LSx/4L60E Tranny Crossmember/y-pipe concerns... HELP!!!!
Car: 1990 Firebird
Engine: 6.0L LQ4
Transmission: 4L60E 4000 Stall
Axle/Gears: 3.23 G80 (01 TA)
Hey guys,
My Bird has seen 300 miles of road/track time since I installed the 6.0L/TH400. Well after filling up at each passing gas station, I've decided to have a 4L60E built up to replace the TH400 and its 10mpg's! I have a Spohn Torque arm and crossmember combo on the car at the moment as well as a non y-pipe friendly set of 3" Hawks/Stainless Works long tube headers on the car.
Anyways, I ran into problems routing an exhaust around the Spohn's bulky crossmember. I only ran 3" Flex pipe but I did have to cut into the crossmember because it was nearly impossible to route around it. I can get pictures of what I'm talking about if needed.
Well, now's the time to decide whether or not I want to buy the 4L60E Spohn Crossmember or have one fabricated. I just want some advice or guidance on what other people have ran into when fabricating their 3" y-pipe. Pics are always helpful!
Thanks,
Chris
Thanks,
Chris
Car: 1984 Z28
Engine: SLOW carbed ls
Transmission: TH400 with brake, 8" PTC converter
Axle/Gears: moser 9" 4.11
Re: LSx/4L60E Tranny Crossmember/y-pipe concerns... HELP!!!!
with 3.23 gears that can't be the reason your mileage is that bad, go get a dyno tune on it with a wideband IMO. That gear ratio is no different than a 4th gen with overdrive and 3.73s
Car: 1990 Firebird
Engine: 6.0L LQ4
Well it has been dyno tuned, needs some polishing on the tune. But it does have ported heads, a big cam, and a fast 92 intake.... I'm not asking why I should keep my th400, I need advice on exhaust and crossmembers lol
Car: 87 Formula
Engine: '00 LM7
Transmission: 4L60e
Axle/Gears: 3.23 posi
if you already have the spohn torque arm, i would think it would be cheaper to just buy the crossmember and cut it ( I did the same thing). Not sure you could fab that for less than the 150 they charge, and its coated already. guess it depends on if you are fabbing and if your time is worth it to you or not.
another note, if you're in a fabbing mood, maybe you should be thinking 4l80e, as they have to be fabricated to begin with.
also that must be some cam, my 98 ls1 w/ a gt2 cam and 3k stall th400 made 18 city when I took it easy. =D
Car: 1990 Firebird
Engine: 6.0L LQ4
Car: 1984 Z28
Also a "big cam" won't like low load low rpm driving in overdrive without some surging I'm guessing as well.
Car: 1990 Firebird
Engine: 6.0L LQ4
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
