Super Vortec TPI intake
Old Feb 8, 2009 | 12:59 PM
JERRYWHO's Avatar
The project has started with installing new injector bungs that will move the injectors up .250 to get them out of the port. Now its time to weld up the roof to move it up like the injectors.
Jerry
Attached Thumbnails Super Vortec TPI intake-mvc-001f.jpg   Super Vortec TPI intake-mvc-006f.jpg   Super Vortec TPI intake-mvc-003f.jpg
Old Feb 8, 2009 | 02:56 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Super Vortec TPI intake
Signing on to the project.
Old Feb 8, 2009 | 03:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Axle/Gears: MWC 9” 3.00
Very nice... should be another good flowing TPI intake. Edelbrock should change their casting to something of this design
Old Feb 8, 2009 | 04:00 PM
JERRYWHO's Avatar
Welded it up now time to start the machine work.
Jerry
Attached Thumbnails Super Vortec TPI intake-mvc-011f.jpg   Super Vortec TPI intake-mvc-009f.jpg
Old Feb 8, 2009 | 04:11 PM
Car: 1989 GTA
Engine: 369 TPI
Hehehehehe. Another 300+ CFM TPI intake manifold in the making. Hey Orr, I agree that Edelbrock should but they won't.
Old Feb 8, 2009 | 05:04 PM
JERRYWHO's Avatar
One picture of the port side with a quick hand grind to see what to set the mill at. The old port is 1.66 tall, the ported one will go 1.90 after the mill is done with it. My six hours today is done, time for other things.
Jerry
Old Feb 8, 2009 | 05:21 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Wow, there is alot of material that can be taken out. thats almost a proper 1205 gasket size correct?
Old Feb 8, 2009 | 06:40 PM
Car: 1989 GTA
Engine: 369 TPI
Vortec intake manifold.
Old Feb 8, 2009 | 07:31 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
My fault, i forgot about that. I mean 1255 gasket size which i believe is 2.11 by 1.08 inch. That intake should take full advantage of the vortec port
Old Feb 8, 2009 | 09:09 PM
Car: 1989 GTA
Engine: 369 TPI
The taller Vortec ports are one of the reasons Jerry decided to raise the injector as much as he could and still retain the stock fuel rail setup. Edelbrock could have done the same thing.
So yes there is now plenty of room to open the port up to some serious air flow. The stock Vortec TPI intake manifold is pretty dismal as it comes from Edelbrock. I can't wait to see the dyno results of this motor.
Old Feb 8, 2009 | 09:49 PM
Mike Massey's Avatar
very nice work!!
Old Feb 9, 2009 | 10:58 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I can hardly wait as well, the port size after I ported it was 1.86 sq. in.(was 1.77)
It will now be around 2.2 when finished.
The compression will go up to 10.5 from 9.7.
The head flow will now be 270 cfm intake 218 exhaust (was 236-193) (Etec200's) The intake port is now 2.13 sq. in. (same as AFR 195 elims) was 1.77.
Stock Vortec head is 1.76
As bad as it all was, 12.80 @ !08. wasn't all that bad.
(motor in sig. is not mine)
Thanks Jerry all is greatly appreciated.
Old Feb 10, 2009 | 08:42 AM
JERRYWHO's Avatar
Update on this project, Fit the Plenum, runners and fuel rails and was able to move the injectors up .312 and still fit the plenum on with some mill work to fit the fuel reg and the front fuel crossover tube. Will post pictures of plenum after work today.
Jerry
Old Feb 10, 2009 | 04:13 PM
Car: 1989 GTA
Engine: 369 TPI
Just wondering if you raised the injector .250" would everything clear without a little clearancing?
Old Feb 10, 2009 | 04:40 PM
JERRYWHO's Avatar
It has more to do with the runners, SLP has the plenum sitting lower then stock by .050 to .100 and if you use AS&M runners you have the plenum about .050 to .100 higher then stock, so no plenum work is needed with the AS&M runners.
Pictures of the work needed to fit the SLP runners with the injectors .312 up, it's very little work to the plenum.
Jerry
Attached Thumbnails Super Vortec TPI intake-mvc-017f.jpg   Super Vortec TPI intake-mvc-016f.jpg
Old Feb 12, 2009 | 10:54 PM
JERRYWHO's Avatar
Update:
Had some time today to setup the mill and rough cut the roof on each port. You can see how much it will be moved.
Jerry
Old Feb 13, 2009 | 12:32 PM
Car: 1989 GTA
Engine: 369 TPI
....and the angle is changed for more of a direct shot into the head port instead of at an angle as on the stocker.
Old Feb 14, 2009 | 02:12 PM
JERRYWHO's Avatar
and the angle is so bad on the Vortec intake you can't get a good turn into the head, and if you try to you get this.
Jerry
Old Feb 14, 2009 | 04:11 PM
Car: 1989 GTA
Engine: 369 TPI
Hmmmmm, it looks like some more welding is in order. I don't think I want to do a Vortec intake manifold in case anyone is thinking of asking.
Old Feb 14, 2009 | 07:42 PM
JERRYWHO's Avatar
If someone asks you to make them a fast Vortec intake manifold.... RUN! Its about 50% more work to end up with a manifold that is about 10% worse than a standard port Edelbrock manifold. If I pull my super ram runners off this week, do you think you'll have time to do the mill work?
Jerry
Old Feb 14, 2009 | 08:52 PM
Car: 1989 GTA
Engine: 369 TPI
If you want them done like Alex's then there will be welding and the machine work. I will also need the plenum if you want that opened up like Alex's. Bottom line is yes I'm ready to go so maybe drop the runners and plenum off at Don's and I will pick them up this comming week and get started on them.
Old Feb 14, 2009 | 09:25 PM
JERRYWHO's Avatar
I only need the machine work done on the runners only. The plenum is already cut open to match the runners, with the divider removed. I really only need the machine work on the runners, but you'll need to have them welded to do it. Also, I can do all the grinding and divider removal needed.
Thanks,
Jerry
Old Feb 14, 2009 | 10:58 PM
Car: 1989 GTA
Engine: 369 TPI
Gotcha. I have to weld on the bolt extensions and of course the runners on that end of things so we don't punch through. I will leave the plenum half of the runners to you. Also we will use the gaskets to center the holes with.
Old Feb 16, 2009 | 12:15 PM
86 IROC's Avatar
Where are you getting the new bungs from? Are they an off the shelf part? Or something you had made up?
Old Feb 16, 2009 | 02:46 PM
JERRYWHO's Avatar
I make them from barstock.
Jerry
Old Feb 16, 2009 | 08:17 PM
Car: 1989 GTA
Engine: 369 TPI
For those who don't have Jerry's skills do a Google search for "fuel injector bung". You will come up with quite a few suppliers.
Old Mar 4, 2009 | 09:47 AM
Dyno Don's Avatar
Followup:
The manifold was flowed this week.
It now flows 290 CFM this should work well since my heads flow 270.
Old Mar 4, 2009 | 09:53 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Mass produce for TGO members only please.
Old Mar 4, 2009 | 04:13 PM
Long Beach Z-28's Avatar
Car: 89 IROC Z-28
Engine: 5.7
Transmission: A4
We call that "290 the HARD way". Congratulations buddy.
That is gonna be one killer combo Don!
Old Mar 4, 2009 | 06:20 PM
Car: 1989 GTA
Engine: 369 TPI
I went by Dyno Don's today to check things out. I found out that the bolt-on intake inlet radius did not quite fit the manifold port 100%. It was somewhat larger and exposed a lip. I believe this caused some loss of flow. If the inlet raduis had been of the proper diameter and matched the port better I believe Don's intake manifold would have passed the 300cfm mark.
"Mass produce for TGO members only please." No one could afford it as the man hours to get the Vortec intake manifold to this point is quite extensive.
Old Mar 4, 2009 | 08:41 PM
TPI's Avatar
Yea I understand Allen, I was being playful!
Ive been a fan of you guys for a long time though.
Old Mar 4, 2009 | 11:33 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Stupid question, but, why didn't you just go with a FIRST injections Vortec base? They do make them.....
Old Mar 5, 2009 | 02:14 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Engine: 355 TPI siamesed runners
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The FIRST stuff is exclusive and requires using all their parts. We already have SLP siamesed runners and dont want to buy all new parts.
See 1989GTATransAm's posts about modifying the FIRST intake base to fit with his SLP runners.
Old Jul 25, 2009 | 06:10 PM
Dyno Don's Avatar
This project is all bolted together now and will be going to the dyno on 8/8/'09
Old Jul 25, 2009 | 11:33 PM
Car: 1989 GTA
Engine: 369 TPI
Looking forward to the results. We could have a new TPI horsepower leader. I won't jinx things by saying anymore. Well maybe that Vincent will have another car to climb over.
Old Aug 5, 2009 | 11:09 PM
87-monte-ls's Avatar
? when installing vortec heads w tpi setup do i need to use the vortec head pushrods or can i use the stockers on a 350
Old Aug 6, 2009 | 11:14 AM
Car: 1989 GTA
Engine: 369 TPI
Pushrods are the same.
Old Aug 8, 2009 | 07:50 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
My 10.5:1 383 is at 378 RWHP in the Van with siamessed SLP runners and an Edelbrock 3817 that has not had the injectors raised (YET!)
Old Aug 8, 2009 | 03:10 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
TODAY !! looking forward to seeing what the #'s are
Old Aug 8, 2009 | 08:38 PM
Car: 1989 GTA
Engine: 369 TPI
Fast355 those are good numbers and right in line with what ours are.
Don is running 30# injectors.
Old Aug 8, 2009 | 10:52 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Yep cant wait to see the numbers.
Any specs on this motor?
Old Aug 11, 2009 | 10:43 AM
Dyno Don's Avatar
Results are Here:
https://www.thirdgen.org/forums/sout...-sticking.html
Old Jan 17, 2011 | 11:50 PM
MyZ51's Avatar
I know this is an older thread but I'd like to chime in...
Ordered some Bosch Design III injectors which are 0.25" shorter than stock and noticed a 2nd O-ring at the tip to act as a stop and raises injectors for the fuel rail. Looking into the SDPC Vortec base... looks like most if not all of the injector bung can be ground off! My aluminum welding skills are nonexistent and this looks like an alternate way to free up some area.
1992rs/ss
Jan 31, 2025 05:10 PM
Fast355
Dec 2, 2016 06:33 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
