ATI Procharger Q's
Old Mar 28, 2002 | 12:36 AM
SMKNGTA's Avatar
Car: 1989 GTA
Axle/Gears: 9bolt 3.27s
ATI Procharger Q's
I got a Procharger catalog about a year ago and I am just now seriously looking into a power adder, and their numbers seem kind of high. So this is what I'm thinking, my car make about 320fwhp now and with AFR heads, LTI intake, cam, 58mm TB, and headers I think I would be looking at atleast 420fwhp. The ATI book says "you can take almost 2 seconds of your et!" they also say they have "put completely stock L98 F-body's into the 11's, and can easily take TPI's into the 10's with minimal engine modifications", has anyone seen this done or done it themselves? ATI says their P-1SC with 12psi will give you an 80% gain, which equates to over 750hp on my N/A 420hp engine. This seems really high, what do you guys think? Does anyone have dyno #'s or time slips before and after there SC?
Old Mar 28, 2002 | 04:23 PM
SMKNGTA's Avatar
Car: 1989 GTA
Doesn't anyone have an ATI???
Old Mar 28, 2002 | 05:26 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Patience......
Normally aspirated on a 305 built for a supercharger:
14.06 @ 98.00
After D1SC (10-psig) but needing fuel/spark curve mapping (EPROM) calibrations:
12.05 @ 116.62
Willie
Old Mar 29, 2002 | 01:19 PM
SMKNGTA's Avatar
Car: 1989 GTA
Willie
Thats an incredible gain, what compression are you running? I'm running 9.5:1, do you think I could run 12 psi? Is your ATI really loud and anoying or not that bad?
SMKNGTA
Old Mar 29, 2002 | 02:00 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
12 would be too much for your app... I wouldnt go over 9, 6 would be the safest. Especially on a stock bottom end. Im sure ***** could shed more light on this than I can!
Old Mar 29, 2002 | 02:51 PM
Willie's Avatar
9.2 : 1
Possibly, but I would ease into it gradually. That's what I did. I started at 8 psig while recording data. Once I knew all scanner data looked good, I bumped up to 10 psig and repeated the process.
Another important point is the fact that I use an intercooler AND water/alcohol injection -- please see the other current thread on this subject. These "add-ons" along with aluminum heads greatly decrease the in-cylinder temps. I'm sure I could run even more boost given these facts.
ATI rated my blower at 96dB. It produces a very obvious whine at idle (quite cool) but quietens somewhat as you increase vehicle speed. This may be in part to other noises, such as exhaust, wind, etc.
Willie
Old Mar 29, 2002 | 09:35 PM
SMKNGTA's Avatar
Car: 1989 GTA
What do you mean stock bottom end, I have a 383 stroker with forged internals and 6" rods. What is water/alcohol injection, I have heard of it but I'm not sume what it is or does? Thanks
SMKNGTA
Old Mar 31, 2002 | 06:50 PM
rhuarc30's Avatar
Water/alcohol injection uses shoots a fine mist of water and/or alcohol into the intake tract to cool the air. Alcohol also has a high octane rating so it helps reduce detonation. With forged internals 12 psi intercooled should be no big deal as long as you get mixture and timing dialed in right. There is also some debate about the merits of propane injection, which shoots propane into the air stream. This is more popular with the import boys right now, and started with diesels.
Here's a coupla links that should help you out.
http://home.att.net/~stevemon/AlcoholInjMod.html (this one has several other links on it as well)
https://www.thirdgen.org/techbb2/sho...threadid=36275
http://www.geocities.com/rad87gn/tech/SteveCkit.html
http://www.procharger.com/faq.html#5
http://www.turbobuick.com/messagebd/
Old Apr 1, 2002 | 02:03 AM
SMKNGTA's Avatar
Car: 1989 GTA
Thanks for explaining water/alcohol injection rhuarc30.
Old Apr 1, 2002 | 12:28 PM
89ProchargedROC's Avatar
Those percentage gains are on a STOCK motor
you would not see that high of a gain on a nice n/a motor like yours because your motor is already VERY efficient
you take an inefficient STOCK motor and add a lot of boost and you'll get a lot of hp from it
take your efficient n/a motor and add a bunch of boost and you will see less
see what i'm saying?
Old Apr 1, 2002 | 12:48 PM
SMKNGTA's Avatar
Car: 1989 GTA
That makes sence.
sleprock
Oct 1, 2015 09:39 AM
sleprock
Sep 24, 2015 04:33 PM
-=Z28=-
Sep 24, 2015 10:21 AM
MoJoe
Sep 15, 2015 12:50 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
