Turbo header drivers side
Old Jan 1, 2002 | 03:27 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Got a couple pics of the drivers side header all tacked up. Need to add the collector which should add about 2.5 inches in height. turbos clear everything easily, the closest tube is .5 inches from the upper steering shaft bolt, rest is .75 or better. Will post more pics once the collector is done. cheers, Bob
Old Jan 1, 2002 | 05:27 PM
BlownBird's Avatar
Just curious, Are you making that header out of scedule 80 pipe? If so, that header is going to be heavy as hell. Are you doing a single or twin turbo setup? Keep us posted on how the project is going.and keep the pics comming.
Old Jan 1, 2002 | 05:52 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
using sched 40 pipe, and yeah she weighs about the same as a cast iron header, bout 15 pounds I guess, havent put it on a scale yet. Yes I am running a twin setup with T3's. cheers, Bob
Old Jan 1, 2002 | 06:16 PM
89ProchargedROC's Avatar
heavy, but it'll work fine
i have a buddy locally who used that on his twin turbo 454 with small super series 60 turbos
on little boost it went 9.80s, but it is tubbed
Old Jan 1, 2002 | 10:38 PM
Guido's Avatar
Car: 2000 Trans Am
Looking good!
How is your plug wire access going to be with those?
Old Jan 2, 2002 | 12:06 PM
scauffiel's Avatar
plug... wire... access...??
Uhhh...
LOL
Just kidding!
Steve
Old Jan 2, 2002 | 12:21 PM
Bobalos's Avatar
From the looks of this one Header, my bet is not bad. for some time now I have bought nothing but BBC wires & run them under the headers (for looks mostly), & my bet is that if he does this trick he will not have any problems.
My question is how are you (Bob) going to get the down tube through? are you planning on going out through the fender & then back in or is there enough room to the side of the booster to get it down? It is hard to see from this angle.
While I am @ it, what are you using to weld that pipe up? Just a standard Mig?
Looks good, cant wait to see how it comes out.
BW
Old Jan 2, 2002 | 04:07 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Theres plenty of access to the plugs and wires, the downpipe will run between the last two cylinders, between the head and the last primary pipe, near the dip stick ( I am swapping to a Lokar flexable stick and mount it to the last cylinder. I plan to run a 2.5 inch downpipe under the oil pan and over the pass side and mate with the second downpipe and Y into a single cat then onto the Hooker dual GN exhaust. Heres a couple different pics.
First a scale shot.....
This one is from below....
I plan to weld using my Lincoln 110v MIG, with I had a TIG but someday..... cheers, Bob
Old Jan 2, 2002 | 05:22 PM
Bobalos's Avatar
Gotcha, I saw that & thought, "boy that is a funny way to run the #7 tube, wonder what that is about?", but did not think that you were going to run it though there as the dipstick tube was in the way........... Duh.
Thanks amigo. I just bought a Hobart 135 & have been playing with it for a little while. I love it, I tried using a buddies Lincoln 100 & could not draw a bead to save my life, but he was able to run them well enough to put in my Sub Frame connectors. Anywho, See Ya
BW
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Mutillator
Oct 1, 2015 06:05 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
