P1SC on Stock Bottom
Old Mar 28, 2002 | 04:39 PM
89_RS_Mike's Avatar
Im currently looking for a 350 short block and I am wondering if I should be looking for a forged bottom end or just stock. I plan on running a P1SC with 9 psi. Will this be ok for a stock bottom end because forged is out of my price range right now.
Also what kind of Runners work best for supercharging?
Old Mar 28, 2002 | 05:04 PM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
from reading different posts on this board i would reason to say that 9 PSI is the absolute max i would run on a stokc bottom end. in other words, thats pushing it. i would say 6 psi is a more manageable solution until you can upgrade to the forged assembly and get the job done right. otherwise you might be replacing stock internals to the point that it surpasses the price of the forged assembly.
Old Mar 28, 2002 | 05:46 PM
89_RS_Mike's Avatar
Damn! That wasn't the answer I was looking for. Guess I will wait till I can get a forged assembly.
Thanks Mike
Any ideas about the best runners?
Old Mar 28, 2002 | 06:15 PM
BigMike92Z's Avatar
honestly i wouldnt take my answer as written in stone. im just going b y what i've heard from this board. wait for answers from some of the "gurus" like guido and others. they will have better answers for you...
Old Mar 28, 2002 | 11:26 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Willie runs 10psi on his stock bottom end 305 and hasn't had any problems that I know of.
Old Mar 29, 2002 | 06:38 PM
maniacc's Avatar
right now i'm running 10#'s boost on a stock bottom end and in another month or so i'm jumping up to 12#'s but if i blow up the engine i'm not to worried, cause it'll give me a reason to build a new forged engine to handle some serious boost
later
larry
Old Mar 29, 2002 | 07:00 PM
BigMike92Z's Avatar
so, as you can see, i was wrong... sorry bout that.
Old Mar 29, 2002 | 08:21 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
9 psi on this stock bottom end L98 was ok until the old owner put 85 octane in it and blew the head gaskets.
Old Mar 29, 2002 | 08:23 PM
BigMike92Z's Avatar
85 octane.. geezus.. i dont think i've ever seen that low. 87 is the lowest here...
Old Apr 1, 2002 | 01:42 PM
89_RS_Mike's Avatar
Thanks for the help guys I think I will just run 9 psi that should be fine.
beastin91rs
Oct 9, 2015 07:38 AM
Genopsyde
Oct 7, 2015 08:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
