Vortech bracket project
Old Oct 15, 2020 | 11:03 PM
cpalmaccio1@gma's Avatar
Car: 90 iroc z
Engine: 358 tpi
The current project I am attempting to tackle. It began with a sweet trade deal for a vortech supercharger. The bracket mounting kit for the third gen camaros has been discontinued for over a decade. I have a hobby machine shop in my garage so I'm documenting my attempt to mount it up. I turned down a crankshaft pulley spacer on my lathe and drilled it on my Bridgeport. I made several cardboard templates for the mounting bracket before getting it right. Once done i sent it to a buddy with a cnc plasma cutter to burn it out. Due to space constraints i decided to model it after the procharger kits. I turned stand offs from 3/4 aluminum stock and spaced the bracket out so it straddles the serpentine belt. Finally got it mounted up and looked like it's going to work
Old Oct 16, 2020 | 10:29 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Vortech bracket project
Looking good! I ran mine on the passenger side. Brackets out of aluminum, spacers, etc. Pretty straightforward. Fun project.
-- Joe
Old Oct 20, 2020 | 06:39 PM
83 Crossfire TA's Avatar
That looks like a heafty backet. FWIW, if you go about this again, aluminum sheet/plate can be cut quite well using woodworking tools. I've "rough" cut quite a few supercharger brackets and similar items on a table saw, and done fine details with a router. If you wanted to make a copy of your bracket in aluminum, probably the easiest way would be to cut the aluminum to close to the right size using a table saw, circular saw or jigsaw and then bolt the 2 together and use a pattern cutting router bit in a router to make an exact copy.
Old Oct 21, 2020 | 08:24 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
That is what I did. Chop saw and table saw for straight cuts. Hole saw, etc.
Old Oct 23, 2020 | 11:02 AM
iroc90dfi's Avatar
Car: 1990 IROC-Z
Engine: 355 TPIS Mini Ram, Vortech R-Trim
Axle/Gears: 3.73 Strange S60
Very cool, I have a vortech on my 90 IROC let me know if you need any pics of the bracket
Old Oct 23, 2020 | 11:54 AM
Car: 90 iroc z
Engine: 358 tpi
Curious about your set up. Are you running stock motor, what injectors, did you upgrade your fuel pump?
Old Oct 23, 2020 | 12:06 PM
iroc90dfi's Avatar
Car: 1990 IROC-Z
Its a 355 but changed to a blower cam, dart heads, mini ram, using a Walbro 255 Fuel Pump
Old Oct 23, 2020 | 12:08 PM
Car: 90 iroc z
Engine: 358 tpi
Yeah there's a few things I'm worried about I am currently running a 355 as well I have a trick flow 465 horsepower top end kit with hyper Pistons the blower was kind of an afterthought currently I have 24 lb injectors I know I'm going to have to upgrade I'm not happy that I'm going to probably have to put a new fuel pump in the tank right now is the stock one also will be running a methane injection kit
Old Oct 23, 2020 | 12:23 PM
iroc90dfi's Avatar
Car: 1990 IROC-Z
I use 50lbs injectors, I think I need to upgrade my fuel lines to a bigger size at some point. I use a O2 gauge, and a data logger to monitor fuel issues. I am also running a Accel DFI system.
Old Oct 23, 2020 | 12:26 PM
Car: 90 iroc z
Engine: 358 tpi
I'm running the ebl p4
Old Oct 31, 2020 | 08:44 PM
Car: 90 iroc z
Engine: 358 tpi
Got it all hooked up and did some preliminary driving while tuning and this thing is a monster
Handy_man91
Carburetors
Jun 4, 2021 06:22 PM
Aaron R.
Apr 25, 2020 05:53 PM
84 1LE
Convertibles
Mar 26, 2020 08:29 AM
gta324
Sep 1, 2008 12:33 AM
maniacc
Mar 2, 2001 01:51 PM
