Air pump delete
Air pump delete
Just have questions on deleting the air pump on my 89 IROC-Z 305 SBC. I'm looking at getting headers, and the ones im looking at, Hooker competition, don't have the connection for the air pump. Any recommended pulleys or advice on getting one? New to trying to delete air pump. Just wanna make sure that i'm not gonna screw anything up by deleting it. Thank you for any advice in advance.
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Air pump delete
Re: Air pump delete
Run a string around the pulley's, except skip the air pump.
However long that string is, is roughly how long the belt needs to be. Usually the belt length is somewhere in the part number. Then you try until you find one that fits and tensions correctly.
Re: Air pump delete
On a TPI car I remember it being a 96.5 " belt. Ive seen pics here on the re-routing I think.
Car: 2002 Dodge Ram 1500 Quad Cab
Engine: 4.7 Liter
Transmission: 4 Speed Auto
Re: Air pump delete
A 95 Chevy Silverado 1500 does not have the pump, get a belt for it and look up the routing. That's how I figured out how to re-route my old Firebird TBI that I never did.
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: Air pump delete
ACDelco #935K6 + your Cat converter(s) need a plug of some sort or be replaced.
https://www.thirdgen.org/forums/tech...p-removal.html
https://www.thirdgen.org/forums/tech...ml#post6367775
https://www.thirdgen.org/forums/tpi/...-diagrams.html
https://www.thirdgen.org/forums/tech...e-without.html
https://www.thirdgen.org/forums/exha...p-removal.html
... and so on
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: Air pump delete
