kick" as hard as you would think. do I need to get a high flow valve or is the selonoids to small for that "kick" feeling? I can tell when it kicks in, but when riding in my buddys car with nitrous its a lot better. any suggests?
Old Mar 5, 2016 | 08:12 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: nos sniper kit
What HP rating is your kit? What size (HP) jets are you running? What HP rating and jets is your buddy's system?
Old Mar 5, 2016 | 08:24 AM
DIGGLER's Avatar
Re: nos sniper kit
a 125 shot should be very noticeable, if thats what the kit is rated for.
what is your bottle pressure, what is your fuel pressure, and what is your jet sizes.
Old Mar 5, 2016 | 11:12 AM
Engine: 355
Re: nos sniper kit
im running the 125 kit. 55 fuel/61 nitrous. bottle pressure is between 750-900 psi. fuel psi 5.5
I believe his is also 125 kit.
Old Mar 5, 2016 | 11:13 AM
Engine: 355
Re: nos sniper kit
I also had a tranny go bad so that might be some of the problem to?
Old Mar 5, 2016 | 06:40 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Re: nos sniper kit
Bottle pressure is low. My car liked 1050 the best.
Old Mar 5, 2016 | 07:02 PM
DIGGLER's Avatar
Re: nos sniper kit
pressure needs to be 900 and then adjust jetting from there. how are you checking pressure? you need a gauge where you can see what the pressure is as you are about to make a pass. it needs to be dead on the money at 900psi.
going by the instruction sheet, looks like your jets are backwards.... should be 55 nitrous, 61 fuel.
Old Mar 7, 2016 | 05:48 AM
Engine: 355
Re: nos sniper kit
I have a pressure gauge mounted on bottle. I have bottle between where rear seats are so gauge is right there. I have a bottle warmer and blanket, might need to let it warm up more before a pass. ill double check jets I might have typed them, in wrong but will check to be safe
Old Mar 7, 2016 | 05:52 AM
Engine: 355
Re: nos sniper kit
there backwards 55 nitrous 61 fuel
Old Mar 7, 2016 | 05:55 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: nos sniper kit
I run the same kit but a universal 4/6cy one. Get your bottle pressure up to 950-1000psig. My jets seems to be on the small size compared to what they advertise but it is crank hp not wheel hp they are advertising.
But I would get your bottle pressure up and also keep your afrs in check or check the plugs. If needed switch arroind the jets. I did not run the fuel jets that the manual said to match the n20 becuse i could not get the afr i wanted. If you have too much or too little fuel it will drastically slow you down and also potentially harm your engine.
lonewolf583
Sep 6, 2016 01:32 PM
siuol
Firebirds Wanted
Mar 18, 2016 11:13 PM
IROCThe5.7L
Mar 8, 2016 05:40 PM
tom3
Mar 5, 2016 10:59 AM
OneShotGlory
Car Audio
Mar 4, 2016 03:31 PM
