SBC SINGLE TURBO PROJECT
Old Jun 25, 2021 | 12:32 PM
  #151
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Re: SBC SINGLE TURBO PROJECT
Do I “Need” a kill switch if I relocate my battery?
I may go for a test n tune once in a blue moon, but don’t plan on running it competitively.
The first diagram is the way GM has it
The second is what I planned on doing? (For simplicity sake)
This works doesn’t it?
Old Jun 25, 2021 | 02:10 PM
  #152
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Well upon further investigation….
looks like if it’s relocated anywhere there has to be a kill switch to run at the track (test n tune or not)
and with that a sealed battery box. No questions asked…
damn, back to the drawing board
Old Jun 25, 2021 | 04:23 PM
  #153
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Time to buy a sealed Moroso battery box and switch.
Go to princess auto and buy welding cable.
It's doable
Old Jul 10, 2021 | 10:02 PM
  #154
GTA Sammy's Avatar
Car: 1989 T-Top GTA
So all my stuff came in…
Mounted the kill switch like LB9GTA
Already ran the battery cable to the front where I’m gonna have a positive bulkhead and tie in with the existing cables.
Gotta run the 4 gauge wire from the alternator to the kill switch
Old Jul 13, 2021 | 03:53 PM
  #155
GTA Sammy's Avatar
Car: 1989 T-Top GTA
K, power wires have been run back n forth.
Just gotta make terminal ends in the back, the front is done.
Another quick question…. I wanna keep my oil cooler and was gonna run 5/8” heater hose but can someone tell me where the coolant was coming from and going to as far as the passenger side plumbing goes .
Getting closer…..
Old Jul 14, 2021 | 11:50 PM
  #156
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Mounted the Moroso battery box in the hatch.
Made terminal ends on all the wires in the hatch and connected them.
Battery positive and alternator power wire to one lug on the kill switch and the other lug goes to the positive power bulkhead on my driver fender.
Whew…. Still gotta install
Coolant lines from oil cooler
Vacuum lines
Boost gauge
Power to starter from the positive bulk head
MAP
Passenger PVC to catch can
Put the Wideband O2 in.(just a hookup)
Then EBL Flash P4
Plugs and wires/timing
Sooooo close
Old Jul 23, 2021 | 10:37 AM
  #157
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Well the plugs and wires go in pretty good… if hours is good 🤣
After a bunch of fighting with the lack of space I bit the bullet….
Gotta unbolt the driver side from the head and v-band to get #1 spark plug in, but it might have gone in easier without the header wrap. Either way I feel like the wrap is a necessity so…, it stays
I hate the way the HSR fuel rails fit around the distributor, I might try to route it from the front with the crossover in the back…
I pulled the cap and it looks like I got rough timing ready.
Wires routed this way for now…
Vacuum and boost lines are done.
Still gotta run a line for the boost gauge but the T fitting is already in place. I’m hoping that I can reuse some of the transmission temperature gauge wires that are there so maybe it’s partially done (wishful thinking)
Street Lethal helped me out with a few EBL specific questions I had, like where do I wire the MAP sensor, repining and MAF delete….Thank You
This is way more work than most people are willing to tackle….
The only way I would have attempted it was with TGO!
Thank you to all that have helped me along the way…
Almost ready
Old Jul 23, 2021 | 06:45 PM
  #158
brian p's Avatar
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 4L80E in progress
Axle/Gears: 9 bolt 4.11
Try Accel shorty plugs, not cheap but. I have to pull the down pipe to install #5 every time and the shorty plug (a 526S for vortec heads) gives me some clearance. And yep, Rob/Street Lethal is the guy for sure, I'd still be choking in fumes in the dark ages without him...
Brian
PS just saw your pm now, glad you got the MAP sorted.
Old Aug 8, 2021 | 09:46 AM
  #159
GTA Sammy's Avatar
Car: 1989 T-Top GTA
OMG, didn’t realize that the EBL needed a NB o2 signal so I bought an OEM o2 sensor and welded in another bung. I thought that it would use the WB somehow….
Not to difficult at this point but it meant that I had to take the downpipe off again (won’t be the last time, I know…) and unwrap the fibreglass wrap, weld and re-wrap… ugh
With the exhaust out of the way I was able to finish the heater core/oil cooler lines and get the wire loom relocated up and on the fender so I could pull the MAF wires out.
I also took the opportunity to wrap the heater lines in foil to protect them from heat and figured I would do the same to the downpipe to protect me from fibreglass hair 😝 and the turbo blanket went on…
Old Aug 22, 2021 | 12:49 AM
  #160
GTA Sammy's Avatar
Car: 1989 T-Top GTA
I took a few minutes to post a YouTube video on my page “Sammy’s Garage”
The sound is bad, but I know why… (GoPro was in a sealed case….)
and I lost a bunch of wiring and battery box mounting video… 🤷‍♂️ Ugh
Over the last week or so I was able to delete my MAF and re-purpose a few of the wires for the MAP Sensor. I got a 5v power from the TPS Sensor.
So the MAP now has a vacuum/boost reference. The boost gauge needs to go in and a few pin relocations for the EBL ECU
Then taking care of the laptop and software before I can start it…
Old Aug 28, 2021 | 05:22 PM
  #161
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Looks like I’m gonna need help with the EBL install.
I was gonna add the comm port to the smaller connector A1 but it’s already full. 🤷‍♂️
So I go check out what’s in A1 for a 1989 5.7L TPI ECU and it looks like it’s power for my fuel pump relay
Old Aug 28, 2021 | 05:23 PM
  #162
GTA Sammy's Avatar
Car: 1989 T-Top GTA
I’m missing something
It’s probably obvious to many, but I’ve never done this before 🤷‍♂️
Old Aug 29, 2021 | 10:46 AM
  #163
GTA Sammy's Avatar
Car: 1989 T-Top GTA
BIG Thanks to BobR from DynamicEFI
I have a much better understanding of what it takes to do a EBL conversion…
I thought it was just a few pins…(3) but I was wrong 🤣
I’ve just purchased a EF Connector
I’m gonna start labelling and removing pins from the connectors to reorganize them into their eventual locations.
Old Sep 2, 2021 | 05:16 PM
  #164
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Started the process of repining last night
Old Sep 6, 2021 | 09:12 PM
  #165
GTA Sammy's Avatar
Car: 1989 T-Top GTA
All the pins are out…
EF connector should be here anytime…
Then it goes back together.
Old Sep 10, 2021 | 05:55 PM
  #166
brian p's Avatar
Car: 86 IROC
I really should sign in more often, sorry about that. I just come in and read posts, never think to check my pm's. Glad to hear you're taking a stab at the repinning. I also realized after reading the above you have a P4. I have the Flash 2, it seemed much easier to repin but it's the same process. Deep breath and one at a time. it'll work out great. Just wait till you get on the boost...
Old Oct 6, 2021 | 06:52 AM
  #167
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Everything’s re-pinned….!!!
Time for laptop stuff 🤞🙏
Old Oct 10, 2021 | 05:30 PM
  #168
GTA Sammy's Avatar
Car: 1989 T-Top GTA
OMG!!!!
After it was all said and done ….
It looks like the Ignition control module took a dump…
No spark…
Tested the coil it’s good
Need a new ICM
My luck….
Like brand new
Unbelievable
Old Oct 11, 2021 | 12:04 PM
  #169
DIGGLER's Avatar
that pic brings back memories. when i got my car, it had an ANCIENT Accel DFI (early 90s) in the factory location, and it used an adapter harness between the dfi and factory wiring harness, and that is where the wires would be switched around to the appropriate input. i had that thing out quite a few times changing pins around....
Old Oct 14, 2021 | 11:09 PM
  #170
GTA Sammy's Avatar
Car: 1989 T-Top GTA
It’s alive!!!
I can’t believe it
Swapped the distributor and it lit right up…
My wide band says it’s rich… 10ish
I’m not screwing around with it tonite.
I’ll post a video soon
WooHoo!!!!
Old Oct 20, 2021 | 06:57 AM
  #171
GTA Sammy's Avatar
Car: 1989 T-Top GTA
K, I’ve got a faulty MAP sensor (was reading 12 lbs boost with the engine off 🤣(funny, not funny)
I’ve ordered a new one and spark plugs as well… the current plugs have to be super fouled by now…
Old Oct 20, 2021 | 08:00 AM
  #172
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
What MAP sensor you using ?
2 bar?
What plugs you running?
Old Oct 20, 2021 | 09:57 AM
  #173
GTA Sammy's Avatar
Car: 1989 T-Top GTA
It was a 2 BAR MAP Sensor
just bought a 3 BAR (it’s what was available)
I had installed my old E3 std temp plugs initially…
but I’m replacing them with Autolite 3923 as per AFR’s website …
Old Oct 25, 2021 | 09:42 AM
  #174
GTA Sammy's Avatar
Car: 1989 T-Top GTA
I think I figured out what part of my problem is…
I think I may have wired the MAP sensor incorrectly…
The new sensor gave me the same reading, so…..
Either, way I posted a sneak peek of the car starting.
greywuuf
Feb 3, 2021 09:05 PM
19Irocz86
Apr 7, 2007 10:51 PM
rooster433
Jun 25, 2003 06:55 PM
blk86ta
Sep 20, 2002 02:49 PM
