Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Suggestion: Editing Subject Line
Old Sep 23, 2003 | 01:11 PM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
I frequent several Computer Tech Forums and one of the things that they have found to be helpfull is to allow the user to edit the Subject line. When a problem is fixed the user can then add the word " Solved " to the Subject Title. Helps a lot with searchs and alerts others to what has worked.
Old Sep 23, 2003 | 01:26 PM
88txiroc's Avatar
That is a good idea.
Mods can edit the subject line now, so if someone wants one changed they can PM or email the mods of that board.
Old Sep 23, 2003 | 01:32 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
No because people will post a crazy title to get attention then just change it later.
Old Sep 24, 2003 | 07:44 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Would that mess up the search?? I also don't think that that would be a good idea, because there will be other members out there that will have the same problem and will have a heck of a time looking through all of the solved posts. They will have to read through all of them to find out if it fits their situation.
Old Sep 24, 2003 | 08:20 PM
Car: 86\92 Mutant
Engine: 355CI 430HP
A search usually involves more than just one word. It works very well on the Computer Forums that I frequent. No problem at all.
IE: A search for " Holley problem SOLVED " is going to bring up a lot less hits than having to weed through a search called " Holley problems "..... but the hits you get will have solutions that work. It actually makes the search function better.
Some people never bother to post back when a solution works. That is just plain wrong. It helps every one when an acknowledgement is posted that a solution works. Makes it much easier for someone to sort the " wheat from the chaff ".
We've had people resurrect a ( computer ) post that is months old, that people were ripping their hair out trying to solve and do a repost with the Subject line edited by adding the word Solved. You wouldn't believe how many posts we get right away from people saying that they had the same problem, that no one could ever fix, and they were so happy to finally find a solution.
Sadly as IROCZTWENTYGR8 notes this requires a forum with a certain level of maturity. It is very bad etiquette to change a Subject line from something, let's say, inflammetory to something innocent for example. Trolls do that...considerate, mature users do not. I can see IROCTWENTYGR8's point there......he would know the forum's past better than me. Maybe it's been tried before and didn't work
Old Sep 24, 2003 | 09:00 PM
88txiroc's Avatar
Then maybe we should let users know that if they solve a problem that has been posted about, PM or email the mods and ask them to put "Solved" in the subject line. I know that I would not mind doing that for our members.
Old Sep 24, 2003 | 09:54 PM
Car: 86\92 Mutant
Engine: 355CI 430HP
That should work
Old Sep 25, 2003 | 05:44 AM
Administrator
Nah, we can't allow it.
Old Sep 26, 2003 | 02:10 AM
Car: 86\92 Mutant
Engine: 355CI 430HP
OK..
gta892000
Aug 11, 2019 11:16 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
R13_Braz
Sep 18, 2015 05:00 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
TBRays98
Sep 6, 2015 05:05 PM
