Aftermarket Vendor Review Provide questions and comments about aftermarket part vendors for the Third Gen F-Body.
Afr 195 eliminator heads
Old May 18, 2018 | 10:22 AM
fasteddi's Avatar
Axle/Gears: Strange S60 4:10s
I just wanted to display how good these afr 195 heads are. I purchased them last fall. Finally this spring I got to use them and race my car.
I have a mild 385 sbc eith a xr288hr cam, victor jr intake, 750 carb, 4.10 gear, ptc 5k stall. All motor and a 3400lbs race weight street strip camaro.
Right out of the Box these heads where beautiful the craftsmanship was amazing, they looked like you would want to display them on the wall. Bolt up was easy, and customer support was perfect.
I made 3 passes so far with the heads with a best of a 10.73@125mph. 1.48 60 foot.
I purchase these from summit racing but I highly recommend them for anybody with a mild small block Chevy. I never thought I would go this fast with A 195 head.
Old May 18, 2018 | 03:58 PM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Re: Afr 195 eliminator heads
Damn! That is really fast!
How does the car idle?
Old May 18, 2018 | 05:08 PM
fasteddi's Avatar
Idles great, a bit lopey but manageable driving it arround kn the road.
in car vid
idle clip when I was first tuning it.
Old May 19, 2018 | 12:55 PM
Manic Z's Avatar
Exhaust sounds great!
What is it?
Old May 19, 2018 | 03:13 PM
fasteddi's Avatar
What is it?
has Doug's long tube 1 3/4 headers and dual 2 1/2 inch collectors and cut outs right now. No mufflers. Loud on the road... I have race mufflers to toss on still
Old May 20, 2018 | 10:49 AM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
That's some good vacuum with that cam.
Old May 20, 2018 | 10:59 AM
skinny z's Avatar
Originally Posted by fasteddi
a xr288hr cam,
Originally Posted by Jorlain
That's some good vacuum with that cam...
Have the 288 in my 355. Idle vacuum is about 12" with vacuum advance on manifold and about 28° of idle timing. And with a lean cruise tune I can manage better than 20 mpg on the highway. So you can be fast and economical if you really want to be...
Well done Eddi. I've always liked your car. Something mine will eventually morph into as I get away from mostly street to being mostly strip.
Old May 20, 2018 | 11:00 AM
skinny z's Avatar
Don't forget to address the correct tuned collector length. There's power and torque left on the table if you disregard it's impact.
How far past the header flange are your cutouts?
Old May 20, 2018 | 11:23 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Axle/Gears: MWC 9” 3.00
One of the best street strip bolton ready heads out imo. Price has gone up over the yrs but most things have anyway. They just make power tho
Your setup is really moving good for the parts. I had slightly smaller duration cam but more lift in my 383 with afr 195’s. It went 11.47 at 118 with best of 119 mph in summer air. Stealth ram intake. Wasnt as racey tho with just 3.42 gears and 3600 stall
Old May 20, 2018 | 06:45 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Even at 16° timing at idle, I'm barely pulling 12" with my 276HR at a reasonable idle speed. Makes me wonder.
Old May 21, 2018 | 06:21 AM
fasteddi's Avatar
The cutouts are 14 inches past the header collector. I'm not positive if that's long enough as I've heard a lot of ideas about collector length.
Old May 21, 2018 | 06:22 AM
fasteddi's Avatar
I agree they are the best outta box sbc head for street strip cars. I was quite surprised how fast my combo is going as well. I was expecting 11.20s or a bit under. Never did I expect 10.70s. Even though it is a track set up.. the mph shows how much hp its pushing which amazes me.
But keep in mind I ran 11.60s@115mph last year with ease and it was a very mild set up. Xe268 can, 3.23 gear, 3500 stall, old as cast 200cc dart iron heads. I was shifting at 5200 and trapping about 5000rpm. So my car must be set up pretty well.
Old May 21, 2018 | 12:03 PM
skinny z's Avatar
A little more timing will bump the idle vacuum up. I had about 14" of vacuum with the XR276HR.
Idle speed with the 288 is about 800-850. With the 276, I managed a lower idle speed of around 750.
I have the base timing set at 16° and my vacuum advance is all in at 8-9" vacuum which adds another 12-14° depending on my tune.
Old May 21, 2018 | 12:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
That seems really good for the 288 cam. Its not a small cam by any means
skinny z's Avatar
I would agree.
And I'd like a set of the AFRs as well. They seem a perfect fit for 383 CID.
Old May 21, 2018 | 12:06 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Thats not to bad to be honest
14 plus length of collector would be around 21-22” i guess? Depending what rpm you tune for, thats getting close to the “bad” length and just past ideal
Ideal likely would be 17-18 from end of primary tubes to atmosphere cutout
Might like 3” collectors too
Best lengths are 16-18” or 33-35”
Old May 21, 2018 | 12:46 PM
skinny z's Avatar
I haven't run PipeMax for a 383 so my 355 results won't necessarily be what's best but lengths are 19.3 and 38.5 for best torque. Best HP is 19.3 and 9.5".
This is for a members engine here at Thirdgen and was spec'd with a short style header. I'll look to see if I don't have an archived 383 file buried somewhere.
Old May 21, 2018 | 12:52 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Why shorty header?
Old May 21, 2018 | 02:55 PM
skinny z's Avatar
Why shorty header?
A member here (loopy) has that as part of his build. Not my choice but I ran the Pipemax for him to see what the results were.
If fasteddi posts enough engine information, I could probably run it through the program.
Old May 21, 2018 | 03:10 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Yeah i ran my old 383 thru an older version and got the lengths above
Old May 21, 2018 | 03:33 PM
fasteddi's Avatar
14 inches is from the collector flange to the cut out inlet flange itself. Its a short amount but just long enough that my widebands work good
Old May 21, 2018 | 03:35 PM
fasteddi's Avatar
Last year I went from hooker shortie headers 1 5/8 into the y pipe and 18 inches to a open cutout to these Doug long tube 1 3/4 headers and the exhaust I have now... went from running 11.90s@110mph to running 11.60s@115mph just like that did nothing else. Amazing if you ask me.
Old May 21, 2018 | 03:39 PM
skinny z's Avatar
There may be more too depending on how close you are to optimum now. It's crazy how a few inches one way or another can make or break a combination.
I go back to the times when my headers were freshly installed and the car had to be "delivered" to the exhaust shop. Driving around, the headers open and nothing more than maybe a 6" long collector (primary tips to flange) and the engine was complete slug low in the RPM range.
Post your specs as per below and I'll run it through for you. (If you're so inclined).
THAT is exactly the kind of result I'm hoping for once I get to that point. The single full length 3" exhaust is absolutely killing performance. A simple set of cutouts would be all that's needed to add similar improvements as you've had.
Old May 21, 2018 | 04:40 PM
fasteddi's Avatar
what specs do ya need? You mean all the engine ones?
385 sbc 4.040 bore. 3.75 stroke. P2d .012 head gasket .027, quench .039, +5cc flat top pistons with 2 reliefs. Afr 195 heads 218 cfm exhaust 280cfm intake@.550 lift comp xr288hr cam. 288/294 adv. Duration. 236/242 dur at. 050. .555/.576 lift with 1.6 rocker. 110 lsa installed at 106 centerline. 11.0:1 compression, victor jr intake 2999 version which has 1 inch taller adapter built in, holley 750 carb with proform main body, double pumper mech. 2nds.
Old May 21, 2018 | 05:21 PM
skinny z's Avatar
A few questions.
Rod length?
Peak HP RPM?
If you have the valve sizes and stem diameter that'd be handy. Otherwise I'll look up stock AFR Eliminator specs (street version).
Old May 21, 2018 | 05:36 PM
skinny z's Avatar
Based on a couple of assumptions:
Looks like a 3" + collector at 17.2" is the ticket.
8.6" for more HP (sometimes)
34.4" for best TQ.
Old May 21, 2018 | 05:49 PM
fasteddi's Avatar
A few questions.
Rod length?
Peak HP RPM?
If you have the valve sizes and stem diameter that'd be handy. Otherwise I'll look up stock AFR Eliminator specs 6500(street version).
5.75 rod 2.05 Intake valve. 8mm stem. Thanks man those charts are nice
Old May 21, 2018 | 05:50 PM
skinny z's Avatar
Do you think peak HP comes in about 6500? Maybe closer to 6000?
Old May 21, 2018 | 05:55 PM
skinny z's Avatar
Dropping peak HP RPM down to 6000 stretches the collector to 18.6".
Considering the worst case is about 28" there's some margin for a good result even if you're off by a couple of inches.
Old May 21, 2018 | 07:12 PM
fasteddi's Avatar
I think closer to 6000-6200 would be peak hp. I may play with length next time out and just see what it does. 10hp or more is worth it.
Old May 21, 2018 | 07:18 PM
skinny z's Avatar
I'd like to see that kind of test result.
darakus
39
Jun 17, 2010 07:59 AM
C409
Jul 2, 2009 01:02 PM
1989GTATransAm
Aftermarket Product Review
18
Jun 25, 2008 08:31 PM
Burnout91
Mar 22, 2007 04:56 PM
