Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Attachments not working 4 me, both Firefox and IE
Old Mar 21, 2006 | 05:05 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I cannot see the attachments. I use Firefox 1.5, so I tried IE 6.0 and same thing. Is it just me?
Old Mar 21, 2006 | 05:10 PM
Crazy Firebird Kid's Avatar
Car: 84 Trans Am
Same for me. IE 6
Old Mar 21, 2006 | 05:50 PM
JT's Avatar
JT
Community Administrator
I checked both of your accounts and they are properly set, as far as permissions and options.
EDIT: I see the problem. It will be corrected.
Old Mar 21, 2006 | 06:03 PM
krisb410's Avatar
https://www.thirdgen.org/forums/history-originality/352382-1992-gta-amt-models.html
Where the box is for Attached Thumbnails is empty/blank
and
https://www.thirdgen.org/forums/history-originality/329335-82-z-28-factory.html
on this one, I click on the thing and a new window opens, but it's blank
Kris
By the way. Thanks for all the hard work you guys have done. It's awesome.
Old Mar 21, 2006 | 06:51 PM
bjm323's Avatar
Car: '91 Camaro RS
I am having the same problem. IE 6 here.
Old Mar 21, 2006 | 11:52 PM
IROCmenace's Avatar
Car: 1988 IROC
Transmission: 700R4 Silver Dart
Axle/Gears: 3.70 posi
I have IE6 and am having the same problem as the previous posts. When I click on attachments they open in a new window but are blank.
And ditto to the hard work.
Old Mar 22, 2006 | 02:55 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Same here.
Old Mar 22, 2006 | 09:29 AM
jasonlitka's Avatar
The forums moved to a new directory (from techbb2 to techboard, with a redirect from techbb2 to the new link) and it looks like I forgot to restart vBulletin after I updated the setting variable. My apologies, it should be fixed now.
Old Mar 22, 2006 | 09:31 AM
Car: 84 Trans Am
Just checked and it does look like it is working correctly now. Thanks much.
Old Mar 22, 2006 | 11:03 AM
krisb410's Avatar
Working for me now
evilstuie
Jan 9, 2020 08:29 PM
86IROC112
Sep 7, 2015 01:37 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
jahblah
Aug 12, 2015 05:54 PM
