Air/Fuel Ratio Gauge
I am going to install an air/fuel ratio gauge once my procharger goes in. Is there any certain brand that is better than the other, or one that sucks?? Which do you guys run? Thanks
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Check out the DIY PROM board. They have a very accurate Air/Fuel meter than. Better than anything I ever heard off.
Tell em Large Marge sent ya.
J
J
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Keep in mind that any gauge combo sold for under $250 will be for the narrow-band air/fuel meter. It's basically a rich-lean indicator. Above 500mV, rich, below 500mV=lean. Folks try to tune with them (i.e. blah blah said I need to keep it at 890mV), but they aren't to accurate. It is better than nothing, though. If you can buy or borrow a wide-band air/fuel meter for when you need tuning, it's a much better solution. You can buy them complete starting around $700, or build a kit the DIY_EFI folks have been kind enough to put together for about $35+sensor (around $125-$150). HTH!
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Just go to pep boys and buy a stock O2 sensor for a civic. 2 black wires = positive and negative, 1 white wire = Guage wire. Attach that guage wire to a $40.00 Auto-Meter Stoichiometry guage.
Then take the header / Y-pipe / Manifold to a muffler shop and have them weld it in for $12.00. or do it yourself...
Bingo, done and done, under $75.00
Want more info? email me.
Kingtal0n@aol.com
Kingtal0n@aol.com
Engine: 3xx ci tubo
Take a look at http://www.diy-wb.com/. It will cost a about $160, but it will read way better than a regular O2. Especially at WOT, which regular O2 does a terrible job.
J
J
Car: 1992 B4C 1LE
Originally posted by Jester
I like Cyberdynes.
I like Cyberdynes.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
