Iroc build
Old Nov 25, 2017 | 10:37 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Iroc build
Going to try and start a build thread. I will try and keep updated. Back story, car was had a 406 Tpi, t56, 150 shot, and a 10 bolt. Tore it apart about five years ago unhappy with the combo. Car got back burnered while I was building my shop. Took some steps this summer to finish it. Setup will be following
-5.3 ls with ls6 heads, katec ls6 torque cam, arp hardware
-4l80 built with rossler trans brake and custom ati converter
-VS racing billet 80mm turbo, eBay air to water, chiseled water tank
-Quick performance 9 inch with a spool and 3.55 gear.
I am running an aei motor plate and mid plate if any one is curious on the brand. Would highly recommend if going this direction.
Attached Thumbnails Iroc build-img_4597.jpg   Iroc build-img_4592.jpg   Iroc build-img_4593.jpg
Old Nov 25, 2017 | 10:45 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Re: Iroc build
Got the rack mounted and rear suspension fab work done. Break down of parts
Rear
-Trz anti roll bar
-Moddified Bmr torque arm
-Founders rear coil overs with 110lbs springs
-Control arms are mine built with rod ends
Front
-Lakewood struts
-Coil over
-Founders strut mounts
-PA racing k member
Attached Thumbnails Iroc build-img_4543.jpg   Iroc build-img_5425.jpg   Iroc build-img_5424.jpg   Iroc build-img_5414.jpg   Iroc build-img_5331.jpg
Old Nov 25, 2017 | 10:49 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Re: Iroc build
Motor is a 5.3 with ls6 heads and cam. This is what will be motivating it.
Old Nov 25, 2017 | 10:59 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Re: Iroc build
The next big step was sending it to someone who is a much better welder and fabricator then I am. So enjoy the pics
Attached Thumbnails Iroc build-img_5627.jpg   Iroc build-img_5628.jpg   Iroc build-img_5624.jpg   Iroc build-img_5622.jpg   Iroc build-img_5613.jpg
Old Nov 25, 2017 | 11:04 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Re: Iroc build
Pics
Attached Thumbnails Iroc build-img_5615.jpg   Iroc build-img_5614.jpg   Iroc build-img_5618.jpg   Iroc build-img_5617.jpg   Iroc build-img_5616.jpg
Old Nov 25, 2017 | 11:10 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Re: Iroc build
Pics
Attached Thumbnails Iroc build-img_5619.jpg   Iroc build-img_5658.jpg   Iroc build-img_5656.jpg   Iroc build-img_5659.jpg   Iroc build-img_5674.jpg
Iroc build-img_5673.jpg   Iroc build-img_5678.jpg   Iroc build-img_5675.jpg   Iroc build-img_5676.jpg
Old Nov 25, 2017 | 11:13 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Re: Iroc build
Last ones of me picking it up to bring home. Have more fab work to do before I blow it apart to paint and reassemble.
Attached Thumbnails Iroc build-img_5680.jpg   Iroc build-img_5682.jpg   Iroc build-fullsizerender.jpg   Iroc build-img_0686.jpg
Old Nov 26, 2017 | 12:29 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Re: Iroc build
If anyone has questions feel free to ask
Old Nov 26, 2017 | 07:14 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: Iroc build
Very nicely done sir. Especially like the exhaust. I am thinking of mergine my 2 turbos into a 4" all the way back. But uncertain at the moment.
Old Nov 26, 2017 | 07:32 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Re: Iroc build
I wanted full exhaust and just couldn’t settle on fender dump. For my set up the 4 inch was difficult. Tony the person fabricating it said dual 3 might have been easier. All in all I am happy how it turned out.
Old Nov 26, 2017 | 07:38 PM
Re: Iroc build
When I was running a single 76mm turbo I had a 3 inch pipe that came out and down under the car where the converter should have been. I put together a 4 " setup from there and it wasn't that bad to do. Wich I kept that setup too haha
Old Nov 27, 2017 | 08:14 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Re: Iroc build
I have my old 4 inch that has dual tail pipes and muflex muffler that I could sell you if your interested.
Old Jan 9, 2018 | 02:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Iroc build
Looks great
