Original Decals location.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I want to make a record, if any one has an all original car, and it has the decals on the original parts, say under the hood on the engine, or on the wheels in one thread, I want to make a record of them
1) Where is the Decal
2) Take a pic,
3) What is on the decal,
4) Make note of any Codes on the decal, is it listed on the SPID sheet.
It would also help to have the Year of the car and whether its a Camaro or Firebird.
This might make a nice sticky
thanks
2) Take a pic,
thanks
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
1) Correct, Permissable, dependable, trustworthy, finder of information in unusual places. He is very okfoz about his information
What does your name mean? Lol.
Oh and try this.
(WILL POST SITE AS SOON AS I GET HOME)
4:34 now I get home at 5:15.
Oh and try this.
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
The pictures Midwest has posted of his TTA is an excellent start for referencing decal style/placement.
Car: 89' IROC-Z
Engine: LO3
What I am wanting is the nitty gritty, its the little things that go unnoticed by owners, or removed by dealers before they are sold. What really started this was I was gauking over an 87 Trans Am at the Dayton TA nats which appeared to have most of the decals in place under the hood, the little tags that label to the assembly line which part to install. Midwest Muscle added to this with his pics of the decals on the Rims showing the part number and the RPO.
For example did you know that there is suposed to be little decals wrapping the throttle cable, and the cruise cable. Also did you know that on each of the springs there is a label, also with the sway bars, On the Cold Air box there is alos a decal with a code. Thats what I am looking for.
Here are some pics, now that I had time to do them:
The first pic you can clearly see the 2 decals wrapping the throttle linkage and the Cruise linkage. If look closer you also find a part number which appears to be attached to the FUel rail supply tube.
The second pic I would be surprised if any one has missed this one, its for the AC unit, by the blower motor. THere is one on the AC compressor too, but I chose not to post that one.
The third pic you can see the date stamp on top of the radiator core end. Kind of interesting, but the Upper and lower Radiator tubes also have a date stamp... I had one for my 87, which had a late 86 stamp, but it had been crushed due to an accident when I bought my parts car. I could have used it but I did not figure it was long for life.
Here are some more...
The first pic you can spot a decal hiding behind the Left relay, also there are some stamped numbers (part number) on top of the realays
The second pic, the Brake Master cylendar has a decal on the front, and hiding behind it there is one on the booster.
The Third pic, there is a decal on the Air box, hiding behind the Charcoal cansiter.
And the last one.
I am kind of skeptical about this one, BUT the company that made the altinator was either Reime, or later called Delco Remie (not sure about spelling). Unfortunately thats the best pic of the decal I have.
John
John
I believe that is a reman alt.. Mine just had the 2 letter code stamped on it from the build sheet on it no decal.. my powersteering had a little sticker on it.. no code just a info decal about not prying on the unit..
There is also stickers with codes on them behind the dash, on the instrument cluster and one on the top of a auto trans.. the BW rearend had metal tags along with a paper type decal (stuck to the cover)with the build sheet code. shocks, springs and wheels had a code .. even the dizzy cap had a paper bar code on it.. Ill try to find all my old pics of low low mile TTAs
Car: 89' IROC-Z
Engine: LO3
I HAVE A DIGI
So I'll take pictures of EVERYTHING.....literally. Any sticker writing anything I find....I'll post up. Even if it doesnt look original....you never know.
HERE THEY ARE
http://www.delcoremy.com/Alternators.aspx
HERE THEY ARE
THe logo Might be a D & R combined, therefore Delco Remy would apply. Obvously Delco Remy could have changed their logo since 1987,
If you look close at the Alt, the First word could be Delco, there appears to be 5 letters, but with small caps. The second word might be Remy as I can see the Y dip down at the end of the word, and there appears to be only 4 letters. It might be the original Alt.
JOhn
JOhn
Engine: LU5 305 CFI
Okfoz it's amazing the number of stickers/labels/tags that come on a vehicle from the factory.But then every part has to have an inventory/tracking history.Once upon a time dealers did the prep before vehicles went on the lot,or especially for customer pickup,a lot of these were removed or washed off(now you're lucky if a car on the lot is clean).My '83 Z28 has the remnants of the paper code tags still.I'll have to look closer to see what is left on her.My '95 Jimmy has a label with a bar code on the firewall.And my '73 CST has a SPID on the top inner fender(at least it's more permanent than the console lid).It's odd how GM used them,at least on trucks,then quit using them.And in mid '84 they start using them again.
The main reason I think it might be a reman is because I bought a reman alt from the dealer with those markings.. that decal is warranty info I believe.
The ink stamp on the alt is a 2 letter code like DA,TY just like on the booster or master cyl . But like you said mine is a 89 not a 87 and things change LOL
Welll.... does any one have an original Alt to take a picture of?
yep thats the stamp I was talking about.. It matches the code on the build sheet... I have had rubber stamps made for redoing that kind of stuff..
WOW I have never seen a tag like that !!! nice work
I think I might have a adhesive backed paper sticker that was used on the 9bolt rearend cover in 89.. Ill have to do some digging
Very Cool
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
I would like to find the "Firebird" emblems on the front quarter panel. You can find pics of what I am looking for here... https://www.thirdgen.org/forums/exte...d-emblems.html
Car: 1986 Firebird, 2000 WS6
Engine: 2.8, LS1
Transmission: 700R4, T-56
Axle/Gears: Stock, Stock
Re: Original Decals location.
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Are you still interested in these original decals? I have some label pic's of my original '91 TA Convertible but they are too big to post. I am working on some interior items at the moment, so the car is in a location about 30 miles from me. I go there about once a week and would gladly take shots of anything I find that you don't already have in this string. Let me know if you still want submissions.
I have two that may be fairly unique. My '91 TA was built around Aug of 1990 and has two decals under the hood. One, mounted on the flat surface to the right of the radiator is an emmisions waiver dated "9/19/1990" that identifies the vehicle as "CPC-E3" (both handwritten in ink on the label). It is white with black lettering about 3"X4" in size.
The other is about 4"X6", is yellow with black lettering, and is mounted on the underside of the hood at the front just left of center. It identifies the car as a "CPC Engineering Test and Development Vehicle". It also has boldly printed on it that the label is to be removed before conveying the car to the public.
If you have seen anything like these, I would sure like to know. I could get nothing from either Pontiac or PHS. Pontiac had the car for its first 8000 miles and I bought it from them as a "used" car in Feb of 1992. Paperwork shows it invoiced to the dealer by Pontiac via their company auction sales. Don't know if this car was used for emissions testing or as a test vehicle for the release of the 91's as convertibles.
I'll capture them and post the images if you would like them or other decals for this string. Are their any labels in particular that you would like to see? I havn't removed anything but some have fallen off over the years.
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Here are the pictures of the emissions waiver and CPC Test & Development labels from my 1991 TA Convertible. The car was probably built in Aug or Sept 1990 and the date on the ASC door tag is marked Mar 1991. Both decals say that they were to be removed before sale (obviously they were not). Sorry the clarity of the Emissions decal is not good. It basically states that the car, for some period of time, was exempt from emissions standards. It is dated in writing on 9/19/90 and identifies the vehicle as CPC-E3.
Can anyone that can help identify their origin or meaning?
Thanks,
Thanks,
can you get ones that are not so blurry?
John
John
Engine: LB9 5.0 TPI
Transmission: 5 SPD
I will try to get a better angle and enlarge so the print is clearer. I will not be at my garage until late next week and I will try to take the shots.
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Finally got a shot you can read. The first is the emmisions waiver identifying the car as number CPC-E3 (lower right corner) and dated 9/19/90 (lower center). Both hand written on the lable in ink.
The second shot is the location of the emmisions waiver label (right center of picture below yellow "CAUTION" label).
The third is the underhood location of the "CPC ENGINEERING TEST AND DEVELPMENT VEHICLE" label.
Have you seen either of these on any other cars? Both have GM part nembers. Do you know what CPC stands for? I found another reference to CPC in a different thread that said it was Chevrolet Pontiac Canada, but this is a Van Nuys car by the VIN and converted by ASC in Mar 1991 based on their door label.
Any info would be appreciated.
Those are really interesting, I must admit that they are interesting nonetheless.. Obviously the car was originally or at one time a Test vehicle...
Really its a neat piece of history, too bad you don't know the full extent of what it was used for.
John
John
John
John
Engine: LB9 5.0 TPI
Transmission: 5 SPD
I have a theory but can't prove it. I think that either the car was used to validate emmisions for the new 1991 models or to validate the ASC production process before Pontiac put the convertibles on the market as a factory option.
I'm a retired manufacturing/engineering guy. When we were bringing out new models, we would first do a short run of product (5-10 units) that were used for in-house testing to validate processes, fit, and finish. We would internally identify these units as E-1, E-2, etc.
With the designation as E-3 and the 9/19/90 date on the label, the timing would fit to be one of the first units converted in the original production run to validate assembly processes with ASC. Unfortunately, I have not found a way to prove this.
I found the car in Jan 1992 at a Pontiac dealer that bought it from GM auction sales in Dec 1991. It had 8000 miles on when I picked it up as "used" with full warranty. It was in Pontiac's care from its 1990 build until I bought it.
I suppose it could also have been used by a Pontiac exec for the 9 months as well, but then why the labels? Anyway, thanks for taking a look at them. Are there any particular labels you are still looking for?
I guess one thing that might help is what is the first 7 digits of your VIN. If it was a test vehicle then it might be a 1G2FW23F... THat would indicate that the car started as a coupe and was converted. If your VIN is 1G2FW33F then that would indicate that it was always intended to be a Convertible.
I have one of the Pre production cars, its VIN is for a coupe, so I am thinking that its not about ASC's process, but more for emissions as ASC already had been approved by GM for their process'.
Another aspect to your decals and the engine which would support the emissions theory or at least a test car for MPG is the fact it has the LB9 Engine. Since it would be unlikely that GM would allow Pontiac to have anything significantly better than a Chevrolet the LB9 was probably determined to be the top engine for the convertibles, period, thus your engine.
John
John
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Thanks for your thoughts. The car has the 3 code in the VIN, so it was always intended to be a convertible. Strange though, the RPO sticker shows code AD3 which, I believe, is decoded as "window, hinged roof".
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Here's an emissions sticker that I recreated for my 84 Z28. In the upper left hand corner you can see where I have written XKA 5.0 L69. The sticker that I was working off was damaged and I can't make out what should be there so I just came up the other stuff to fill in the blank. Anyone know what should be there? I know the XKA is correct.
Engine: LB9 5.0 TPI
Transmission: 5 SPD
This is from the sticker on my 91 TA (its a 5.0L LB9 car).
1st Line: LLL
2nd Line: 5.0 Liter
3rd Line: M1G5.7VANTA8
4th Line: MBO-1A
1st Line: LLL
2nd Line: 5.0 Liter
4th Line: MBO-1A
John
I was hoping that someone with an 84 L69 would read this and give me the info. I can easily make the sticker myself. I probably just start a new thread asking for the info and see what I get. Actually, I can P.M. some of the guys on this site that I know have an L69 with a 5 speed and see what their's say. Thanks.
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
This might be the wrong place to ask this but.. How do you check if the engine in your 87 IROC is the origial ? Where do you check? and what do you compare it to..? Please help!
On the Block, on the RH (Passenger) side behind the Alternator 1982-1987 or behind the AC compressor (1988-1992) there is a "Hog" that has some information stamped on it. Including the sequence number of the car the engine came out of.
John
John
Not silly really,
There is probably a better name for it, but it is the term that is refers to pieces on the casting that stick out. That is what my dad always called them. He was a Metallurgical engineer for the special Foundry at Buick.
John
John
here is the dash check decal out of my JY 92 formula
http://www.team3rdgen.com/modules.ph...id=354&popup=1
I forgot I kept these.. this is the decal that came on black 16x8 crosslace wheels
http://www.team3rdgen.com/modules.ph...id=371&popup=1
Car: 1991 Pontiac Firebird
Engine: 3.1L 189CUI
Transmission: 4spd Automatic
Dear Members!
I'm New here, and not good in English, but i try to ask.
My question is: After a new paint job if i want to take back the original decals, and vynils (on the hood bottom and driver side door, etc).
Where can i get tham as new or reproduced form?
Or how can i save tham?
I have an 1991 V6 3.1L Firebird.
I will wait for any answer here or PM.
Regards:László
Regards:László
You can get some of the Under Hood decals from classic industries - www.classicindustries.com The Drivers side door decal is a little more difficult to come by as they were all car specific with the VIN.
I bought some, from a guy, I really do not remember his web site tho... someone please chime in.
John
John
Car: 1987 Iroc-z Convertible
this might be the one you are referring to.
http://ras001.0catch.com/stickers/stickers.html
