383 procharger project
Old Jan 31, 2020 | 10:20 AM
Tarizza's Avatar
Hi, I am italian, sorry for my english...
I have 1991 z28 with 305 tpi, complete exhaust, walbro fuel pump, 24 lb injectors in tpi with 58 throttle body and procharger system at 9 psi.
I have a 383 short block (1984 cast year) to finish of built and swap the 305
What do you recommend to install for complete my 383 with procharger?
I search a budget built and 4/500 hp close maximum.
Can I use my Tpi system?
Can I use LT hotcam or other budget parts ?
Thanks!
Old Feb 6, 2020 | 07:11 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: 383 procharger project
If staying TPI, an aftermarket unit would be necessary. A lot of restriction with a stock tpi on a 383.
Old Feb 8, 2020 | 09:28 AM
toronto formula's Avatar
Car: 89 Firebird Formula
Engine: 383 tpi vortec heads Xr 269 cam
Welcome to the board
check out my thread in this section “surest route to 400 fwhp”
the specs on my build are in the thread. It is a decent set up making close to 400 fwhp with after market tpi on a 383 block
One mistake I made was the higher compression ratio so you may want to look into reducing compression ratio to supercharge.
Old Feb 15, 2020 | 02:30 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
In my opinion, the boost or positive pressure of the blower should overcome any restriction of the intake manifold...
I assume that because the block is from 1984 that its designed for a flat tappet camshaft...
That will affect what camshafts you choose. The LT hot cam was a roller cam if I remember correctly.
Google search "flat tappet camshafts for boost-Chevy"
CRAZYCHUCK13
Nov 20, 2014 02:12 AM
SixSeriesCSi
Jun 5, 2010 10:11 AM
blue86z28
May 4, 2003 09:43 PM
Four12'sCamaro
May 24, 2002 11:20 AM
MouseCamaro305
Apr 1, 2001 09:59 PM
