SLP 1-3/4 headers, AFR 195 Eliminator heads with straight plug angle, results within
Old Feb 4, 2007 | 05:01 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Well I got some good news and some bad news.
Good news is the straight angle plugs work out perfect on these heads with SLP 1-3/4! It's no different then bolting the SLP's to my stock heads, only spot that will give you trouble is cylinder #5 when trying to get a socket on the plug to tighten down the spark plug but I had the same problem with the stock heads. What I did long ago was cut out a window out of a sparkplug socket, works great. I'll get proper pic's for you guys hopefully tuesday when my set of 8 AR3923's plugs come in, don't feel like taking 8 separate pic's with the one plug I do have.
Now for the bad, there is quite a mismatch with the exhaust port and SLP's. These AFR's exhaust ports are huge and the SLP's are kind of small in comparison. I'll post some pic's and you guys tell me what you think.
Attached Thumbnails SLP 1-3/4 headers, AFR 195 Eliminator heads with straight plug angle, results within-picture-002.jpg   SLP 1-3/4 headers, AFR 195 Eliminator heads with straight plug angle, results within-picture-003.jpg   SLP 1-3/4 headers, AFR 195 Eliminator heads with straight plug angle, results within-picture-004.jpg
Old Feb 4, 2007 | 05:03 PM
Tony89GTA's Avatar
Car: 89 GTA
more pic's
Attached Thumbnails SLP 1-3/4 headers, AFR 195 Eliminator heads with straight plug angle, results within-picture-006.jpg   SLP 1-3/4 headers, AFR 195 Eliminator heads with straight plug angle, results within-picture-007.jpg   SLP 1-3/4 headers, AFR 195 Eliminator heads with straight plug angle, results within-picture-010.jpg
Old Feb 4, 2007 | 05:04 PM
Tony89GTA's Avatar
Car: 89 GTA
pic of my spark plug tool.
Attached Thumbnails SLP 1-3/4 headers, AFR 195 Eliminator heads with straight plug angle, results within-picture.jpg
Old Feb 4, 2007 | 05:25 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
It's good to hear the straights will work. What exhaust gasket is that?
Old Feb 4, 2007 | 05:30 PM
Tony89GTA's Avatar
Car: 89 GTA
Fel-Pro #1404
Old Feb 4, 2007 | 06:23 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
I got angle plug heads with my SLP 1-3/4 headers... talk about a bitch!
Old Feb 4, 2007 | 11:08 PM
LilJayV10's Avatar
Engine: 406 Roller
can you get some pics?
Old Feb 5, 2007 | 04:23 PM
jjlabinski's Avatar
Engine: shinny 350
http://i56.photobucket.com/albums/g1...ki/engine6.jpg
Old Feb 5, 2007 | 05:18 PM
Zipdrive's Avatar
I'd say you have got some welding, cutting, and grinding to do. That one bolt hole is off more than a 1/2 dia. The heads look great though. I am interested in how your combo goes together.
Old Feb 5, 2007 | 06:52 PM
Tony89GTA's Avatar
Car: 89 GTA
What do you mean it's off?
Old Feb 5, 2007 | 07:17 PM
Zipdrive's Avatar
Sorry, my mistake. I was looking at the second hole from the right. The back side of the flange caught my eye first and it 'appeared' to be off. What are you going to do about the port size?
Old Feb 5, 2007 | 07:19 PM
LilJayV10's Avatar
Engine: 406 Roller
what exhaust gasket does AFR recommend?
Old Feb 5, 2007 | 07:41 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Hehehe, You look like me when we were assembling my motor. I'm using the Dart Pro One 200cc heads with straight plugs but with custom headers by Dyno Don. The only problem I had was trimming the header gasket at the top about 1/16" to it would clear the top of the exhaust port. No problem with the headers. I bet my collector opening is bigger than yours. That is just one of the reasons I went with a custom build.
Old Feb 5, 2007 | 09:56 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I have allways used a 5/8 wrench, allways gets those hard to get suckers, the one thats shaped like --------\_ , it sits in the head area well.
Old Feb 5, 2007 | 10:03 PM
LilJayV10's Avatar
Engine: 406 Roller
How about a pic that shows what makes the L98 plugs so difficult? That pic doesn't show anything.
Old Feb 6, 2007 | 07:54 AM
Tony89GTA's Avatar
Car: 89 GTA
Fel-Pro #1404
I'am pretty sure he is talking about the regular angle plug heads not L98.
Old Feb 7, 2007 | 09:27 AM
88BlackZ-51's Avatar
Tony those gaskets don't look too bad at all. I sent you a few pm's. I might of called you this morning by an accident.
Old Feb 7, 2007 | 03:16 PM
jjlabinski's Avatar
Engine: shinny 350
no L98..... world products sportsmanII's with angle plugs
Old Feb 27, 2007 | 02:31 PM
Tony89GTA's Avatar
Car: 89 GTA
Ok I finally got my spark plugs in so I took some pic's with the plugs in with the boots on, as you will see there is plenty of room to work with. The crappy part of this is I might not be using these headers since the ports don't really match that great so I might be going with some long tubes if they fit ok for me.
This is the driver side
Attached Thumbnails SLP 1-3/4 headers, AFR 195 Eliminator heads with straight plug angle, results within-driver1.jpg   SLP 1-3/4 headers, AFR 195 Eliminator heads with straight plug angle, results within-driver2.jpg   SLP 1-3/4 headers, AFR 195 Eliminator heads with straight plug angle, results within-driver3.jpg
Old Feb 27, 2007 | 02:32 PM
Tony89GTA's Avatar
Car: 89 GTA
passenger side
Attached Thumbnails SLP 1-3/4 headers, AFR 195 Eliminator heads with straight plug angle, results within-passenger1.jpg   SLP 1-3/4 headers, AFR 195 Eliminator heads with straight plug angle, results within-passenger2.jpg   SLP 1-3/4 headers, AFR 195 Eliminator heads with straight plug angle, results within-passenger3.jpg
Old Feb 28, 2007 | 02:45 PM
LilJayV10's Avatar
Engine: 406 Roller
Looks good. I have seen people say they have had problems with straight plugs but I don't see where the problem would be at. I'd like to see some pics like that of L98 plug heads. Thanks for the pics.
Old Mar 11, 2007 | 09:50 AM
Beater79TA's Avatar
Since the ports don't appear to line up very well between the heads and the headers, what are the other options for emissions legal headers that might match up better?
I'll be running the same heads with a D1SC as well so I want at least 1 3/4" headers for it and SLP appeared to be the only emissions legal option.
Old Apr 6, 2007 | 08:12 PM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Re: SLP 1-3/4 headers, AFR 195 Eliminator heads with straight plug angle, results wit
So what did you end up doing with these headers not matching the exhaust ports? Did you port the headers to match the heads?
Old May 8, 2007 | 02:19 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
How would the clearance be if the exhaust would be raised 6mm, would they still clear with straight plugs?
Any pict of L98 angled heads?
/N.
Old May 8, 2007 | 02:57 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
I could e-mail you a picture of the AFR 195 Angle
with the SLP 1/34" headers if you want to post it.
Biggest problem is #8 spark plug to header clearance.
Having to use Autolite shorty plug and 1'' header wrap
with stainless tie.
Later
Old May 8, 2007 | 06:01 PM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
with stainless tie.
Later
Can you send me a pic and also what plugs you use. i'm in the same boat. I need to know the spark plug number. I have a set of SLP headers and angle plug heads. shortie pklugs would help alot. thanks
Old May 9, 2007 | 12:05 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
email me the pictures gta324@spray.se
are they AFR 195 eliminator heads?
Just heard that AFR210 with straight plugs arent availible yet
The AFR210 also have the exhaust port a few mm higher that 195Cc, to make it worse....
Old May 9, 2007 | 01:33 PM
jaykar's Avatar
I'll take a picture of the problem header pipe, #8 with
the AFR 195 Angles with the SLP 1/34 headers.
Just need e-mail address and would appreciate it
if you would post it here to help others.
The plugs I am using are Autolite 3926 shorties and
also help out with a couple of other pipes that are
pretty close
Don't have the software to downsize pics for posting.
Take about a day to get pic.
Later
Old May 16, 2007 | 01:35 PM
jaykar's Avatar
Hi,
Pic sent
Later
Old May 16, 2007 | 07:57 PM
Car: 1992 Camaro RS
can i get pics too.
evilstuie
Feb 28, 2016 03:33 PM
CRFred
Feb 7, 2016 11:39 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
anesthes
Aug 8, 2015 09:37 PM
