MY 383 build going for tens now !!
Old Mar 2, 2018 | 05:51 PM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
precious
crank is in
nice view of cam and cylinder wall
pistons baby
all most a short block
Attached Thumbnails MY 383 build going for tens now !!-383block.jpg   MY 383 build going for tens now !!-20140808_224556-1-.jpg   MY 383 build going for tens now !!-cam-card-383.jpg   MY 383 build going for tens now !!-383bk.jpg
Old Mar 8, 2018 | 04:51 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Re: MY 383 build going for tens now !!
Who did the cloverleaf in the top of your intake? I have something very similar from chad Speier.
What is the head combo?
Looks like it will be a runner!
Old Mar 8, 2018 | 08:33 PM
MY-92-RS's Avatar
The heads were Cast by ALLPRO running 2.08 -1.65 titanium valves
the custom port work on the Heads and intake were done by a good friend of mine from Texas that went to SAM Tech few years back
name is Rick
Old Mar 9, 2018 | 01:22 AM
izcain's Avatar
Engine: 584
Allpro makes some good castings! Do you have some flow numbers for them?
Looks like dart block?
Old Mar 9, 2018 | 07:37 AM
MY-92-RS's Avatar
I wish the block was a dart block much better foundation.. this is a 1975 truck Chevy sbc with Howards racing nodular main caps
flow numbers from all pro model 220 sp 23 degree heads done at 28" water
cam lift + Intake,______Exhaust
.500, + + 287.6, ______243.46
.600, + + 308,________ 250.39
.650, + + 312.75,______ xxxx
.700, + + 314.15,______ 252.65
Old Mar 9, 2018 | 11:12 AM
izcain's Avatar
Engine: 584
Oh don't feel to man, we are running nines on a factory 76 block out of a school bus. That without turning it up much.
They will take a lot as long as the tune up is right.
Dart block will come in due time.
Sounds like we have a very similar block. I had mine machined with Pro-Gram billet mains.
Those are some good flow numbers. It should run well
What does the rest of your valvetrain consist of? You going shaft rockers?
After running shafts they are very nice! I really like mine so far.
Old Mar 9, 2018 | 02:55 PM
MY-92-RS's Avatar
I want to run a shaft mount setup need to find good set up fair price kind of thing you price out 1.6 stud mount roller rockers , 7/6 studs, stud girdles guide plates etc etc you are looking at $600-800
you can buy a good shaft mount around $1200
Old Mar 10, 2018 | 12:30 AM
izcain's Avatar
Engine: 584
You can buy them better then that. Pm me and I can send you some contact info for Shelton bars at lgm development. He has some very nice shaft rocker setups for great prices.
Old Mar 10, 2018 | 12:37 PM
MY-92-RS's Avatar
pistons are in
coming along now cam has been degreed
nice pic of crank and rods
Updates engine is getting close...
by the way I am using Royal Purple assembly lube !!!
Old Mar 10, 2018 | 03:03 PM
Jacobaxeman's Avatar
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
what crank is that? Beautiful set up its going to run awesome
Dont be so quick to abandon stock blocks they work great with great power, we race a 8500 rpm 355. They usually break when a rod lets go lol.
Old Mar 10, 2018 | 08:06 PM
MY-92-RS's Avatar
Thanks for the vote of confidence.... 8500 rpm you don't mess around ..
The crank is a piece of work to say the least got it from crankshaft specialties back in the early 2000 had it sitting for years, Recently I had it checked by local machinist found it was under standard and not balanced properly got to pay for it twice
the stock block has hard block in it and will have all the passages o-ringed
Old Mar 12, 2018 | 02:28 PM
izcain's Avatar
Engine: 584
I have touched the 8200 limiter a couple of times. I don't like doing that though! lol
Old Sep 12, 2018 | 08:36 PM
MY-92-RS's Avatar
MORE ENGINE **** !!
these are going on the 383....
Old Sep 12, 2018 | 09:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I use T&D myself. Comp Cams versions but still made by T&D. Either way, a shaft rocker is much better than a pedestal rocker. When I installed mine, it relocated the rocker directly over the tip of the valve. Doing so also moved my pushrods over and I had to modify the pushrod passage through the head so that they wouldn't hit the walls.
I went from this with a stud girdle and tall valve covers and still needing a rocker cover spacer.
To this with shaft rockers and a low profile rocker cover.
Old Sep 13, 2018 | 11:41 AM
MY-92-RS's Avatar
That is definitely the way to go!! I had stud girdles and all that stuff on my last engine.. Pain in the but.. I like your set up, clean simple get it done; did you have to go to off-set plungers in the lifters??
Old Sep 13, 2018 | 07:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Actually, I was considering it but it's never recommended and not all the rockers would require an offset plunger. Only a couple of the pushrod holes through each head had to be modified. With aluminum heads, it's not hard to shave out some extra metal for the clearance.
There's a lot of metal in these heads. The intake ports have sleeves inserted where the headbolts pass through since the porting goes out into head bolt area.
It took a bit to get the stands all set up properly. The exhaust was pretty straight forward. The intakes needed a taller stand because of the longer valves plus I have lash caps. Once it was all set up, valve train geometry is as perfect as I can get it. Nice thing about shaft rockers is that you can unbolt them to change a valve spring then just bolt them back up without needing to recheck the lash.
Shaft rockers is the way to go especially when your valve train is on the extreme side. My triple springs have an open pressure around 800 pounds. Seat pressure is around 300 pounds. Valve lift is .833/.809 so those rockers and springs get a lot of abuse at 7000+ rpm.
Shaft rockers are just overkill for a street engine but if you have the money to throw at the engine, it sure won't hurt them.
Old Sep 14, 2018 | 07:07 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Axle/Gears: MWC 9” 3.00
​​​​​​​thats it? I figured you would be mid lower 300’s seat and 900-1000 open depending on the lobe
Old Sep 17, 2018 | 04:26 PM
MY-92-RS's Avatar
we are a short block now !!
Old Sep 17, 2018 | 04:36 PM
MY-92-RS's Avatar
Top end !! heads , valves springs !!
Old Sep 17, 2018 | 04:42 PM
Looks great!
I think i'm losing another #509 400ci block. Can't seem to keep cam bearings in it. Even had it fixed at Tim Wilkersons shop with his cnc equipment. Oh well, time for an aftermarket block.
Old Sep 29, 2018 | 11:49 AM
MY-92-RS's Avatar
Originally Posted by TTOP350
Looks great!
Ouch .. sorry to here that !! this is most likely the last factory block I will ever build >I have one more that will be a 383 backup street engine built with parts laying around the garage .. than that is it for me.. aftermarkets blocks are so inexpensive now and so much better than Chevy ever cast .. there really no reason to use a factory block on a hi-end build north of 500 horsepower
Old Sep 29, 2018 | 12:00 PM
MY-92-RS's Avatar
GOT HEAD !!
Old Dec 5, 2018 | 12:45 PM
MY-92-RS's Avatar
Ready for the DYNO Cell !! ALMOST !!
Old Dec 7, 2018 | 08:34 PM
skinny z's Avatar
I've the same timing cover bought primarily for the built in and adjustable thrust button. I'd also thought about using the access to get at the Hex-A-Just timing set but after setting the cam timing initially, I never went back.
Old Dec 12, 2018 | 09:19 PM
MY-92-RS's Avatar
I agree it is a real nice piece looks good on your motor .. I probably never will go back in mine either but I do like how you set the can button !!
Old Feb 22, 2019 | 07:21 PM
MY-92-RS's Avatar
614 horsepower 595 torque CONSERVATIVE TUNE !!
383 on the DYNO !!
DYNO DAY IS HERE !!
Old Feb 23, 2019 | 11:02 AM
skinny z's Avatar
Nice numbers. Who spec'd that cam? It seems it's rare to see a tight LSA of 106 but that's a desired target for a 383. Seems most just fall back to the standard 110 out a catalogue and consequently leave considerable performance behind. You can't argue with your results.
Old Feb 23, 2019 | 09:09 PM
Nice work! That should get it moving
Old Feb 24, 2019 | 11:55 AM
MY-92-RS's Avatar
I got this Cam from Sam at Guardian Performance out of Tennessee he used to build engines For old Bob Glidden back in the 80ties unfortunately neither of them is still with us ..
This cam has been sitting in my closet for many years waiting to be used !!
Old Feb 25, 2019 | 10:19 AM
skinny z's Avatar
Looks like it was an excellent choice.
Old Feb 25, 2019 | 05:05 PM
izcain's Avatar
Engine: 584
The HP gods are smiling from above giving him a high five on the cam choice!
Great job on the build man that thing should move right out!
144 on 305
Feb 6, 2014 04:44 PM
PimpRod92RS
Car Audio
May 27, 2002 01:04 PM
89 4Mula 350 Tbi
Car Audio
Jan 4, 2002 07:13 AM
irocz_ca
Car Audio
Mar 30, 2001 10:39 AM
