Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Right justify sig pic?
Old Feb 10, 2005 | 04:24 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I'd like to have a small picture of my car in my sig, but to the right of all the text, so it takes up less space. How can I do this?
Old Feb 10, 2005 | 05:52 PM
CaysE's Avatar
Interesting idea, but I'm pretty sure this site is designed for 800x600 resolution, and that doesn't leave a lot of room with three table columns with the borders that are already set. I doubt it will happen unless TGO enforces smaller signature images.
Old Feb 10, 2005 | 06:03 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
something like this ?
Old Feb 10, 2005 | 06:07 PM
JT's Avatar
JT
Community Administrator
Unless i'm misunderstanding, i think he means place an image to the right of his signature. You can see that his signature does not take up the entire 'column'. The image would be right above the "Report this post | IP: Logged"
HTML is disabled in signatures, as well as most of the forums. i do not believe this will be possible. Unless, as adambros demonstrated, you make it an image.
Old Feb 10, 2005 | 06:18 PM
CaysE's Avatar
Oh... thought he meant to the right of the "post" text.
Old Feb 10, 2005 | 06:30 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Yes, but in a sig. Sounds like it can't be done... weak!
Old Feb 10, 2005 | 06:32 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Save the pic to your hard drive. Edit as you wish (within the limits set by TGO) post it somewhere, and just reference the image in your footer . edit : i meant sig
What about that can't be done ?
Old Feb 10, 2005 | 06:37 PM
JT's Avatar
JT
i meant it can't be done in a normal fashion that you'd likely find on a webpage, using HTML. As far as i know at the moment, your method of posting it as an image is the only way.
If he then wants to add links in that signature, then he's going to have a problem. If he wants to change text in his signature, then it's going to cost him extra time and hassle.
But, that is about the only way that would get him want he wants, for now. No offense meant, you did give him 1 option for his request.
Old Feb 10, 2005 | 06:41 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
I'd have to agree with you -- I was just trying to help him out with his original request.
Old Feb 10, 2005 | 07:11 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Well, I thank you all for the help. As you can see, there is a large gap to the right of my sig. I really want to add one of those recangular collages of my car to it, but if I just add it to the top or the bottom of the text it is much too large.
I could cut some of the signature off, but I like it!
Lanz06
Mar 13, 2019 06:07 PM
92projectcamaro
Sep 29, 2015 07:07 PM
ndndndnd
Sep 28, 2015 08:00 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
gt4373
Sep 9, 2015 10:29 AM
