Turbo down pipe
Old 05-10-2020, 10:16 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Turbo down pipe
Running a Bw s480. It’s 5” I’m necking down to 4” I’m curious if anyone else has ran a single 4” all the way out the back. It really curious about 4” between the heater box and engine. Non Ac
Old 05-12-2020, 09:59 AM
TGO Supporter/Moderator
anesthes's Avatar
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Re: Turbo down pipe
Good luck! I had a 3" in the same spot and it was very tight.
Old 05-16-2020, 10:49 AM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: Turbo down pipe
When I ran a single 4" down pipe I modified the heater box and had plenty of room. It can be done.
Old 05-16-2020, 02:06 PM
Street Lethal's Avatar
Re: Turbo down pipe
I did the same thing, ran the downpipe angled straight downward parallel with the box after I made the cut . It barely kissed the number eight primary, but it did clear. Could have made more room by redoing/rerouting the eighth primary on the header, but I wound up switching back to a three inch downpipe because the four inch was overkill....
- Rob
Badass355ciz28 (05-17-2020)
1970judge
01-21-2010 10:28 PM
IROCFAST
11-25-2008 10:08 PM
Fromaster
10-10-2006 11:06 PM
high c
02-12-2006 07:39 PM
Omega
06-28-2001 08:41 AM
Quick Reply: Turbo down pipe
